Serial Communication Not Working
7 replies to this topic
#1 bsilvereagle
bsilvereagle
  • 11 posts
Posted 13 February 2013 - 02:39 AM
I am trying to get a Netduino Plus 2 to communicate with PuTTy.
using System;using System.Net;using System.Net.Sockets;using System.Threading;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.Hardware.Netduino;using System.IO.Ports;namespace NetduinoPlusRx{    public class Program    {        static SerialPort port;        public static void Main()        {            // write your code here            port = new SerialPort(SerialPorts.COM2, 115200, Parity.None,8,StopBits.One);            port.Open();            while (true)            {                port.Write(new byte[] { 0x01, 0x02, 0x03 }, 0, 2);                Thread.Sleep(100);            }        }    }}
PuTTy isn't picking up anything. I have an FTDI cable with Ground connected to Ground, and Rx/Tx connected to pins 3/2.
Any thoughts/obvious errors?
#2 Mario Vernari
Posted 13 February 2013 - 04:30 AM
Did you swap the RXD/TXD in order to flow the data from an output to an input?
#3 bsilvereagle
bsilvereagle
  • 11 posts
Posted 13 February 2013 - 01:38 PM
Yes, I flipped the wires and nothing changed.
#4 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 13 February 2013 - 05:34 PM
Are you sure putty will display those values as characters?
Mightbe better to try values greater than 0x20 which map to real characters.
Paul
#5 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 13 February 2013 - 08:07 PM
Silly suggestion, but last night I kicked rocks with serial communication for about an hour before I realized that the baudrates were different on the Netduino side and the laptop side. Maybe you overlooked this too?
#6 Chris Walker
Posted 13 February 2013 - 09:09 PM
Hi bsilvereagle, What voltage does the particular FTDI cable use for signals? Is it a 3.3V cable, 5V cable, or RS232-level cable? Also, is it only COM2 that doesn't work for you? Or did COM1 (pins D0/D1) also not work in your scenario? Finally--are you using digital pins D2/D3 or analog pins A2/A3? Chris
#7 bsilvereagle
bsilvereagle
  • 11 posts
Posted 14 February 2013 - 04:25 AM
Paul you were absolutely correct, I changed the values to > 0x20 and now it's working, thanks a lot.
Chris - not that it matters but it's the Adafruit FTDI Cable
#8 Paul Newton
Paul Newton
  • 724 posts
Posted 14 February 2013 - 08:36 PM
It was only guess!
Glad your back on track.
