Netduino2 ultrasonic sensor + 8x8 LED matrix + Speaker
Netduino 2 ultrasonic sensor I2C PWM
#1 Shivaram K R
Shivaram K R
  • 3 posts
  • LocationIndia
Posted 04 August 2013 - 05:13 PM
I am sharing my C# code for Netduino 2 here. The project uses Ultrasonic distance sensor (HC-SR04) with 8x8 LED matrix (available in Adafruit store http://www.adafruit.com/products/872 ). When the object is close the whole LED matrix is ON, when the object moves far away the number of LEDs which are ON reduces. It also generates sound based on the proximity of the object.
Pin 5: SONAR trigger,
Pin 0: SONAR Echo
Pin 6: Speaker
SCL: LED Matrix clock
SDL: LED Matrix data
make VCC and Gnd connections to +5V and GND
Run this program in the file attached.
I will be writing cleaner library with classes etc later. Any suggestion to improve the efficiency of the code is welcome.
#2 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 04 August 2013 - 11:20 PM
well, you should use a multi i2c class, its makes it look way nicer.
also:
byte[] data = new byte[bufferSize];
  data[0] = 0x00; // Going to starting address
  for (uint i = 1; i < bufferSize; i += 2)
  data[i] = 0x00;
  data[i + 1] = 0x00;
isent needed
sets every item in the array to 0x00 allready
than:
PWM trig = new PWM(Cpu.PWMChannel.PWM_0,60000,10, PWM.ScaleFactor.Microseconds, false);
dont use Cpu.whatever.
its PWMChannels.yourpin
another suggestion: dont use static all the time.
http://pastebin.com/9BBHnWA3 > anti static :P
#3 Shivaram K R
Shivaram K R
  • 3 posts
  • LocationIndia
Posted 05 August 2013 - 03:42 AM
Thank you :) , Yes I need to use a class instead of using everything in Main...
also:
  data[i] = 0x00;
  data[i + 1] = 0x00;
isent needed
than:
#4 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 05 August 2013 - 06:11 AM
Welcome to the Forums!
Sharing is what makes this a great place to be.
Paul
Also tagged with one or more of these keywords: Netduino 2, ultrasonic sensor, I2C, PWM
