How to power netduino without USB?
usb power power supply car battery battery
24 replies to this topic
#1 NeonMika / Markus VV.
  • 209 posts
  • LocationUpper Austria
Posted 21 February 2013 - 06:33 PM
Hey guys!
I know to electronic guys this might sound a silly question, but:
What is a good way to power my N+ when I don't want to use the USB-way?
I thought about a unused car battery but a friend of mine told me I shouldn't use it. I though of using it with a 9 Volt voltage regulator (7809).
How much risk is there in going that way? A car battery has 12V and as far as I know even touching both poles shouldn't harm me because of my high body resistance.
Don't care how easy this sounds to most of you, I better ask before hurting me or my N+ :P
Greets, Markus
NeonMika.Webserver
> Browse the SD on your N+ directly in the browser and d
own - and upload files
If you need help with NeonMika.Webserver, please just leave a note in the thread and/or contact me via Skype :)
#2 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 21 February 2013 - 06:40 PM
i suggest not using a linear regulator for a car battery (you sure its 12v and not 24v ?)
linear regulators are inefficient and make a lot of heat, while swichting regulators are way more effiecent and
dont need cooling (at least for around 10 watts)
the cheap lm2577 regulators from ebay work great for that.
there are also some for more power (but 10 watts is a lot!! thats 2amp @ 5 volt)
//edit 2577 is step up, sry, i meant LM2596
#3 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 21 February 2013 - 07:26 PM
Hey Markus,
Are you trying to power it with out the board being plugged into a USB or Wall transformer (meaning battery powered)?  How long does it need to run before new batteries or a re-charge?
#4 dougY
dougY
  • 19 posts
Posted 21 February 2013 - 11:43 PM
make sure you put a fuse in line from the car battery to your power supply.
probably another fuse or a PTC in line from the power supply to the rest of your circuitry outside the netduino if splitting the supply between them.
#5 Mario Vernari
Posted 22 February 2013 - 04:54 AM
Markus, I done the same for my Invaders game, which requires 600+ mA at 5VDC. I used a LM7805 from a 9VDC source.
http://www.tinyclr.i...r-netduino.aspx
If you take a car battery, which is rated for 12 VDC, and add it a LM7809 (or LM7808), the first questions you have to answer yourself is: how much current shall the regulator draw?
As in my case, the drop between the input and the output is 4V (9-5=4V), thus the "wasted" power is roughly 2.5W =4*0.6
Since any LM78xx has the case connected to the ground, I simply screwed the regulator to a piece of metal. The result is that the heating is almost irrelevant: I don't think it reaches 40'C.
Of sure I would add a good fuse BEFORE the regulator, as dougY said.
The regulator has several kinds of protections (thermal, short, current, etc), but if you short accidentally the battery you can have serious troubles, such as wires melting, up to battery explosion (when gets too hot).
Finally a note about the regulators: is it better a linear one or a switching one?
I believe there's a bit of confusion around this theme. It's *true* that a linear regulator is based on the heat dissipation, thus gets hot easier than a switching one. But it's also true, that a switching regulator must be designed and built very well, because it leads a *lot* of noise, when not enough filtered.
Back to my circuit, I tried two very common 5VDC adapters: one is used for a cell-phone and another for another small appliance. With none of them the circuit was working fine: the logic got crazy, the LCD displayed scrambled characters and anything seemed working. That's because I wired the adapter's output directly to the circuit, without any capacitor, inductor or else. Once I tested with the scope the "cleanness" of the +5VDC rail, it was far from being straight: lot of noise and spikes.
As soon I switched to the LM7805 everything started to working perfectly: no any error, and the +5V rail is still perfectly straight.
I wouldn't feel the linear regulators as kind of "evil".
I am just looking for a good laboratory power supply and I really want a linear one! Keep out from switching if you target experiments!
Hope it helps.
#6 NeonMika / Markus VV.
  • 209 posts
Posted 22 February 2013 - 08:53 AM
Mario, thank you very much for the explaination!
My question is not about a specific topic, I just wanted to know about it.
So, my battery has 12VDC, the drop to 9V would be 3V...
Now to the fuse: I've never used a fuse except for my car or the fuses you use for the "house electronic" (no word for that now :P)
Is it possible to use a normal car fuse? And they also have different Ampere-values. I think a 2-Ampere one should be right (also thinking of something like 600 mA draw normally)
Thanks for your experience-sharing about linear and switching Regulators. I already have a 7809 at home (bought it just to play around, like everything I have xD)
@Dave: Yes, I mean that I want to power it only with battery without USB.
