Version: 4.3.0 Beta 1 (version 4.3.0.0 beta 1)
This firmware requires use of the .NET Micro Framework v4.3 SDK and Netduino 4.3.0.0 SDK.
To flash this firmware:
1. Detach your Netduino
3. Erase the firmware on your Netduino using the STDFU Tester v3.0.1 application
> d. Press the "Go" button
4. Flash the attached .DFU file using the ST DfuSe Demonstrator v3.0.2 application (included with STDFU Tester)
After flashing, to set your network settings using MFDeploy:
1. Select the Target > Configuration > Networking menu. Re-enter your IP address settings and MAC address.
Hi just wanted to let you know that i was finally able to flash the Netduino 2 plus to the 4.3.0.0 beta 1
Im using windows 7 64 bits.
Problems i encountered:
-No detection in bootloader mode.
i upgraded to STDFU tester V3.0.3 same problem.
windows was able to recognise the usb device by going to the device manager and selecting the driver located in ..DfuSeDriver(manual update)
then i did flash but the program crashes when it does the verification(i tried several times to do the verify it doesn't do it)
But i verified the version within and it works!
Verified with the blink led program it works!!!
Just hope it will make it easier for someone else to upgrade it!
