Building custom go!bus modules for Netduino Go
102 replies to this topic
#81 Lunddahl
Lunddahl
  • 152 posts
  • LocationEurope, Denmark
Posted 25 June 2012 - 09:50 PM
Good strategy. And there's an STM32F2 in between the STM32F0 and F4...the Shield Base uses this and it hits a "sweet spot" in price/memory.
With my limited knowledge it seems to be the only way to build a module, is the source for the Shield Base available?
The modules should be flashable via go!bus, no special hardware required. And with the upcoming standard virtual I/O firmware, you'll be able to just say "use pins X, Y, and Z on the STM8S for the following features" and no knowledge of C or STM8S architecture will be required. Those pins/features will simply become "part" of the mainboard.
This, also sounds very promising for someone who will never be able to write code for something like a STM8S.
What features will be available, only GPIO pins, or will there also be hardware busses like I2C, SPI (besides what is used for the go!bus), and ?
I'm thinking of building a temp sensor module that uses I2C temp sensors.
- Ulrik Lunddahl
#82 Chris Walker
Posted 26 June 2012 - 11:33 AM
Hi Ulrik,
Yes, you could use I2C. Just attach your temp sensor to the I2C pins and the upcoming standard io firmware will take care of the rest. You'd build your support library (speaking I2C) in C#, running on the mainboard.
#83 mcinnes01
mcinnes01
  • 325 posts
  • LocationManchester UK
Posted 28 June 2012 - 06:06 PM
Can anyone tell me if I can get the following IO from the STM8S103F2P3's that I have bought. Alot of my project relies on temperature readings and the first moule I am planing to make is a relay control board. I know a lot of other people will be doing relay control modules but this one doesn't include the relays the idea being you pick your own for what ever it is you are doing. Any way without babbling too much about the spec... I need 6 logic 2 pwm and something to make a 1-wire bus (I guess this is serial right can anyone correct me?) The problem I am having is I'm not sure what is used by the GO bus on the STM and what this leaves to play with even from reading the datasheet. Is it possible to achieve 1-wire on an STM and is SWIM 1-wire or is this different and is this required for the GO bus? Thanks in advance for any info you might have. Andy PS the 1 wire is for temperature monitoring and I am intent on using ds18b20s as they are really accurate.
#84 CW2
Posted 28 June 2012 - 06:59 PM
SWIM uses one wire, but it is not Maxim/Dallas 1-Wire protocol; it is required by go!bus to support module firmware update. You can implement Maxim/Dallas 1-Wire protocol on STM8 either by bit-banging (on any pin, a little bit more useful are pins marked as 'True Open-Drain'), or using its UART in [rather unusual] Single Wire Half Duplex mode, the generation of appropriate waveforms is described in Atmel's Application Note AVR318.
The go!bus protocol requires STM8's reset, SWIM, SPI_MISO, SPI_MOSI, SPI_CLK, SPI_NSS and one pin for GPIO/!IRQ. You can check the Netduino GO! Module Builder Guide for more information and have a look at the schematic of the current modules for inspiration.
#85 supra
supra
  • 210 posts
  • LocationOntario, Canada
Posted 23 August 2012 - 11:49 AM
Yessir, that's perfect from the module's perspective.
Hey chris, I have suprised 4 u. Pin 4 and 5 isn't accurately. Posted Image Pin 4 could be RX instead of TX. and PIN 5 could be TX instead of RX
Here's the breakdown: As u mentioned before.
  • 3V3
  • 5V
  • GPIO+/IRQ
  • UART_RX (from module's perspective) Posted Image Could this be TX Posted Image
  • UART_TX (from module's perspective) Posted Image Could this be RX Posted Image
  • SPI_SS
  • SPI_MOSI
  • SPI_MISO
  • SPI_SCK
  • GND
This is what I found on schematic saying that pin 4 is TX and pin 5 is RX.
