security keypad
#1 optimus primer
optimus primer
  • 21 posts
  • Locationnashville, tn
Posted 06 February 2013 - 11:29 PM
i am in the process of making a home security system. i want to buy a keypad instead of making one. honeywell ademco 6148. but i do not understand the data line out. i can not find any specs on the net anywhere. any help would be awesome.
thanks.
#2 Mario Vernari
Posted 07 February 2013 - 04:20 AM
There's a very interesting article of Paul Newton in the Netduino's Wiki.
That should help.
#3 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 07 February 2013 - 09:53 PM
Hi Optimus,
I found a data sheet for the keypad.
I can see that you have 0V, 12V, data in and data out.
But, I can't find any information on what the data in/out are.
I suggest that you power up the keypad and use a voltmeter to check the data out signal.
If you find a large voltage, e.g. +/- 5V, you may have RS232. If so you could try inputting that to a PC serial port (or USB adapter if you have a PC younger than my 10 year old model), then run up a serial terminal such as Putty and try pressing buttons. You may need to tweak the serial settings (baud rate / bits) to get a result. Hopefully you will a recognisable character on the PC when you press a key. Even better would be to use an oscilloscope to look at the data out as you press keys.
If it is RS232, remember you will need a voltage converter before connecting to the Netduino.
Paul
#4 optimus primer
optimus primer
  • 21 posts
Posted 12 February 2013 - 05:20 PM
thanks for the infromation. i should be getting it in the mail in the next couple of days. with some trial and testing i will be able to figure out something and i will post my results with some questions how to write the code.. thanks
