TCP between two Netduinos 2 plus
TCP
#1 hteml@hotmail.com
hteml@hotmail.com
Posted 28 April 2014 - 04:44 PM
We have 2 Netduinos 2 plus, running the code bellow. The one has the IP 169.168.1.100, and the other has 169.168.1.101.
We get a connection, but we never receive any data. We have tryed making a connection to a windows computer, running a test program. In this scenario both Sever and Client works as expected.
When running the Sever and Client code on the same Netduino, and connecting to itself, everything works.
// ------------------------ Sever ----------------------------------------
            var networkAdapter = NetworkInterface.GetAllNetworkInterfaces()[0];
            networkAdapter.EnableStaticIP("192.168.1.100", "255.255.255.0", "192.168.1.1");
            (new Thread(Sever)).Start();
        private static void Sever()
            Debug.Print("Starting listener");
            try
                _receiveSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
                _receiveSocket.Bind(new IPEndPoint(IPAddress.Any, 4543));
                _receiveSocket.Listen(2);
                    using (Socket commSocket = _receiveSocket.Accept())
                        Debug.Print("Connected");
                        try
                            while (!commSocket.Poll(10, SelectMode.SelectRead)) ;
                            int bytesSent = commSocket.Available;
                            if (bytesSent > 0)
                                byte[] bytes = new byte[bytesSent];
                                int bytesReceived = commSocket.Receive(bytes, bytesSent, SocketFlags.None);
                                if (bytesReceived == bytesSent)
                                    Debug.Print(new string(Encoding.UTF8.GetChars(bytes)));
                        finally
                            commSocket.Close();
            catch (Exception exception)
                Debug.Print("Listen error: " + exception.Message + " stacktrace: " + exception.StackTrace);
// -------------- Client .-------------------------------
            networkAdapter.EnableStaticIP("192.168.1.101", "255.255.255.0", "192.168.1.1");
            (new Thread(Client)).Start();
static void Client()
                using (var send = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp))
                    var destination = new IPEndPoint(IPAddress.Parse("192.168.1.100"), 4543);
                    byte[] buf = Encoding.UTF8.GetBytes("Hello World ");
                    try
                        send.Connect(destination);
                        send.Send(buf, buf.Length, SocketFlags.None);
                    catch(Exception e)
                        Debug.Print("Error");
                    finally
                        send.Close();
                        Debug.Print("Exit");
#2 JoopC
JoopC
  • 148 posts
Posted 28 April 2014 - 05:32 PM
Is the MAC address on the Netduino's correct, I had a same problem after the MAC was filled everything worked well.
#3 hteml@hotmail.com
hteml@hotmail.com
Posted 30 April 2014 - 06:57 AM
Thanks for the reply. We just tested it, and it worked :)
Also tagged with one or more of these keywords: TCP
