POST request to Twitter with Netduino Plus 2 - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
sockets c# twitter-api
1 reply to this topic
#1 ioexception
ioexception
  • 4 posts
Posted 20 December 2014 - 06:25 PM
string oauth_nonce = Utility.RandomString(32);
        string oauth_timestamp = Utility.Timestamp.ToString();
        string oauth_signature = null;
        string encodedTweet = HttpUtility.UrlEncode(tweet);
        string signingKey = HttpUtility.UrlEncode(ConsumerSecret) + "&" + HttpUtility.UrlEncode(AccessTokenSecret);
        string requestLine = "POST https://api.twitter.com/1.1/statuses/update.json HTTP/1.1";
        string requestBody = "status=" + encodedTweet;
        string paramsString = "oauth_consumer_key=" + HttpUtility.UrlEncode(ConsumerKey) +
                                "&oauth_nonce=" + HttpUtility.UrlEncode(oauth_nonce) +
                                "&oauth_signature_method=" + HttpUtility.UrlEncode("HMAC-SHA1") +
                                "&oauth_timestamp=" + oauth_timestamp +
                                "&oauth_token=" + HttpUtility.UrlEncode(AccessToken) +
                                "&oauth_version=" + HttpUtility.UrlEncode("1.0") +
                                "&" + requestBody;
        string signatureBase = "POST&" + HttpUtility.UrlEncode("https://api.twitter.com/1.1/statuses/update.json") +
                                "&" + HttpUtility.UrlEncode(paramsString);
        byte[] signatureBytes = Sha.ComputeHMACSHA1(Encoding.UTF8.GetBytes(signingKey),
            Encoding.UTF8.GetBytes(signatureBase));
        oauth_signature = HttpUtility.ConvertToBase64String(signatureBytes);
        byte[] requestBodyBytes = Encoding.UTF8.GetBytes(requestBody);
        string otherHeaders = "Host: api.twitter.com" + CRLF +
                                "Connection: Close" + CRLF +
                                "Accept: */*" + CRLF +
                                "User-Agent: Tuitduino v0.1" + CRLF +
                                "Content-Type: application/x-www-form-urlencoded" + CRLF +
                                "Content-Length: " + requestBodyBytes.Length;
        string authorization = "Authorization: OAuth oauth_consumer_key=\"" + HttpUtility.UrlEncode(ConsumerKey) + "\", " +
                                "oauth_nonce=\"" + HttpUtility.UrlEncode(oauth_nonce) + "\", " +
                                "oauth_signature=\"" + HttpUtility.UrlEncode(oauth_signature) + "\", " +
                                "oauth_signature_method=\"HMAC-SHA1\", " +
                                "oauth_timestamp=\"" + oauth_timestamp + "\", " +
                                "oauth_token=\"" + HttpUtility.UrlEncode(AccessToken) + "\", " +
                                "oauth_version=\"1.0\"";
        string fullRequest = requestLine + CRLF + otherHeaders + CRLF + authorization + CRLF + CRLF + requestBody;
        byte[] requestBytes = Encoding.UTF8.GetBytes(fullRequest);
        using (var socket = Network.Connect())
            socket.Send(requestBytes, requestBytes.Length, 0);
Hi guys, I'm new to netduino and I'm trying to send a POSTrequest to update an status to Twitter API, at this moment I generate the request and send it using raw sockets but it always return 403 Authentication Required, but when I grab the same request and send it vía Fiddler everything goes OK. Can any of you tell me what is wrong? I'm thinking that it might has something to do with indicating the end of the body message.  Here is my code:
#2 TechnoGuy
TechnoGuy
  • 51 posts
  • LocationCanada
Posted 13 October 2015 - 12:02 PM
I came across this article, which seems relevant to what you're trying to do:  http://mattisenhower...6/microtweet-2/
  • In the article he talks about how Twitter disabled their v1.0 API and started enforcing the use of SSL connections
See also comments he makes here:  http://mattisenhower...tduino-3-wi-fi/
  • He talks about how the Netduino 3 WiFi is "the first Netduino to support SSL out of the box"
I don't know what one would have to do to retrofit SSL to a Netduino Plus 2 or even if it's possible.  Perhaps other people can comment on that...
- Ian
My Current Dev Boards:
  • 3 x Netduino Plus 2
  • 1 x Netduino 3 WiFi
