Netduino Drivers - Netduino 2 (and Netduino 1) - Netduino Forums
Netduino Drivers
14 replies to this topic
#1 Chris Walker
Posted 21 July 2010 - 09:28 PM
I've attached the Netduino drivers to this post. We support the following operating systems: Windows XP Windows Vista (32-bit and 64-bit) Windows 7 (32-bit and 64-bit) NOTE: these drivers apply to Netduinos running 4.1 firmware. The newer 4.2+ firmware uses integrated drivers which are set up by the Netduino SDK installer.
Edited by Chris Walker, 26 January 2013 - 06:47 PM.
added note about 4.2+ firmware support
#2 hari
hari
  • 131 posts
Posted 29 August 2010 - 12:12 AM
Would you mind quickly summarizing the various software components for us N00bs?
Are these correct?
  • Netduino Drivers - Needed by PC to talk to Netduino board via USB
  • Netduino SDK - Netduino Application template and netduino specific libraries
  • Netduino Firmware - pre-loaded on the netduino board
  • Netduino Application - Visual Studio solution and project containing C# code that us n00bs write.
  • .NET Micro Framework SDK - Microsoft's framework used by all of the above.
Being 100% open source, the source code for all of the above are also available for download.
#3 Chris Walker
Posted 29 August 2010 - 03:55 PM
hari, The one thing that I'd add is that the Netduino SDK includes the Netduino drivers. You do not need to download those separately. Chris
#4 DLA
DLA
Posted 08 December 2012 - 09:01 PM
I downloaded the .zip file. What to I do next? I have win7 system. DLA
#5 Chris Walker
Posted 09 December 2012 - 03:33 PM
Hi DLA,
I have win7 system.
If you open up Device Manager on your computer, you can right-click on the Netduino entry (under USB devices) and select "Update Drivers..." The wizard should guide you from there.
If you get stuck at some specific step, just let us know.
#6 Zbyszek
Zbyszek
  • 4 posts
Posted 25 January 2013 - 02:36 PM
Hello Chris,
I've just unpacked my first Netduino Plus 2 and tried to connect with my laptop running Windows XP. Hardware Wizard made a couple of attempts to install new device driver. First attempt failed. For the second attempt I provieded NetDuinoDrivers (from your zip file). This time I've got a message saying that the driver did not pass "Windows logo testing" and it is not recommended to coninue with its installation. So, I stopped the process. What should I do now?
Zbyszek
#7 Zbyszek
Zbyszek
  • 4 posts
Posted 25 January 2013 - 02:51 PM
Hello Chris,
Its me again,  this time to let you know that I have ignored a couple of "Windows logo testing" warnings and got me Netduino pinging back successfully. Therefore, I should be able to proceed.
Zbyszek
#8 Chris Walker
Posted 26 January 2013 - 06:46 PM
Okay, thanks for the update. Let us know if you run into any other troubles! Chris
#9 zenmanenergy
zenmanenergy
  • 4 posts
Posted 05 March 2013 - 08:08 AM
I am stuck. I have flashed my Netduino using the 3v3 to gold square. Now I can't do any of the next steps to bring it back up.
In the windows XP device manager I have a USB device (my netduino) that has no drivers. I have attempted to install the drivers you've attached, but no luck. When I lselect the folder when I attempt to install the drivers I get a "Cannot install drivers" message.
Without the drivers, the atmel is failing saying it cannot connect.
Any suggestions?
#10 salim3
salim3
  • 7 posts
Posted 08 March 2013 - 02:41 PM
hai,
after install the netduino driver, is it it will create a serail port automatically?
#11 kiikas
kiikas
Posted 07 May 2013 - 07:21 AM
Hi guys,
Some urgent help needed.
I have beed trying to flash my Netduino to 4.2 firmware but after loading tinybooter using SAM BA, the netduino is nolonger visible via USB in MFDeploy.
Yet in device manager under Universla Serial Bus Controllers, its actually there..
Please help
#12 Jason.Net
Jason.Net
  • 41 posts
Posted 07 September 2013 - 01:31 PM
Hi Guys.
I have a Netduino 2 which I received today :-). I currently develop software using Visual Studio 2012 inside a VMWare virtual machine. I read from another post that the drivers for the board need to be installed on the host system first and then it can be used in the virtual environment. I don't want to install anything else but the drivers into the host machine.
1) Will my Netduino 2 work under Visual Studio 2012 as is or do I need to upgrade it?
2) Can I use the drivers from this post or do I need to go somewhere else?
Jason
#13 Chris Walker
Posted 13 December 2013 - 04:01 AM
Hi Jason,
I'd recommend using the Netduino drivers which are installed (into Program FilesSecret LabsNetduino SDKDrivers). The MFUSB drivers are legacy and will probably work for you inside a VM. The WinUSB drivers are the newer ones and may not work inside your VM. Be sure to force Windows to install the particular drivers you're wanting to use. Welcome to the Netduino community, Chris
#14 Emilio Pastore
Emilio Pastore
  • 12 posts
  • LocationSão Paulo, Brasil
Posted 25 February 2015 - 07:46 PM
Hello.
After the automatic driver install failed a couple of times, I downloaded Cris' ZIP here and proceeded, but this time the message I received was this :
Windows encountered a problem installing the driver software for your device
Windows found driver software for your device but encountered an error while attempting to install it.
Netduino
Windows cannot load the device driver for this hardware. The driver may be corrupt or missing. (Code 39)
What do I do now, any hints ?
Thanks, Emilio
#15 Emilio Pastore
Emilio Pastore
  • 12 posts
Posted 28 February 2015 - 08:36 PM
An update :
After a couple of hours attempting to solve this, it turns out that when I disabled drivers signature enforcement in my Windows Vista 64 Advanced boot options, the installed driver came up never to give errors again. It seems to me this driver does not carry a valid Windows signature, is it so ?
Emilio
