How do I read a network stream ?
Sockets Network
1 reply to this topic
#1 bgreer5050
bgreer5050
  • 28 posts
Posted 22 April 2015 - 04:46 PM
I copied an example of how to use a socket and a stream to send a request to a server below.  It was from Nicky and there is a reference to the link at the end of this post.  How can I read the stream returned from the server in this example ?  What type of conversion can I expect to have to make so the response is human readable ?
public static void InStateToServer(int port)
   IPHostEntry host = Dns.GetHostEntry("192.168.2.231");
   IPEndPoint endPoint = new IPEndPoint(host.AddressList[0], 80);
   using (Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp))
      socket.Connect(endPoint);
      using (NetworkStream ns = new NetworkStream(socket))
         byte[] bytes = System.Text.Encoding.UTF8.GetBytes("GET /decoder_control.cgi?command=" + port + "&user=admin&pwd=abc HTTP/1.1\r\n");
         ns.Write(bytes, 0, bytes.Length);
Code From Nicky
http://forums.netdui...es-a-long-time/
#2 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 23 April 2015 - 09:28 AM
HI,
If your doing an HTTP request it is most probably easier\simpler to use the functionality in System.http.
See bottom of this post for sample code.
http://forums.netdui...https-rest-url/
@KiwiBryn
blog.devmobile.co.nz
