Versions! VS2012 with Netduino Plus 1
VS2012
11 replies to this topic
#1 seascan
seascan
  • 88 posts
Posted 13 January 2014 - 11:00 PM
Hi All.  It has been a long time since I have been on the forum.  I really like the spec on the Plus 2 but, for now I am using my dusty old Plus 1.
I have recently migrated to a new laptop running windows 8.1.  I have installed VS2012.  For the last few days I have been trying to breathe life back into my Plus 1 and have gotten a lot accomplished EXCEPT I can't ping it (Ethernet not MFDeploy).
I have installed the .NET Microframework V4.3 and Secret Labs Netduino SDK V4.3.
I was able to change my IP Address (192.168.1.100) and my default gateway (192.168.0.1) but, I am unable to ping the device.  The two green and one amber leds on the Netduino are flashing like it is seeing network traffic.
Any ideas why I can't ping it?
Thank you!
Terry
#2 MrSmoofy
MrSmoofy
  • 47 posts
  • LocationOdessa, FL
Posted 13 January 2014 - 11:06 PM
Unless it's a typo or you have some customized network your gateway should probably be 192.168.1.1
#3 seascan
seascan
  • 88 posts
Posted 13 January 2014 - 11:22 PM
I went ahead and changed it to 192.168.1.1 and had the same issue.
I ran ipconfig on my laptop and it showed the default gateway as 192.168.0.1 -- no custom setup.
#4 MrSmoofy
MrSmoofy
  • 47 posts
Posted 13 January 2014 - 11:25 PM
What does it show for your laptop's IP address?
#5 seascan
seascan
  • 88 posts
Posted 13 January 2014 - 11:37 PM
My laptop is: 192.168.0.102
#6 MrSmoofy
MrSmoofy
  • 47 posts
Posted 13 January 2014 - 11:52 PM
Ahh ok then the IP you gave the netdunio is wrong and should be 192.168.0.100
#7 seascan
seascan
  • 88 posts
Posted 13 January 2014 - 11:58 PM
Whoo hoo -- Thanks for that!  It worked when I plugged it into my router.
If I plug directly to the PC do a I need a crossover cable?
Thanks!!
#8 MrSmoofy
MrSmoofy
  • 47 posts
Posted 14 January 2014 - 12:00 AM
Ahh ok didn't realize you had plugged it directly into the PC.  Yes I believe if you want to connect it directly to your PC you would need a cross over cable.
#9 seascan
seascan
  • 88 posts
Posted 14 January 2014 - 12:08 AM
This is a bit off topic but, do you happen to know if I can make this wireless?  I was thinking of buying a small wireless access point and connecting this to the netduino ethernet port.  If I did this, do you think I would be able to then "see" my netduino on my network wirelessly?
#10 MrSmoofy
MrSmoofy
  • 47 posts
Posted 14 January 2014 - 12:13 AM
My guess is your current router is not a wireless router?
You could get a access point and plug the netdunio into it and then connect to it with your computer to the wireless point as long as your computer has a wireless network card.
You could also get a wireless ethernet board for the netdunio to make it's wireless too.
#11 seascan
seascan
  • 88 posts
Posted 14 January 2014 - 12:41 AM
Thank you for all the help.
I do have a wireless router for my house.  My laptop is wirelessly (is that a word?) connected to it.  I would like to be able to communicate with my netduino without it being wired to either the main router or my laptop.  My thought was to get a small, cheap travel router and connect it to the netduino then that router would communicate with my main router...  does that make sense?
#12 MrSmoofy
MrSmoofy
  • 47 posts
Posted 14 January 2014 - 12:47 AM
Yes I understand and what your attempting won't work.  Wireless Routers typically do not talk to each other.
There is this option http://forums.netdui...hernet-adapter/ which is like adding a wireless network card to your netdunio using it's ethernet port.
Which is basically a ethernet-wifi bridge
The other option is a wifi shield for your netdunio as found here http://forums.netdui...6-wifi-shields/
