http://www.emartee.c...ton IRF540 V2.0
Does anyone know if the netduino can control this device?
Anyone using it for LEDs as a driver?
![]() Mosfet IRF540 v2.0
Started by zemuss, Feb 13 2013 11:02 PM
Posted 13 February 2013 - 11:02 PM http://www.emartee.c...ton IRF540 V2.0
Posted 14 February 2013 - 04:57 AM i guess so, it says the min voltage is 3 volts for the inputs, wich netduino can supply.
its also opto coupled, so i like the design
when you want to drive a mosfet directly you have to watch out that its logic level, or it wount completly turn on, get hot and burn. but this board avoids that with the couplers
Posted 14 February 2013 - 07:30 AM
Netduino should be able to control this - as NooM has already pointed out, there are optocouplers (4N35) that switch the MOSFETs, so it is basically the same as if Netduino controls ~10 mA LED. IRF540 has gate threshold voltage 2 - 4 V (3V typical), so Netduino's 3.3V output would be barely sufficient to switch it on, but the transistor needs at least 5V on the gate for 10 A drain current, and 10V for the maximum 22 A current.
I would say it depends on how many LEDs you want to control and how they are connected. It is certainly an overkill for controlling single 'normal' LED, it will work for power LED or LED strip (constant current power supply recommended).
Posted 14 February 2013 - 04:48 PM I think I will go with the Meanwell Drivers which are used for high powered LEDS and get a constant power supply.
Thanks for the help everyone its much appreciated. 1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
