Possible hardware fault
#1 Andrew Johnson
Andrew Johnson
  • 12 posts
  • LocationUK
Posted 03 March 2013 - 02:17 PM
I have an original netduino which I haven't used for about a year. Today I dug it out and deployed some software that I wrote a while back that drives an hd44780 lcd panel. This used to work, but now doesn't.
In investigating this I found some strange behaviour with the gpio pins. If I have program with a simple loop that repeatedly alternates GPIO0 between high and low with a short delay, this actually affects GPIO3. Changing the pin ID sometimes has no effect and other times affects a completely different pin.
My question: is there an explanation for this apart from some kind of hardware damage? The board is screwed onto a baseboard and has just been sat on my desk. I don't think it has been handled.
It will respond to pings and blink the on-board led, so its not completely dead. I tried re-flashing it with 4.1.0.6 but that didn't help.
Any thoughts? should I just toss it an buy a netduino 2.
Thanks, Andy.
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 03 March 2013 - 03:13 PM
Hi Andy and welcome to the Netduino forums!
Just want to be sure, did you use the correct pin enumeration? This is a common mistake I often make myself too;
Debug.Print(SecretLabs.NETMF.Hardware.Netduino.Pins.GPIO_PIN_D0.ToString()); // 27Debug.Print(Microsoft.SPOT.Hardware.Cpu.Pin.GPIO_Pin0.ToString());           //  0Debug.Print(SecretLabs.NETMF.Hardware.Netduino.Pins.GPIO_PIN_D3.ToString()); //  1Debug.Print(Microsoft.SPOT.Hardware.Cpu.Pin.GPIO_Pin3.ToString());           //  3
The SecretLabs enumeration is the correct one
#3 Andrew Johnson
Andrew Johnson
  • 12 posts
  • LocationUK
Posted 03 March 2013 - 03:38 PM
Hi Stefan, and thanks for your help.
Yes, I was using the Microsoft.SPOT.Hardware.Cpu.Pin enumeration in my test program. Changing it to the SecretLabs enum gives me the results I was expecting. Thanks for that!
Unfortunately my lcd driver uses the correct enum, so its problems lie elsewhere. But at least I'm not utterly confused now...
Thanks again, Andy.
#4 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 03 March 2013 - 06:40 PM
Hi Andy,
Do you have a way to test the LCD panel? (without using the Netduino)
Paul
#5 Chris Walker
Posted 05 March 2013 - 07:18 AM
Hi Andy, How hard was it screwed down? I've never seen it happen, but I suppose that it's possible to damage any circuit board traces if it is bent for a long period of time. All of the digital pins should be independent. Chris
