Best Answer baxter, 04 March 2013 - 09:17 PM
I am using code from a different reference, but it works well for me. The interrupt is triggered on the rising edge of the echo return pulse and the ticks are saved. On the falling edge, the elapsed ticks are computed and the difference is the pulse width ( See sub Trigger to generate the trigger pulse).
I translated this from C# to VB, but the link in the code is in C#.
Imports System.ThreadingImports Microsoft.SPOTImports Microsoft.SPOT.HardwareImports SecretLabs.NETMF.HardwareImports SecretLabs.NETMF.Hardware.NetduinoImports System.Math''http://forums.netduino.com/index.php?/topic/2202-measures-jumping/' Written by BG on July the 25th 2011 to test the HC-SR04 sensor (above Ref.)' Physical Placement 240 mm perpendicular to flat reflective surface.' Physical distance is measured from 1/2 the height of cylindrical sensor case to flat surface.'100 measurements from Netduino Plus 2'====================================='Calculated Distance = 240.79349999999999 mm'Mean = 241.02483673469382 Standard Deviation = 1.0885082552654264'Low pass filter distance (alpha=0.3) = 240.78816817382358'Max/Min on interval: MAX = 245.08 mm, MIN = 240.62 mm'100 measurementsModule Ultrasonic_Dist_Sensor Dim ConvFactor As Double 'conversion factor: Echo pulse width ticks to distance Dim Distance As Double = 0 Dim ticks As Long Private EchoPin As New InterruptPort(Pins.GPIO_PIN_D10, True, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth) Private TriggerPin As New OutputPort(Pins.GPIO_PIN_D12, False) Public Sub Main() 'compute the mean and standard deviation of the measurements Dim MeanVariance As Smooth = New Smooth(0) ' initialize time series Dim ExpSmooth As Double 'conversion factor for return pulse ticks to mm. ConvFactor = ConversionFactor(20.0) 'call with temperature (deg C) 'handler to process return pulse AddHandler EchoPin.OnInterrupt, AddressOf Echo_OnInterrupt 'echo EchoPin.DisableInterrupt() Dim count As Integer = 0 While True Trigger() 'trigger pulse Thread.Sleep(1000) Debug.Print("Distance = " & Distance.ToString & " mm") MeanVariance.MeanVarAddData(Distance) ExpSmooth = MeanVariance.LowPassFilter(Distance, 0.3) If (count > 3) Then ' first collect some data before printing Debug.Print("Mean = " & MeanVariance.mean.ToString & " Standard Deviation = " & MeanVariance.StdDeveviation.ToString) Debug.Print("Low pass filter distance (alpha=0.3) = " & ExpSmooth.ToString) End If count += 1 If (count = 103) Then Exit While End While End Sub Public Function ConversionFactor(Temp As Double) As Double 'Temp = input degrees Celsius 'The approximate speed of sound in dry air is given by the formula: 'c = 331.5 + 0.6 * [air temperature in degrees Celsius] 'At 20°C, c = 331.5 + 0.6 * 20 = 343.5 m/s '1 tick = 0.1uSec, 1 meter = 1000 mm, Hence 'c = c * 1000 / 10000000 --> c mm/tick 'round trip out and back so divide by 2 to get distance Dim c As Double = 331.5 + 0.6 * Temp Return (c * 1000 / 10000000) / 2.0 End Function Public Sub Trigger() EchoPin.EnableInterrupt() TriggerPin.Write(False) Thread.Sleep(2) TriggerPin.Write(True) Thread.Sleep(15) TriggerPin.Write(False) Thread.Sleep(4) End Sub Sub Echo_OnInterrupt(port As UInteger, state As UInteger, time As DateTime) If state = 0 Then ' falling edge, end of pulse Dim pulseWidth As Integer = CInt(time.Ticks - ticks) Distance = ConvFactor * pulseWidth Else ticks = CInt(time.Ticks) 'rising edge End If EchoPin.ClearInterrupt() Thread.Sleep(50) End SubEnd Module
