NeonMika.Webserver
webserver web server neonmika internet web server http sd xml json
213 replies to this topic
#1 NeonMika / Markus VV.
  • 209 posts
  • LocationUpper Austria
Posted 07 November 2011 - 04:42 PM
NeonMika.Webserver @ http://neonmikawebserver.codeplex.com/
Introducing
Hey guys,
NeonMika.Webserver is an pre-setup and easy to extend webserver. With minimal (to no) code you can achieve great results controlling your Netduino+, accessing and uploading files and more!
It's supports:
- SD card access
- Controlling your Netduino using existing methods like setPWM or setDigitalPinState (see full list below)
- Adding your own webservice-like methods so you can expand NeonMika.Webserver to your own needs for every project.
How easy is it?
Server WebServer = new Server PinManagement.OnboardLED, 80, false, "192.168.0.200", "255.255.255.0", "192.168.0.1", "NETDUINOPLUS");
The parameter for setup are: The OnboardLED, Port, DHCPenable, ipAdress, subnetMask, gateway, name.
You don't need anything more to run it!
At http://neonmikawebse...m/documentation you can find a complete documentation on how to set up the server and how to expand it.
What methods are already implemented?
Here is a list with all pre-coded webmethods you can use within your browser or any other application to communicate with your Netduino:
echo (Returns the submitted value)
-> netduinoplus/echo?value=[a-Z]
switchDigitalPin (Switches the selected pin from true to false and vis-a-vis)
-> netduinoplus/switchDigitalPin?pin=[0-13]
setDigitalPin (Set the selected digital pin to the selected state)
-> netduinoplus/setDigitalPin?pin=[0-13]&state=[true|false]
pwm (Set the PWM of the pin to the submitted period & duration
-> netduinoplus/pwm?pin=[5|6|9|10]&period=[int]&duration=[int]
getAnalogPinValue (Return the value of the selected analog pin)
-> netduinoplus/getAnalogPinValue?pin=[0-5]
getDigitalPinState (Returns your selected pin's state (on / off))
-> netduinoplus/getDigitalPinState?pin=[0-13]
getAllAnalogPinValues (Return the value for each analog pin)
-> netduinoplus/getAllAnalogPinValues
getDigitalPinState (Returns the state for each digital pin)
-> netduinoplus/getAllDigitalPinStates
getAllPWMValues (Returns the values for all PWM ports)
-> netduinoplus/getAllPWMValues
fileUpload (Uploads a file to the path on the SD card via POST. You have to write the file-data (bytes) into the POST body)
-> netduinoplus/upload?path=[a-Z]
AND FOR SURE:
File and directory response
Just type in netduinoplus/[pathtomyfile] and you can view / download your file. If the given path is a directory, a directory view will be returned
Some examples:
Example commands (can be executed with browser):
Show file directory:
Access file:
Download & Documentation:
Project & Videos
Controlling your Netduino+ with Android phone
Thanks to skarphedinnos for this great video about controlling Pins and PWM with NeonMika.Webserver & Android!
http://www.youtube.c...h?v=Q5T7TQsOf-w
Home brewery
Thanks to Coding Smackdown for using NeonMika.Webserver in his awesome beer brewing Project!
http://diybrewery.com/
N+2 aquarium controller
Thanks to H07R0D!
http://forums.netdui...roller/?p=34544
I appreciate every kind of response. I want this to help the community, so I hope the communty will help me to get this project better and better
Thanks and greets,
Markus
Changelog:
- Index page(8.11.2011)
- Screenshot ofecho, switchPin and index page (8.11.2011)
- JSON support(30.11.11)
- PWM(30.11.11)
- getAnalogPinValue and getDigitalPinState (30.11.2011)
- Examples(30.11.2011)
- FileResponseimproved (15.3.2012)
- Changed indexpage (15.3.2012)
- Nested XMLsupport (28.4.2012)
- Example method for nested XML -> see MultipeXML(28.4.2012)
- Code cleanup(28.4.2012)
- POST working!(22.11.2012)
- File upload(22.11.2012)
- Better XML(22.11.2012)
- Choosing between DHCP and fixed IP (22.11.2012)
- Return filelist from directory (Directory view) (22.11.2012)
- Some changes to the code (Somewhere here between :P)
- Videos (13.3.2013)
- Nameservice (28.3.2013)
- Server code refactor and restructure (28.3.2013)
- Index page (28.3.2013)
- New webserver methods (28.3.2013)
--- GetAllPWM (Returns duration and period for all PWM pins)
--- GetAllDigitalPinStates (Returns the state for all digital pins)
--- GetAllAnalogPinValues (Returns the value for all analog pins)
- NeonMika.Webserver.ClientLibrary Version 0.1 (28.3.2013)
- NeonMika.Webserver V1.2
--- Fixed POST file upload
--- Fixed SD card view
Edited by NeonMika / Markus VV., 30 January 2014 - 05:47 PM.
