Azure Certified for IoT?
IoT Azure Certified for IoT
#1 Dan T
Dan T
  • 91 posts
  • LocationBoston (Greater)
Posted 14 October 2015 - 11:05 PM
Is Secret Labs participating in the Microsoft Azure Certified for IoT program?
I don't see you or the Netduino listed.
Why not?  Seems like you should have been first in line.
- Dan (not the other Dan)
P.S. Getting back into Netduino after an absence. The Netduino 3 Wi-Fi is very nice.
#2 Dan T
Dan T
  • 91 posts
Posted 14 October 2015 - 11:13 PM
Found a related post by KiwiDev: Netduino 3 Wifi Azure Event Hub Client
#3 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 20 October 2015 - 09:23 AM
Hi Dan,
I have a couple of blog posts about Netduino 3 Wifi + Azure Event Hubs for Telemetry on my blog. Last time I checked a possible certificate validation issue means that the HTTPS RESTful API approach doesn't work. (Will go back and check this)
I currently use AMQPNetLite or Azure SB Lite (I have sample code for AMQPNetLite on my blog)
I have another series of Azure IoT posts in the pipeline - just need some time to write them. I have another Azure EventHub gateway which queues messages on the MicroSD card for increased robustness and a version which uses Azure SB Lite and supports EventHubs for telemetry and ServiceBus queues for commands.
Would be good if the Netduino 3 wifi could get certified
@KiwiBryn
blog.devmobile.co.nz
#4 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 21 October 2015 - 12:00 PM
I already wrote about this lack on my following blog post ...
https://paolopatiern...s-finally-here/
Today there isn't an official IoT Hub client for .Net Micro Framework and the current C# based can't work as is because it uses Task and async/await programming model a lot. Other reason is that the current client uses a closed source AMQP library that can't work on .Net MF instead of the AMQP .Net Lite.
For the above reasons a board can't be certified if they don't have a client for testing.
My intention is to develop a new library or porting the current C# based that uses the AMQP .Net Lite for the underlying protocol. I'm already able to access IoT Hub using it but it's useful to have a client with same APIs as official one.
However, there is a pull request for an HTTP based client on GitHub : https://github.com/A...ot-sdks/pull/38
Paolo Patierno
Azure Advisor
Twitter : @ppatierno
Linkedin : paolopatierno
Blog : DevExperience
Blog : Embedded101
Also tagged with one or more of these keywords: IoT, Azure, Certified for IoT
