Environment and Compiler for building STM32f2xx-based projects
stm32f2xx arm gcc eclipse make error 1
6 replies to this topic
#1 knutolai
knutolai
  • 36 posts
Posted 22 May 2013 - 06:09 PM
Hi
I'm building a simple C program based on the STM32F2xx peripheral library examples. The program is meant to flash the onboard LED on my Netduino board.
I've set up a environment using:
Eclipse Juno C/C++
GNU ARM Eclipse plugin (CDT)
LaunchPad GNU Tools for ARM (has Cross GCC compiler)
I'm working in a 64-bit windows 7 system.
I build the project in Eclipse and keep getting the error:
Make: *** [<project name>] Error 1
I can't afford to buy a commercial tool. Does anyone have any recommendations on alternatives I could try out?
I have checked out CooCox CoIDE, but it only supports projects for STM32F1/F4 MCUs. I've also tried building the project in the command-line (though I might have used faulty syntax, as I have absolutely no experience with it).
attached is my main program (was not allowed to upload .h and .c files)
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 22 May 2013 - 08:38 PM
The CooCox IDe also seems to support STM32F0 (although not much help to you with your board).
Have you had a look at Hussam Al-Hertani's blog.  That talks about setting up Eclipse and GCC.  I'd have thought all you should need to do is to get the correct compiler flags for your chipset.
If you are looking for a solution for small programs (less than 8KB) then have a look at IAR's environment.
#3 Bi Qin
Bi Qin
  • 23 posts
Posted 23 May 2013 - 02:35 PM
obviously you made some mistake while setting up the eclipse.
there should not be any error about "Make" command,as you don't need to write makefile for such a building.
I think all you need can be found here:http://www.stf12.org...opers/ODeV.html
#4 knutolai
knutolai
  • 36 posts
Posted 24 May 2013 - 11:19 AM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]obviously you made some mistake while setting up the eclipse.[/color]
Thats what I thought to. Thank you for the link to ODeV.
I've installed the package and it manages to compile the template project, generating a .elf file. Does this file contain the whole pre-compiled project?
#5 Bi Qin
Bi Qin
  • 23 posts
Posted 24 May 2013 - 02:45 PM
Yes,you can use the elf file with GDB for debug.
Or you can use below command to generate .hex file for burning(using st-link utitily or something similar)
arm-none-eabi-objcopy.exe -O ihex Yourfilename.elf Yourfilename.hex
#6 knutolai
knutolai
  • 36 posts
Posted 26 May 2013 - 11:23 AM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Yes,you can use the elf file with GDB for debug.[/color]
Great that worked alright. Again thank you so much for the link to ODeV! Amazing resource :)
#7 knutolai
knutolai
  • 36 posts
Posted 30 May 2013 - 12:15 PM
So I ran into some trouble with ODeV when writing a program where I combine C and C++.
I keep getting "expected '=', ',', ';', 'asm' or '__attribute__' before '*' token" when building. ODeV does offer a C++ extension (FreeRTOS_EC) and there is a downloadable project for a STM32F1xx device using this extension (Cortex_STM32F1xx_CPP_Template).
I added FreeRTOS_EC as a Linked Resource in my project, but it didn't really do any difference. When further inspecting and comparing  the preferences of the I noticed that both projects used the same Tool Chain with the same Used Tools. However only the F1xx project has the C++ Compiler (ARM Sourcery Windows GCC C++ Compiler) listed in the Discovery Options Tools list.
For some reason my project does not understand that it needs this compiler to build the code.
I tried applying all available discovery profiles, but none of them adds the C++ Compiler to the tools list
Does anyone have any suggestions on other things I could try?
Also tagged with one or more of these keywords: stm32f2xx, arm, gcc, eclipse, make error 1
