Shield Base Firmware (beta 6)
26 replies to this topic
#1 Chris Walker
Posted 26 January 2013 - 06:59 AM
Version: Beta 6 (based on 4.2.2 NETMF firmware) This update requires a Netduino Go running v4.2.2.0+ firmware. This firmware uses the GoBus 1.5 UART transport, so it temporarily requires use of 4 GoPorts (1-4 or 5-8). We will remove this restriction in an upcoming release by moving to the fast GoBus 1.5 SPI transport. Because this firmware uses an un-optimized implementation of the GoBus UART transport, SerialPort and SPI operations run at a reduced speed. This firmware includes the following updates: 1. Bug fix: SPI clock 'idle high' setting now supported This firmware includes the previous updates: 1. COM1 (shieldBase.SerialPorts.COM1 on pins D0-D1) is now available for use 2. Now compatible with legacy SecretLabs AnalogInput and PWM classes (requires 4.2.2 SDK) 3. Bug fix: SPI chip select timing corrected 4. Bug fix: PWM frequency corrected 5. GoBus 2.0 Alpha: auto-detect support for Shield Base 6. GoBus 2.0 Alpha: Pins, AnalogChannels, PwmChannels, and SPI_Devices are auto-redirected to Shield Base 7. SerialPort support (COM2/COM3 on pins D2-D3/D7-D8) 8. SPI support (SPI1 on pins D11-D13) 9. New ShieldBase.SerialPorts and ShieldBase.SPI_Devices enumerations 10. GoBus 1.5 transport: error-correction with CRCs, frame acknowledgements, retries, etc. 11. InterruptPort support (pins D2-D13, although A0-A5 can be used by advanced users) 12. New ShieldBase.PWMChannels and ShieldBase.AnalogInputs enumerations (matching Netduino 4.2) 13. PWM no longer stops working 'randomly' 14. PWM scale now works properly NOTE: if you are using your Shield Base (with upgraded STM32F2 chip) as a standalone NETMF board, you can build the 4.2.2 NETMF firmware from source or use the original 4.2.0 firmware for Shield Base. To upgrade your Shield Base: 1. Plug your Shield Base into GoPort 5 on your Netduino Go. 2. Deploy the attached updater app, and watch your Output window. 3. When prompted, press the Netduino Go's onboard button to start the flashing process. 4. While flashing your Shield Base, GoPort 5's LED will flash and the Output window will provide status. 5. When the Shield Base is completely updated, the white power LED will flash. After the upgrade, simply deploy a new app to your Netduino Go mainboard. If you have trouble communicating with the shield base, power cycle your Netduino Go. Please post in this thread if you have any troubles. Thank you for beta testing the Shield Base, Chris
#2 supra
supra
  • 210 posts
  • LocationOntario, Canada
Posted 26 January 2013 - 11:06 AM
Thank you, Chris.
NO more "checkiing your hardware". Worry free. :)  :)  :)  :)
#3 mcinnes01
mcinnes01
  • 325 posts
  • LocationManchester UK
Posted 26 January 2013 - 11:47 AM
Hi Chris, Just wondered if there is an estimated date for multiple shield base support? Also any ideas on the 1-wire support on shield base? many thanks, Andy
#4 Chris Walker
Posted 26 January 2013 - 03:50 PM
Hi Andy,
Multiple shield bases will be enabled later this winter/spring. OneWire will be the first new feature we add to Shield Base after that. Chris
#5 wernerotten
wernerotten
  • 8 posts
Posted 10 February 2013 - 02:04 PM
Hi Chris;
I am getting an execution error when running the program to upgrade the shield base. Advise?
#6 wernerotten
wernerotten
  • 8 posts
Posted 13 February 2013 - 03:04 AM
Hi Chris;
Here the error I am getting when updating the baseshield.
Any Advise
  bool GetAck()   {   if (_isDisposed)   throw new ObjectDisposedException();
  byte[] readBuffer = new byte[1];   int bytesRead = 0;
  bytesRead = _serialPort.Read(readBuffer, 0, readBuffer.Length);
  if (bytesRead == 0)   throw new Exception(); // timeout exception
  if (readBuffer[0] == 0x79)   return true;   else if (readBuffer[0] == 0x1F)   <-- here it is where the error happen the buffer value is 128   return false;   else   throw new Exception(); // invalid byte  <-- throw this exception   }
#7 Chris Walker
Posted 13 February 2013 - 09:32 PM
Hi wernerotten, Which port is your Shield Base connected to? Are you using a long cable or a short cable? Can you try another cable really quickly? Finally...did you unplug all the other modules while flashing the shield base (or at least the ones on that half of the board...1-4 or 5-8)? It looks like either the data is getting corrupted or the board might be connected to the opposite GoBus channel. Chris
#8 wernerotten
wernerotten
  • 8 posts
Posted 14 February 2013 - 02:48 AM
Hi Chris;
I used to different cables (provided with the Netduino) connected to Port 5, the only module connected was the base shield; in both cases I got same error.
