I wrote this simple code to send a string to a client, once it attached to my listen:
Posted 11 January 2016 - 04:18 PM I wrote this simple code to send a string to a client, once it attached to my listen:
Module Module1
Dim Listen_Thread As Thread
Dim Client_Thread As Thread
Private Listener As System.Net.Sockets.Socket
Private ClientSocket As System.Net.Sockets.Socket
Private bmsg() As Byte
Sub Main()
' write your code here
Dim Msg As String = "This is a transmission test to check the first message. I hope it arrives safety and quickly .... bye bye !"
Dim sMsg() As Char = Msg.ToCharArray
ReDim bmsg(sMsg.Length - 1)
Dim i As Integer
For i = 1 To sMsg.Length
bMsg(i - 1) = CByte(Microsoft.VisualBasic.Strings.AscW(sMsg(i - 1)))
Next
Listener = New System.Net.Sockets.Socket(System.Net.Sockets.AddressFamily.InterNetwork, System.Net.Sockets.SocketType.Stream, System.Net.Sockets.ProtocolType.Tcp)
Dim ListEndPoint As New System.Net.IPEndPoint(System.Net.IPAddress.Any, 5001)
Listener.Bind(ListEndPoint)
Listener.Listen(1)
Listen_Thread = New Thread(AddressOf listener_thread)
Listen_Thread.Start()
End Sub
Private Sub listener_thread()
While (True)
Try
ClientSocket = Listener.Accept
Debug.Print("Client accepted ")
Client_Thread = New Thread(AddressOf Clienter_thread)
Client_Thread.Start()
Catch ex As System.Net.Sockets.SocketException
Debug.Print("Error, not connected .. : " & ex.Message)
If Not Client_Thread Is Nothing Then
Client_Thread.Abort()
Client_Thread = Nothing
End If
End Try
End While
End Sub
Private Sub Clienter_thread()
While (True)
Dim MessReady As Boolean = False
Thread.Sleep(1000)
Debug.Print("bytes send")
ClientSocket.Send(bmsg)
End While
End Sub
End Module
Then i run and opened HyperTerminal
It works for a while ... then in Hyperterminal i receive a lot of characters and it stop.
You can check simply with Hyperterminal ... i Can't find where is the problem ...
Any Help, please ?
Thanks a lot
Posted 12 January 2016 - 07:48 PM
Here you can find a very good example of a visual basic client-server application on codeplex.
edit: here you can find more examples: https://netduinohelpers.codeplex.com/
Posted 13 January 2016 - 09:06 AM Thanks for reply .... but everyone can give a link .... i don't need a link.
I need a help to understand. Have you tried this code ? There're no problem with this code, indeed it works properly on a PC. I'd want to know why it doesn't work on N3. So ... if someone should want help me .... i need that he tries this code.
Thank you
Posted 14 January 2016 - 07:41 AM
Thank you, but I am not everyone.
I am not a teacher but (without insulting) the code you have written looks like beginners code and so much wrong, so the easiest way to learn yourself .netMF VB you'll need to read and understand examples from other and see the differences.
Posted 14 January 2016 - 09:25 AM
Magically i può the same code on a N2+ and workshop fine ... so there wasn't errors. So ... again ... have you tried or not ?
Also tagged with one or more of these keywords: TCP, Socket.Send
1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | |||||||||||||||||||||||||||