Which is one accuratedPosted Image
#86 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 23 August 2012 - 01:03 PM
Hi Supra
TX from the GO goes to RX on the on the module and vice versa, admittedly its confusing but if you look at the go schematic you will see pin 4 is TX on the go, so pin 4 on the module would be RX.
i.e. the transmission (tx) from the go on pin 4 is received (rx) on pin 4 of the module, whilst the module transmits on pin 5 and is received by the go on pin 5.
You find the TX to RX naming/wiring convention being used in lots of 2 wire/channel transmission protocols, such as RS232, MIDI, DMX (i think) etc. etc.
It can also help to think of TX = out and RX = in, and that you need to go out to come in
Hope that helps
Nak.
#87 supra
supra
  • 210 posts
Posted 08 September 2012 - 02:59 AM
@nakchak
I found this on netduino go wiki:
GO! Socket
Pinout
  • 3V3
  • 5V
  • GPIO+/IRQ
  • SPI_SS
  • SPI_MOSI
  • SPI_MISO
  • SPI_SCK
  • GND
Netduino go's schematic got me confusedPosted Image
Thank!Posted Image
#88 Gutworks
Gutworks
  • 363 posts
  • LocationOttawa, Ontario
Posted 08 September 2012 - 03:18 AM
@nakchak
GO! Socket
Pinout
  • 3V3
  • 5V
  • GPIO+/IRQ
  • SPI_SS
  • SPI_MOSI
  • SPI_MISO
  • SPI_SCK
  • GND
Thank!Posted Image
Hey Supra,
You may also find this image helpful. I pulled it from Fabien's "What Is an Arduino Shield and Why Should My Netduino Care?" article.
Attached File  GoSocket.png   50.88KB   48 downloads
Cheers,
Steve
#89 supra
supra
  • 210 posts
Posted 08 September 2012 - 03:27 AM
@gutworks Thank!
#90 AlfredBr
AlfredBr
  • 138 posts
  • LocationConnecticut, USA
Posted 28 October 2012 - 06:18 PM
And here's the through-hole version:
FCI 20021511-00010T1LF
http://www.mouser.co...kTNcJ8wnslDRg==
Can anyone share or point me to an Eagle layout for the thru hole version?
#91 baxter
baxter
  • 415 posts
Posted 28 October 2012 - 11:35 PM
Here is a SMD socket socket library, http://3ln.org/blog/...-socket-library Eagle has a 10 pin footprint, con-leotronics 1365-10, but I have not been able to find a through hole shrouded part with the correct pitch. Baxter
#92 Jack Chidley
Jack Chidley
  • 99 posts
Posted 22 March 2013 - 01:41 PM
Help me out, where are the instructions for a lay person to build a module?
I found a couple of articles on the Wiki http://wiki.netduino...evelopment.ashx & http://wiki.netduino...ders-Guide.ashx
This from Matt http://komodex.com/b...ction-to-gobus/
Fabien wrote this http://channel9.msdn...y-Netduino-Care which mentions Go at the end.
And, of course, this http://forums.netdui...ucing-gobus-15/
I also fond this interesting article http://forums.netdui...sing-the-stm8s/
and this tempting morsel http://forums.netdui...atest-firmware/
But nowhere can I find the firmware for the special Go Module chips/Go Bus.  The shieldbase, which I think is intended to be the development platform for Go Modules, is still stuck in UART land http://forums.netdui...irmware-beta-6/
I am, still, keen to build modules myself.  Please help me.
Several people that have developed modules (including Pete, Fabien, Aarron, Matt, etc) are doing it somehow.  Although Pete, too, is waiting for Go Bus 1.5 http://forums.netdui...or-netduino-go/
#93 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 22 March 2013 - 02:16 PM
Jack,
If you check out the blog post pointed to from the above forum post you will find a link to the GoBus 1.0 firmware for the STM82 is in the conclusion of the post.
Sorry, but I make you read my waffle before giving you links to the goodies.
#94 Jack Chidley
Jack Chidley
  • 99 posts
Posted 25 March 2013 - 05:48 PM
Mark - the "waffle" is the best bit.
