How to upgrade to the .NET Micro Framework v4.3 SDK
25 replies to this topic
#21 dmr6124
dmr6124
  • 6 posts
Posted 18 April 2013 - 02:05 PM
I've attached a Word Doc with the screen shot from my desktop showing both the Vs Express 2012 for Windows Desktop screen, with the NETMF 4.3 installation and error windows superimposed.Attached File  NETMF 4.3 Error.doc   1.89MB   12 downloads BTW, I did an installation on my laptop too. Same products, but it worked on my laptop.
#22 Odelay
Odelay
Posted 14 June 2013 - 01:50 PM
dmr6124: did found a solution for this error? I'm having te same error and express 2012 installed?
#23 jkrarup
jkrarup
  • 8 posts
Posted 16 July 2013 - 05:19 PM
Any reason that you haven't included 4.3 MF and SDK on your "Downloads" page for those of us who have completely switched to VS 2012?
This way we don't have to browse the Forum in order to discover that there is a version for those on the cutting edge.
Thanks...
#24 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 25 July 2013 - 03:53 PM
I have updated my project on CodePlex to .Net Micro Framework 4.3 !
uPLibrary - .Net Micro Framework Helper Library
M2M communication MQTT Client Library
.Net Micro Framework Weather Station
Paolo.
Paolo Patierno
Azure Advisor
Twitter : @ppatierno
Linkedin : paolopatierno
Blog : DevExperience
Blog : Embedded101
#25 SawDust
SawDust
Posted 06 June 2014 - 01:30 AM
Hello Forum,
I am new to micro controllers and .NET so I am still in the steep slope of the learning curve. I have completed the simple examples and am now experimenting with talking to other devices (that is the point afterall!). I have a serial LCD working and of course solenoids. However I am having trouble with I2C devices so I decided to try the drivers in the MicroFramework Toolbox (thanks Stefan, very nice!), and started with the DS1307 clock example. The toolbox example program crashed immediately and the messages hint at a software version issue (?).
I have a Netduino 2 Plus, using the following software:
Visual Studio Express 2012 (v11.0.50727.42)
.NET MicroFramework SDK 4.3 (QFE1) (v4.3.1.0)
Netduino SDK v4.3.1 (Feb 2014) (v4.3.1.0)
.NET MicroFramework Toolbox (v0.1.0.0)
I attached a pdf containing a program listing, messages during Deployment, Build, and Debug, and a snapshot of the external references used. I would appreciate any help from an experienced user.
Thanks!
SawDust
Attached File  RTC_test.pdf   176.94KB   7 downloads
6/17/2014 Update
I found an answer to my question elsewhere on this forum, downloaded Toolbox compatible with 4.3. Happy camper now with the exception of some Visual Studio 12 stability issues.
#26 blackt1ger
blackt1ger
  • 14 posts
Posted 16 November 2014 - 10:32 PM
Help.
Using Netduino Plus 2.
Okay, I got Visual Studio 2013 and Visual Studio 2013 Express for Desktops.  I managed to get everything installed.  Updated the firmware with the Netduino update.  Everything looks okay.
Project builds and deploys, but when I want to debug, it reboots the Netduino, and then tries to re-attach the debugger.  It fails.  Subsequent attempts to deploy fails.  Need to remove/insert USB wait for it to detect and I can deploy again, but the same error happens when I try to debug.
I erased the app (using the Netduino Update options dialog), but it doesn't make any difference.
Just to be clear, the MF experimental is no longer needed, right?  CodePlex has the MF 4.3 - R2-Beta which supports Visual Studio 2013.  But what about the Netduino SDK ? Do we use the experimental version as linked in the beginning of this forum?
Looking for a device on transport 'USB'
Starting device deployment...
Iteration 0
Opening port \\?\USB#VID_22B1&PID_1000#000000000000#{09343630-a794-10ef-334f-82ea332c49f3}\Operations
Attaching debugger engine...
... debugger engine attached!
Querying device assemblies...
Found Assembly mscorlib 4.3.1.0
Found Assembly Microsoft.SPOT.Native 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware 4.3.1.0
Found Assembly Microsoft.SPOT.Net 4.3.1.0
Found Assembly System 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.SerialPort 4.3.1.0
Found Assembly Microsoft.SPOT.IO 4.3.1.0
Found Assembly System.IO 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.PWM 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.Usb 4.3.1.0
Found Assembly SecretLabs.NETMF.Diagnostics 4.3.1.0
Found Assembly SecretLabs.NETMF.Hardware.Netduino 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.OneWire 4.3.1.0
Found Assembly Microsoft.SPOT.Time 4.3.1.0
Found Assembly SecretLabs.NETMF.Hardware.NetduinoPlus 4.3.1.0
Found Assembly SecretLabs.NETMF.Hardware.NetduinoMini 4.3.1.0
Found Assembly NetduinoApplication1 1.0.0.0
Found Assembly SecretLabs.NETMF.Hardware.PWM 4.3.1.0
Found Assembly SecretLabs.NETMF.IO 4.3.1.0
Found Assembly SecretLabs.NETMF.Hardware.AnalogInput 4.3.1.0
Found Assembly SecretLabs.NETMF.Hardware 4.3.1.0
Adding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.hardware.netduinoplus.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.hardware.netduinomini.pe to deployment bundle
Adding pe file C:\dev\TigerTools\Hardware Tools\NetduinoApplication1\NetduinoApplication1\bin\Debug\le\NetduinoApplication1.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.hardware.pwm.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.io.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.hardware.analoginput.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.hardware.pe to deployment bundle
Attempting deployment...
Incrementally deploying assemblies to device
All assemblies on the device are up to date.  No assembly deployment was necessary.
Assemblies successfully deployed to device.
Restarting interpreter...
Attaching to device...
Waiting for device to initialize...
The debugging target and the debugger engine failed to initialize because of unspecified device errors.
The debugger engine thread has terminated unexpectedly with error 'Object reference not set to an instance of an object.'.
Edited by blackt1ger, 16 November 2014 - 10:57 PM.