NeonMika.Webserver
> Browse the SD on your N+ directly in the browser and d
own - and upload files
If you need help with NeonMika.Webserver, please just leave a note in the thread and/or contact me via Skype :)
Posted 07 November 2011 - 05:10 PM
Oh wow, Markus. That's pretty cool. Do you have a sample "site" for it already? Can you show off screenshots/photos so people can see what NeonMika.Webserver can do? Chris
#3 NeonMika / Markus VV.
  • 209 posts
Posted 07 November 2011 - 05:55 PM
I will sit down tonight @ my girlfriends place to write a little index.html
But i don't have a SD card atm, so i will write a sample "Complex response" so people can see how this is done. :)
Tomorrow i will take some screenshots and a little video. So stay tuned for more visual info tomorrow ;)
Greets, Markus
NeonMika.Webserver
#4 NeonMika / Markus VV.
  • 209 posts
Posted 08 November 2011 - 05:23 PM
I added some screenshots, did'nt have time for the video, have to go to work #2 now... Probalby in the night, otherwise tomorrow =) But i hope that the screenshots help to understand how to use it :) Greets, Markus
NeonMika.Webserver
#5 Coding Smackdown
Coding Smackdown
  • 78 posts
  • LocationLewisville, TX USA
Posted 27 November 2011 - 03:51 AM
Markus, I've pulled down your code and have been trying to use it for an interface to a temperature logger that I'm building. The concept really fits into what I need, however I've noticed that after running for a couple of minutes it seems to be going off into nowhere and never answers. I'm running under the .NetMF 4.2 RC3 firmware, so I'm not sure if it is the newer firmware or maybe the code. Have you run into anything like this or does it run without issue for you? Just trying to figure out where I should be spending my time trouble shooting. Thanks
#6 NeonMika / Markus VV.
  • 209 posts
Posted 27 November 2011 - 08:51 AM
Markus,
Are you running in debug mode?
There you can check if incoming requests get ignored...
Probably you get a outofmemory-exception?
I sometimes had the problem that it just worked fine for a time and then it stopped receiving requests, i will look into that as soon as i have time :)
It mustbe something in the Server-class' Listening loop...
Probably you can find an error there (about 20 lines of code)...
Greets
NeonMika.Webserver
#7 Coding Smackdown
Coding Smackdown
  • 78 posts
Posted 27 November 2011 - 03:36 PM
Greets
Markus,
It is not throwing an exception of any kind, but I think you are right with it running out of resources. I was playing with the server listening loop and did make some changes and now it runs without issue. Let me spend some time comparing my changes to the original code and I'll post an issue to the codeplex page.
I also made some changes to the Handle Request method and changed from an array list to a hashtable to speed up request processing. I'll also post those changes as well.
Jim Lavin
#8 Coding Smackdown
Coding Smackdown
  • 78 posts
Posted 27 November 2011 - 04:52 PM
Markus, I've posted the differences out on codeplex for you. Hopefully they'll be of help. Cheers, Jim Lavin
#9 NeonMika / Markus VV.
  • 209 posts
Posted 27 November 2011 - 07:56 PM
Markus,
Cheers,
Jim Lavin
Thank you Jim!
Doing some error handling, good idea. Next time I'll consider it more :)
So did you find out why exactly the code was stopping working? Or are you also not sure and just do some "workaround" with the errorhandling block?
And thank you for the tip with the using for the ClientSocket and the hashtable, i will include them in my next version and will upload the new code in the next few days :)
Thanks for you help.
Greets, Markus
NeonMika.Webserver
#10 Coding Smackdown
Coding Smackdown
  • 78 posts
Posted 28 November 2011 - 01:04 AM
I think it had to do with the client socket not being closed after the request.
#11 NeonMika / Markus VV.
  • 209 posts
Posted 28 November 2011 - 08:50 AM
You are so right, I think that's the point! It's great to have people like you around that help to find this little problems you spend hours on and don't find them (even if it is just one line :P) Greets, Markus PS: I just updated the project main page and the thread start post. The next step will be to build a more "beautiful" index page you can use as a "control center". The last days I read through w3schools.com on HTML, HTML5, CSS and a bit Javascript. I am excited how my first "website" will look like :P
NeonMika.Webserver
#12 AJB2K3
AJB2K3
  • 46 posts
Posted 29 November 2011 - 07:36 AM
This looks like it could be a very noobe friendly server but I have a few questions. 1, Is there a plan to add PWM control to the server to dim the outputs? 2, Would it be possible to add a web page side method that alows you to control which input is tied to which output i.e:input 1, analogue, :output 1,PWM Sorry I'm a noob to programming and not getting much time to learn how to code things yet.
