What is need to get started with Netduino?
15 replies to this topic
#1 cliffboss
cliffboss
  • 3 posts
Posted 19 September 2010 - 02:14 AM
Hello all, Besides the board itself what other tools and/ or supplies are need to get started with Netdunio? Being a software dev, with no hardware experience, I think this would be a pretty cool way of learning some new skills :D
#2 hari
hari
  • 131 posts
Posted 19 September 2010 - 02:27 AM
The list is endless. It depends on your interest.
You CAN start coding with just the board because it has a built-in LED and Switch that you can control. You can even start coding WITHOUT the board using an emulator.
But for more fun I'd recommend:
A breadboard and jumper wires, some LEDs with a 470ohm, or 1K resistor for each, breadboard pluggable switches, a 10K potentiometer (you may have to buy a soldering iron for this one because I've never seen a breadboard pluggable potentiometer), and finally two or more r/c servos.
I'm not associated with any of these suppliers, but I've had positive experience with them.
http://www.hobbypart...promisesg9.html
http://www.sparkfun..../categories.php
http://adafruit.com/
If you're in a hurry, you can purchase things at your local Radioshack.
#3 MattW
MattW
  • 23 posts
Posted 19 September 2010 - 06:17 AM
I've been going through the "Complete Beginners Guide to the Arduino" from Earthshine Electonics. It's for the Arduino, so I've had to convert the code from C to C#, but I've had a lot of fun! http://www.earthshin.../6-starter-kits http://www.earthshin...KManualRev4.pdf I've also found Sparkfun's Arduino Inventor's Kit Manual very good... http://www.sparkfun....oducts_id=10057 Little Bird Electronics here in Australia sells the kits without the Anduino - perfect for my situation, but in the end I just went to my local electronics shop and bought the parts as described in both guides...
#4 Ravenheart
Ravenheart
  • 18 posts
  • LocationBulgaria
Posted 19 September 2010 - 07:48 AM
I'd also recommend a soldering iron and a multimeter.
#5 Eric Burdo
Eric Burdo
  • 130 posts
Posted 19 September 2010 - 11:22 AM
I have one... came in this kit here from HiTechnic: http://www.hitechnic...ion&key=NPA1058
That kit is designed to give you solderless breadboard capabilities on the LEGO NXT. Has a nice collection of projects, and I'm replicating them on the Netduino.
~ Eric D. Burdo ~ http://brick-labs.com/
#6 James
James
  • 56 posts
Posted 19 September 2010 - 03:10 PM
This may be overkill, but I bought this kit from a local Fry's and am replicating the build with a Netduino. So far most of the wiring has been the same as the basic stamp that comes with the kit: http://www.parallax....11/Default.aspx
#7 hari
hari
  • 131 posts
Posted 19 September 2010 - 03:59 PM
This may be overkill ...
I was checking price of Boe-bot when I ran into this robot.
Get ready to drool...
THIS is overkill ;-) Comes with 17 servos and can drive up to 35! Wow...
Back in reality - you should share code/video of your experience with boe-bot. Always wanted that, but decided it was too expensive.
#8 cliffboss
cliffboss
  • 3 posts
Posted 23 September 2010 - 01:49 AM
So I am think on ordering some stuff tomorrow :D
What do you guys think of my shopping list?
If I missed anything let me know.
#9 Chris Walker
Posted 23 September 2010 - 02:00 AM
1k Resistor Does the multicolor led need them?
You'll probably need three resistors--one for each of the Red, Green, and Blue elements.
#10 dab
dab
  • 54 posts
  • LocationBellevue, WA, USA
Posted 23 September 2010 - 04:05 AM
1K is probably too high a resistance if you're driving LEDs from the Netduino output pins (3.3v).
Something like 100 ohms is probably more appropriate for Red or Green LEDs. I think Blue LEDs generally have a higher forward voltage, so you may need an even smaller resistor (or maybe no resistor at all). Best bet is to buy a resistor assortment, and save yourself some frustration.
Also, you'll probably want a potentiometer to attach that knob to ;).
If you're just getting started in electronics, I'd highly recommend the Make: Electronics book. It's a great hands-on introduction to basic electronics. It doesn't cover Arduino/Netduino specifically, but it's a good learning guide.
~ David ~
#11 MattW
MattW
  • 23 posts
Posted 23 September 2010 - 04:14 AM
Thanks David for the reference to the Make: Electronics book. Exactly what I'm after!! (now to find someone in Australia that sells them!)....
#12 Chris Seto
Chris Seto
  • 405 posts
Posted 23 September 2010 - 04:33 AM
RE: Resistors: http://www.sparkfun....roducts_id=9258
#13 hari
hari
  • 131 posts
Posted 23 September 2010 - 04:38 AM
I see Potentiometer Knob, but no potentiometer, I hope already have a 10K potentiometer.
Do you have a breadboard already too?
You may want to wait on the Netduino, they're going to announce something this weekend at Maker Faire.
http://forums.netdui...-to-makerfaire/
#14 dab
dab
  • 54 posts
Posted 23 September 2010 - 05:44 AM
You can also get the eBook version for US $27.99.
~ David ~
#15 MattW
MattW
  • 23 posts
Posted 23 September 2010 - 11:20 AM
Thanks mate!!
#16 cliffboss
cliffboss
  • 3 posts
Posted 24 September 2010 - 12:34 AM
No forgot to put the breadboard on the list, I was think on this one Breadboard
I saw the post on the forums about a big announcement so i may wait till Monday.
