Is it possible to connect FTDI to SCL, SDA, SQW, 32K?
FTDI SDA SCL SQW 32K
1 reply to this topic
#1 tridy
tridy
  • 68 posts
  • LocationStockholm, Sweden
Posted 12 July 2015 - 11:20 PM
hi.
I was wondering if it is possible to use FTDI cable to access this module in order to test the functionality via terminal on a PC before attaching it to Netduino?
Attached File  FTDI_RTC.png   210.44KB   0 downloads
Wiring instructions (with Arduino uno r3 for example):
SCL ? A5
SDA ? A4
VCC ? 5V
GND ? GND
it gives 5V and Ground as a start but the rest I am not sure about the other connections. I haven't played with analog inputs before. Is it possible to connect the cable and read/write the data?
Thanks!
#2 tridy
tridy
  • 68 posts
Posted 13 July 2015 - 09:46 AM
I did a bit more research and found ALL IN 1 USB to SPI/I2C/IIC/UART/TTL/ISP serial Adapter on eBay that looks like this:
Attached File  All_in_1_USB.jpg   69.02KB   0 downloads
so, IIC will not work with FTDI cable, as far as I can see,
but this "All in 1" from eBay should work.
Also tagged with one or more of these keywords: FTDI, SDA, SCL, SQW, 32K