#9 Chris Walker
Posted 14 February 2013 - 07:25 AM
Hi wernerotten, Can you try using port 4 instead--and changing the "5" to a "4" at the top of the code? I'm just trying to isolate any potential issues here. Flashing is pretty straightforward...so it's possible that something here got damaged somehow (maybe even in shipping). Chris
#10 wernerotten
wernerotten
  • 8 posts
Posted 16 February 2013 - 03:09 PM
Chris;
Unfortunately exactly same error.
Could be an issue that I upgraded the Netduino Go to 4.2.2 before trying to upgrade the Base Shield,
#11 Chris Walker
Posted 16 February 2013 - 08:10 PM
wernerotten, Netduino Go running 4.2.2 firmware is fine for flashing the Shield Base. Did you use the Shield Base (with its old firmware) prior to trying to upgrade it? Chris
#12 wernerotten
wernerotten
  • 8 posts
Posted 17 February 2013 - 02:51 AM
Hi Chris;
 Unfortunately not, I can't tell you if it was OK before the upgrade; today I tried a small test application using Nwazet Touch screen but it halt without giving an error (inside a Try Catch block), I tried with different port (5,4 and 1) with same result.
#13 eplaksienko
eplaksienko
  • 112 posts
Posted 20 February 2013 - 01:11 PM
Hi!
Get error in a beginning to re flash Shield Base, even not able to reach a point to push button on Go
Error 1 Device not found or cannot be opened - USB:NetduinoGo
Heeeeeeeelp :(
#14 eplaksienko
eplaksienko
  • 112 posts
Posted 20 February 2013 - 11:35 PM
Folks, help please :(
#15 Chris Walker
Posted 21 February 2013 - 12:13 AM
Hi eplaksienko,
Get error in a beginning to re flash Shield Base, even not able to reach a point to push button on Go   Error 1 Device not found or cannot be opened - USB:NetduinoGo   Heeeeeeeelp :(
Okay, that's a different issue. Let's try to solve that first. The newer firmware for Netduino Go uses the USB name "Netduino" instead of "NetduinoGo". Open up project properties and go to the .NET Micro Framework tab. Change the transport from USB to Serial and then back to USB again, to make sure that it sees "NetduinoGo_Netduino" as the deployment target. Then save the project and try to deploy again. Does that get your Netduino Go up and running? Chris
#16 eplaksienko
eplaksienko
  • 112 posts
Posted 21 February 2013 - 02:47 AM
Chris thx, this worked, but then I got exception here in STM32Bootloader.cs
bool GetAck()
            if (_isDisposed)
            int bytesRead = 0;
            if (bytesRead == 0)
                return true;
                return false;
            else
The message
An unhandled exception of type 'System.Exception' occurred in STM32ReflashApp.exe . looks like similar to
wernerotten
#17 eplaksienko
eplaksienko
  • 112 posts
Posted 21 February 2013 - 02:53 AM
Ok, it worked from bus #4
Chris, is there some reason?
#18 eplaksienko
eplaksienko
  • 112 posts
Posted 19 March 2013 - 03:32 PM
NGO with SB doesn't work independently on it's own power supply, Each time to start the app I have to connect to computer and load program from VS C#
#19 Jack Chidley
Jack Chidley
  • 99 posts
Posted 25 March 2013 - 04:51 PM
That was weird.  I had issues deploying the updated firmware to the shieldbase.  I am using a Windows 8 machine, VS 2013, net framework 4.3, Go Firmware 4.2.2.1.
Tried several times to Debug the application but it would not connect to the Go over USB, kept doing iterations to connect.  In frustration, I then just deployed the solution, which worked ok.  Then I started debugging and it worked fine.
#20 TinkeringTurtle
TinkeringTurtle
  • 55 posts
Posted 15 September 2013 - 10:41 PM
I had the same issue where I had to flash the base from port 4 instead of port 5 as well for whatever reason.
When will the shield base be moving to SPI so the extra three ports aren't wasted?