Also, another question: Are there some cheap "wall transformers" that give me 9V to directly plug in the N+? I'm sorry, I'm still tired from going out yesterday and I don't know how the "round power connector" on the netduino is called :P
Greets, Markus
NeonMika.Webserver
#7 Mario Vernari
Posted 22 February 2013 - 10:11 AM
The LM7809 is rated with 2V as a minimum drop across input and output, thus there's no problem at all.
http://www.fairchild...s/LM/LM7805.pdf
The 2A fuse would be fine, but there are two kinds of fuses: the normal one and the delayed. The second one is best suited whereas a short current peak (above the nominal value) is normal: for instance a motor or even a car lamp. However, I wouldn't use a "delayed" fuse for the Netduino, because it has to react (i.e. melt) sooner and it doesn't have reasons for current peaks.
Markus, just a note about the car battery.
I mean to use it as "off from the car", not during the car is running or -even worse- when the ignitor is on. In such a condition the battery voltage is somewhat a nightmare, with ton of skipes, noise and the voltage can fall even below 6V for a brief.
If you're going to use the Netduino for any "automotive" application, the adapter  must be much more complex.
#8 NeonMika / Markus VV.
  • 209 posts
Posted 22 February 2013 - 10:28 AM
Thats not my plan, but thanks for the advise :P
Ok, so I have to get a "non-delayed fuse".
Ok, and here comes the next question to my mind: Would it be a bad idea to run not only the N+ from my battery, but also other electric loads? Because if I go the car battery way, I would have to possibility to drive for example a servo with 12V or 9V.
Greets
NeonMika.Webserver
#9 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 22 February 2013 - 10:33 AM
its not a bad idea, but you have to be carefull.
last few days 2 duinos got fried of beein not carefully enough with 12v. :(
i suggest opto-isolating the pins from netduino to the 12v stuff, not just a transistor/mosfet.
#10 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 22 February 2013 - 11:46 AM
The reason I asked about how long you want it to run before recharge is that I am using a 2700mAh LiPoly Battery with a Lipo Charger and a Booster from Adafruit and Sparkfun.  I can run Pandora's Box which has 6 sensors as well as a back lit LCD screen for 12 hours before recharge.  It's one idea as long as you don't have to power any motors, solenoids and the like.
#11 NeonMika / Markus VV.
  • 209 posts
Posted 22 February 2013 - 12:33 PM
I thought about the car battery because it delivers 12V, so I can do both, power other things AND the N+.
What do you mean with "Booster"?
Opto-Isolating sounds good, I have to look into it, I have nothing at home for this =)
Greets
NeonMika.Webserver
#12 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 22 February 2013 - 12:39 PM
Greets
LiPoly Batteries are only 3.7v so they are not enough to power a ND.  The booster takes the 3.7 and turns it into 5v for the ND.  https://www.sparkfun.com/products/8290
#13 NeonMika / Markus VV.
  • 209 posts
Posted 22 February 2013 - 12:43 PM
There is something like that? The beauty of technic :D
But are there any "cons" on it, so does it draw more current, does it get hot or something like that?
Greets, Markus
NeonMika.Webserver
#14 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 22 February 2013 - 12:49 PM
Depending upon the connection method I'd consider a diode between the battery and the regulator just in case the battery is connected the wrong way.
#15 NeonMika / Markus VV.
  • 209 posts
Posted 22 February 2013 - 12:54 PM
Battery (+) -> Diode -> Fuse -> Regulator -> Netduino (Vin)
Battery (-) -> Netduino (GND)
Would this be your recommended wireing?
Greets
NeonMika.Webserver
#16 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 22 February 2013 - 01:11 PM
Greets, Markus
Yes, Current is a concern.  Max of 300ma.  The first prototype of Pandora's Box had 2 additional sensors and I did melt the Step-up (Booster).  Now with the setup I am running it doesn't get hot at all.
#17 Nevyn
Nevyn
  • 1072 posts
Posted 22 February 2013 - 01:26 PM
There is a post on Hackaday which talks about building a USB charging station which takes 12V as it's input.   The original authors blog post can be found here.
Thought this might be interesting to you.
regards,
#18 Nevyn
Nevyn
  • 1072 posts
Posted 22 February 2013 - 01:29 PM
I'd probably put the fuse before the diode.
#19 NeonMika / Markus VV.
  • 209 posts
Posted 22 February 2013 - 01:55 PM
Doesn't the N+ alone consume about 200mA or something like that?
I've no idea ;)
And Mark, thanks for the post, I will have a look at it.
Greets, Markus
NeonMika.Webserver
#20 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 22 February 2013 - 02:02 PM
I've no idea ;)
Greets, Markus
I think it's closer to 100-125ma.  I haven't run a full test on the system to see but this thing has run 100s of hours on the battery with no melt downs and no sensor failures due to power issues.
Also tagged with one or more of these keywords: usb, power, power supply, car battery, battery
