Request For Help In Testing Pot, Button and RGBLed Go Modules
C#
Best Answer Chris Walker, 19 January 2013 - 03:01 PM
Hi Denisetoo, Your code should still work. Did you double-check that those modules are plugged into the specified GoPorts (sockets)? What exactly is happening now? What is not working? Also, do any of the GoPort LEDs light up when you start your app? Chris Go to the full post
#1 Denisetoo
Denisetoo
  • 22 posts
Posted 19 January 2013 - 02:48 PM
Hello,
I am attempting to test the potentiometer, button, and RGBLed go modules.  The following code worked until I upgraded to 4.2.2.  Any suggestions are appreciated.
using SecretLabs.NETMF.Hardware.NetduinoGo;
namespace PotGoSocketOnly
        static NetduinoGo.RgbLed led = new NetduinoGo.RgbLed(GoSockets.Socket4);
        static NetduinoGo.Potentiometer pot = new NetduinoGo.Potentiometer(GoSockets.Socket3);
        static NetduinoGo.Button button = new NetduinoGo.Button(GoSockets.Socket2);  // this button will start/stop the flashing
        public static bool currentState = false; // keep track of if the button was pressed to turn it on, or off
            // write your Main code here
            button.ButtonReleased += new NetduinoGo.Button.ButtonEventHandler(button_ButtonReleased);
            //  button.ButtonReleased += new NetduinoGo.Button.ButtonEventHandler(button_ButtonReleased);
            currentState = false; //make sure we start with it off
            while (true) //we're using a device, it will never end
                if (currentState) // see if we should be displaying the LEDs or not
                    led.SetColor((byte)255, (byte)0, (byte)0); // turn on the red LED
                    System.Threading.Thread.Sleep((int)(100 * pot.GetValue()));
                    // pause for a moment based on the potentiometer state
                    led.SetColor((byte)0, (byte)0, (byte)0);
        //button handler
        static void button_ButtonReleased(object sender, bool isPressed)
            currentState = !currentState; //set the state to the opposite of whatever we were before
            Debug.Print("Button Has Been Pushed");
Posted 19 January 2013 - 03:01 PM   Best Answer
#3 Denisetoo
Denisetoo
  • 22 posts
Posted 19 January 2013 - 05:17 PM
It worked the second time I ran it.  Thank you for your speedy response.
