This firmware requires use of the .NET Micro Framework v4.2 SDK (QFE2) and Netduino 4.2.0.1 SDK.
128KB Flash
60KB+ RAM
1. Visual Basic is now a supported language for .NET MF
2. New core AnalogInput and PWM classes; backwards-compatible classes available via add-on assemblies.
3. New WinUSB drivers (to remedy BSOD issues in 4.2 beta)
4. Garbage collector now fully collects old objects
5. See netmf.codeplex.com for full details of all bugfixes
Users of firmware version 4.2.0.0 RC5 or earlier may update to this new firmware:
1. Erase your Netduino by applying 3V3 power to the gold ERASE pad
a. Detach and reattach your Netduino (power cycle)
2. Flash TinyBooterDecompressor.bin using SAM-BA v2.12+
3. Flash TinyCLR using MFDeploy v4.2+
a. Click "Browse..." and select the TinyCLR files (ER_CONFIG and ER_FLASH).
b. Press "Deploy". It will take a few minutes to update your Netduino.
c. Detach and reattach your Netduino (power cycle)