"Maybe it's because you're a crap programmer"
#13 NeonMika / Markus VV.
  • 209 posts
Posted 29 November 2011 - 09:32 AM
Thanks for your idea sharing.
PWM gets on the to-do list. But it's not that difficult at all. This is why i wanted to build this server extendable. You can have a look at this: http://neonmikawebse...m/documentation
Just build a method in this way:
private void Methodname(RequestReceivedEventArgs e, Hashtable h)
//fill h with your response keys and values
I never worked with PWM, but I think it will look something like this:
private void PWM(RequestReceivedEventArgs e, Hashtable h)
  SecretLabs.NETMF.Hardware.PWM pwm  = new SecretLabs.NETMF.Hardware.PWM(Pins.GPIO_PIN_D5);
  if(e.Request.GetArguments.Contains("pulse")
    int pulse = Convert.ToInt32(e.Request.GetArgumenst["pulse"];
    pwm.SetPulse(20000, pulse);
    h.Add("newPulse",pulse);
  else
    h.Add("ERROR","No 'pulse'-value transmitted");
Then you have to add this method to your webserver instance:
webserver.AddResponse(new XMLResponse("pwm",new XMLResponseCheck(PWM)));
Just did that out of mind without IDE, this is probably not going to work without changes.
Then you could set your PWM via this URL:
"http://netduinoip:port/pwm?pulse=4000"
Sorry, I'm no native speaker. Could you explane your second question in more detail?
I dont have my netduino at home to work with it today, but i will sit down today to expand the server code (probably i also include pwm)
Tomorrow you can test the new version :)
Greets, Markus
Edited by Markus VV., 29 November 2011 - 11:17 AM.
NeonMika.Webserver
#14 NeonMika / Markus VV.
  • 209 posts
Posted 29 November 2011 - 10:03 AM
Sorry, didn't want to post :P
NeonMika.Webserver
#15 AJB2K3
AJB2K3
  • 46 posts
Posted 29 November 2011 - 12:58 PM
Sorry, times I forget not all clever people are english What I was thinking was eather 2 buttons up and down to alter the value or a slider to adjust the brightness level.
#16 NeonMika / Markus VV.
  • 209 posts
Posted 29 November 2011 - 01:17 PM
That shouldn't be that hard, I'm already in the Javascript learning phase :P
The slider (or buttons) only have to execute the "http://netduinoip:port/pwm?pulse=[INSERT VALUE HERE 0-20000]" command with the wanted value. E.g. 0 is completly off, 20000 is completly on...
Greets, Markus
NeonMika.Webserver
#17 Coding Smackdown
Coding Smackdown
  • 78 posts
Posted 29 November 2011 - 01:22 PM
I'm doing something similar by using jQuery to post data back to the server. First I added additional pin types to the Pin Management class, then I added a couple of new request methods like Markus discussed. I then have web pages that can be returned from the server which contain my user interface which have jQuery methods that send the request back to the server to be processed and return the results. This way I can interact with the Netduino however I wish, I can even use this method to set the time and network settings on the device. You just have to be careful about how much functionality you try to shoehorn into the device since memory is pretty tight. To build my temperature controller complete with logging and history charts I end up with about 30K worth of code when all finished. That included a complete library to send back JSON formatted data. You can do quite a bit.
#18 Coding Smackdown
Coding Smackdown
  • 78 posts
Posted 29 November 2011 - 01:29 PM
Markus, I had to add code to handle the HTM and HTML file types to the extension handler so it would return the proper MIME type. It seems if you request index.html from the server it was always coming back as application/octetstream instead of text/html. I also added a JSON request handler that uses a JSON library to return requests in JSON format. Let me know if you want me to post the code for you to include. Cheers,
#19 NeonMika / Markus VV.
  • 209 posts
Posted 29 November 2011 - 02:05 PM
Forgetting the most important mime type is a little embarrasing :P Yeah it would be great to receive your cs files :) Thanks! Markus
NeonMika.Webserver
#20 NeonMika / Markus VV.
  • 209 posts
Posted 30 November 2011 - 03:50 PM
Wow, now that was some long work:
But I am proud to announce Version 0.2. Now with:
- JSON support
Thanks to Jim aka Coding Smackdown for sending me his code to include JSON support into NeonMika.Webserver
- PWM
Now you can not only send commands to your Netduino like switchPin, now you can also query the actual state of your digital and analog pins.
- Examples
Have a look at the thread opening post. There are now examples how to write xml and json responses and how to set up a simple webserver.
I don't have my Netduino+ at my place today. I will test it tomorrow :)
But I hope everything works fine :P
And again a big thanks at Jim!
Have fun with the new version of NeonMika.Webserver.
Greets, Markus
NeonMika.Webserver
Also tagged with one or more of these keywords: webserver, web server, neonmika, internet, web, server, http, sd, xml, json
