Posted 25 January 2014 - 09:58 PM
- Giuliano likes this
Posted 25 January 2014 - 10:42 PM
- Stari likes this
Good work. But, look at my work. Netduino can communicate with PC, Android, WiFly. So you can build home automation. Netduino can also send mail, if you wish, mesaure temperature,.....
Posted 25 January 2014 - 10:49 PM
Uffe, if you have any problems with sensors of any kind, contact me. I have made automatic for solar power, all from scratch and all controled by NetDuino. And PC. Monitoring water and electricity is not a big problem.
Regardes from Stari
www.zlatnajedra.com
- uffe likes this
Posted 26 January 2014 - 12:52 AM
Posted 26 January 2014 - 05:51 AM
Posted 26 January 2014 - 06:51 AM
Chris, he will be monitoring the water systems for a part of UAE.
The system will work as surveillance for detecting leaks etc sending alarms to people/systems.
But it will also communicate with hardware in the pipelines to distribute water in case of fire for example.
I think he experiments with other units like old WIN CE, but those are expensive and I think NetDuino would be better
Uffe
Netduino is really funny, and awesome for prototyping, home and hobby. However, whereas you need reliability, unfortunately it misses of many important parts.
Some of them:
- a serious watchdog system;
- ability to control/rescue the board (e.g. firmware/software) remotely;
- unpredictable behavior when the RAM is low (and there's no way to predict, unless under-use it as much as possible);
- misses a minimal OS, which would be very useful for running diagnostic/safety processes;
- several bugs on both the NETMF and the hardware drivers porting;
- the board itself isn't enough for a professional/certified project, and needs several other "surrounding" section.
Win CE (or Linux) together with a pretty larger hardware aren't a waste of money: the reasons behind such a systems are far from being "inflated".
That said, I still would recommend a Netduino as invaluable for home/hobby projects, but I won't sell any mission-critical system relying on that board. Just to be clear, I wouldn't rely even on a normal PC for such a system: PCs are typically less reliable than any *duino!
Good luck, anyway!
Posted 26 January 2014 - 11:11 AM
Thanks for your feedback Mario!
Good to know everybodys opinion and experiance with these things.
To be honest I do not care how he implements his solution. I think NetDuino, Arduino etc are cool things and rather use them over unsupported and old WIN CE.
I have already written clients for him on WIN CE, Arduino and now NetDuino. So it is really up to the guys implementing it to choose the most suitable solution. Our main concern is to help him communicate with our platform (XSockets.NET).
Thanks again for your feedback!
Posted 26 January 2014 - 11:29 AM
i will share photos. But code is in development phase, as you can see. Some things must be done and fixed. Just now i'm bussy on other things, so ....
Stari
Posted 26 January 2014 - 11:31 AM
Mario, i agree 100%.
Posted 26 January 2014 - 07:39 PM
Posted 26 January 2014 - 08:29 PM
Maybe a bit of topic but how does the AGENT processor compare to the Netduino GO ?
Would it be beneficial to have that processor on a GO module?
As you already have experience as a standalone type board in the watch?
RTC/Ethernet/IO functionality kind of Nwazet module?
I am just tossing some ideas here nothing concrete.
Cheers Olaf/Beastyboy
Van SchOten Ict Diensten en Services
http://www.voids.nl
Posted 26 January 2014 - 10:43 PM
Posted 27 January 2014 - 06:02 PM
Hi all.
Thanks for the feedback Mario and Chris.
They will continue with WIN CE instead of using NetDuino.
Personally I will continue to play around with the dunio and avoid WIN CE
Uffe
- Mario Vernari likes this
Also tagged with one or more of these keywords: Publish, subscribe, iot, sockets, real time
General →
General Discussion →
Azure Certified for IoT?Started by Dan T, 14 Oct 2015 ![]() |
Technical Previews →
Netduino.IP Technical Preview →
Network stops working on the hour or one minute afterStarted by NameOfTheDragon, 14 Jul 2015 ![]() |
Hardware →
How do I read a network stream ?Started by bgreer5050, 22 Apr 2015 ![]() |
General →
Microsoft Azure IoT ContestStarted by Mario Vernari, 28 Jan 2015 ![]() |
Hardware →
POST request to Twitter with Netduino Plus 2Started by ioexception, 20 Dec 2014 ![]() |
