I've recently acquired two Netduino Plus 2 boards, have updated them to 4.3.1 as well as having the latest .NETMF framework installed.
My problem is that the VS2012 debugger will not attach to either of my units. Any combination of restarting VS2012, unplugging the devices, rebooting the PC, etc.. etc.. etc... yields no change in the debugger's ability to attach.
See below for my "blinky" code as well as the output from VS2012 when attempting to connect to the devices.
Am I missing something??? As a result of this issue, I have two bricks on my desk
Any help, insight is very much appreciated.
D.
using System.Net;
using System.Net.Sockets;
namespace Blinky
InputPort button = new InputPort(Pins.ONBOARD_BTN, false, Port.ResistorMode.Disabled);
if (button.Read() == true)
led.Write(true);
else
led.Write(false);
[Output]
Looking for a device on transport 'USB'
Starting device deployment...
Iteration 0
Opening port \\?\USB#VID_22B1&PID_1000#000000000000#{09343630-a794-10ef-334f-82ea332c49f3}\Operations
Attaching debugger engine...
... debugger engine attached!
Querying device assemblies...
Found Assembly mscorlib 4.3.1.0
Found Assembly Microsoft.SPOT.Native 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware 4.3.1.0
Found Assembly Microsoft.SPOT.Net 4.3.1.0
Found Assembly System 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.SerialPort 4.3.1.0
Found Assembly Microsoft.SPOT.IO 4.3.1.0
Found Assembly System.IO 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.PWM 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.Usb 4.3.1.0
Found Assembly SecretLabs.NETMF.Diagnostics 4.3.1.0
Found Assembly SecretLabs.NETMF.Hardware.Netduino 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.OneWire 4.3.1.0
Found Assembly Microsoft.SPOT.Time 4.3.1.0
Adding pe file H:\Source Code\NetDuinoPlus2\Blinky\Blinky\bin\Debug\le\Blinky.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.hardware.pe to deployment bundle
Attempting deployment...
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 680 bytes
Assemblies successfully deployed to device.
Restarting interpreter...
Attaching to device...
Deployment error: failed to (re)connect debugger engine to debugging target.
The debugging target and the debugger engine failed to initialize because of unspecified device errors.
The debugger engine thread has terminated unexpectedly with error 'Debugger engine could not attach to debugging target.'.
[/Output]