I also realised 2 things: I don't want to program in C and I haven't being paying attention to Chris.
Reading what Chris has written and thinking about it a bit more, I realised that module building is really simple.
1. Build the stuff on top of a shieldbase.  Do all the coding, testing, etc.  I can do this now.
2. Take the shieldbase + hardware component sandwich (e.g. an Arduino shield) and convert the sandwich into a module.
The shieldbase part of the sandwich is converted to STM chip + cable socket.  Pick the right suppliers and the chip, socket and circuit board could be less than $1 to produce. My hardware mess is added to this, and hey-presto, a module.
The unknown for me is the right STM chip - clearly using the same chip as on the shieldbase will definitely work but that is unnecessarily expensive.  I don't yet see how to make that choice or do a hardware design.  If I knew the relationship between ST pins + Go Bus pins + D1-13, A1-5, then the thing would be easier e.g. stm32f4 PD5 = Socket pin 1 (I am making this up).  Is there a spec sheet somewhere for that?
Another chip option is the one used on nwazet's DAQ, stm32f051R8T6. As the DAQ board is available now, it can be used for prototyping. And Arron's proto board.  Both chips are cheaper than the f4 one.  I guess it depends on the performance.  And there are STM's discovery boards.
Clearly Secret Labs has to provide the right firmware.  Hence the shieldbase beta testing.
#95 Nevyn
Nevyn
  • 1072 posts
Posted 25 March 2013 - 09:07 PM
I suppose that the route you wish to take really depends upon the a few factors:
  • Complexity of the module
  • Speed of the module (i.e. sensor you are using etc.)
  • Target market
For a simple module then the STM8S is a good choice, it is cheap, reasonably fast and the tools are free.  The downside as you have noted is that you really need to use C or be adventurous and try assembler :).  On the upside, the code in the blog post does isolate you from the comms for GoBus 1.0 so you have a starting point.  If you go down this route then the VariableLabs module is a good choice - be prepared to learn C.  If there is enough interest I'll be happy to make the modifications to make the firmware work with the ProtoModule.
Now consider speed.  For a simple module, say a 16-port output module based upon the 75HC595 then you would not need fast processing.  You could then take the Shieldbase and distil this down to a single PCB with the essence of the ShieldBase plus the 75HC595 electronics.  The downside is that the cost then escalates as the cost of the ShieldBase hardware then outweighs the cost of the two 74HC595s.  So for something simple you really need to consider the STM8S route.  If you wanted something faster, say driving a WS2811 LED module then you are again back to the custom code in C (even for Shieldbase hardware) as the comms with the chips is time dependent.  By distilling the ShieldBase you have removed the need to use C but have introduced a performance hit.
BTW - if you want to know the pin mapping etc for the ShieldBase then head over to this post.
And I'm glad you like the waffle :)
Hope this helps,
#96 Jack Chidley
Jack Chidley
  • 99 posts
Posted 09 April 2013 - 06:52 AM
Mark, I see that you are quietly trying to solve the problem of the lack of information.  The community needs to know what you are doing.  See
http://blog.mark-ste...co.uk/?m=201304 folks!
I am going to buy a shift register and follow along...
#97 neslekkim
neslekkim
  • 350 posts
  • LocationOslo, Norway
Posted 09 April 2013 - 10:31 AM
Mark's blog is pure gold, wish it was more of this.
Asbjrn
#98 Nevyn
Nevyn
  • 1072 posts
Posted 09 April 2013 - 11:38 AM
Thank you, glad it is being well received.
#99 Lunddahl
Lunddahl
  • 152 posts
Posted 09 April 2013 - 01:13 PM
I'm following your blog too, however i'm not sure if I will ever build a GoBus module.
- Ulrik
#100 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 09 April 2013 - 02:00 PM
I am following also Mark.  I am hoping to build some GoBus modules down the line for Pandora's Box.  While we are not running on NetduinoGO but rather the Netduino Plus 2, we plan to add one GoBus port so we can allow people to attach external sensors via the GoBus port.
