Digital IO interrupt causing USB reset?
USB NETWORK
1 reply to this topic
#1 Fred007
Fred007
  • 25 posts
Posted 05 May 2014 - 04:50 PM
I have a program that communicates over the net via sockets, and uses COM1 to talk to a OneWire bus. I also monitor the digital IO ports for simple circuit monitoring. Using a Netduino Plus 2 with 4.3 firmware, when I open a closed circuit, it will cause the PC to rediscover the Netduino over USB. (i get the unplug and plug in sounds). This causes the network connection to be reset. I have catches all over the code and can't see anywhere in my code where the socket would be closed, but that is what is being reported on the other end.
I also posted a note about very slow debug performance (when you step lines of code) and when I attach the debugger I get the USB reset sounds a couple of times. Things appear to be working, but I wonder about the Netduino driver. This is on a Windows 8.1 Update x64 machine.
Any ideas on why just opening/closing a digital port circuit would cause the connection with the PC to reset?
Thanks.
#2 Fred007
Fred007
  • 25 posts
Posted 06 May 2014 - 03:21 PM
Ok, a hard post to write, but please ignore this. I failed to create a NativeEventHandler and was just assigning the method address. Whoops. Caused all kinds of nasty problems, but not right away. As I saw in another post, please ignore, nothing to see here...
Also tagged with one or more of these keywords: USB, NETWORK
