Netduino Plus 2 Firmware v4.3.0 (beta 1)
123 replies to this topic
#1 Chris Walker
Posted 04 February 2013 - 05:37 AM
Version: 4.3.0 Beta 1 (version 4.3.0.0 beta 1)
This firmware requires use of the .NET Micro Framework v4.3 SDK and Netduino 4.3.0.0 SDK.
384KB Flash
100KB+ RAM
1. .NET MF 4.2 QFE2 and 4.3 bug fixes
This firmware does not include:
1. Newest lwIP networking stack from .NET MF 4.3. This will be added in an upcoming release.
2. SecretLabs.NETMF.Hardware.Diagnostics.dll. This will be added in an upcoming release.
This firmware also includes the previous updates:
1. Bug fix: SPI clock 'idle high' setting now supported
2. Netduino Plus 1 projects can be upgraded without changing HardwareProvider
3. Now compatible with legacy SecretLabs AnalogInput and PWM classes
4. Bug fix: SPI chip select timing corrected
5. Bug fix: PWM frequency corrected
6. New: more reliable rebooting during deployment
7. Static IP now works (in addition to DHCP default)
8. MAC Addresses are now loaded by TinyCLR
9. Additional I2C bug fix--pins now forced into proper configuration
1. Go to the Start Menu > Programs > Microsoft .NET Micro Framework 4.3 > MFDeploy
To flash this firmware:
1. Detach your Netduino
3. Erase the firmware on your Netduino using the STDFU Tester v3.0.1 application
> d. Press the "Go" button
4. Flash the attached .DFU file using the ST DfuSe Demonstrator v3.0.2 application (included with STDFU Tester)
After flashing, to set your network settings using MFDeploy:
1. Select the Target > Configuration > Networking menu. Re-enter your IP address settings and MAC address.
#2 weixiongmei
weixiongmei
  • 68 posts
  • LocationPhiladelphia, Pennsylvania, United States
Posted 04 February 2013 - 07:18 AM
thanks alot~~~
#3 JoopC
JoopC
  • 148 posts
Posted 05 February 2013 - 07:34 AM
Hello, I need do you all greetings from Ellen (family of my)
Back to 4.3:
-Network is not possible with 4.3, going back to 4.2 then it re-establish Network. (No connect/send light on the N+2 and no connect light on the Router).
-Bit shifting  << is not possible and give an error.
#4 Chris Walker
Posted 05 February 2013 - 07:55 AM
Hi JoopC, Can you please provide more details regarding networking with 4.3? Did you flash your board with Netduino 2 beta firmware...or Netduino Plus 2 beta firmware? Chris
#5 JoopC
JoopC
  • 148 posts
Posted 05 February 2013 - 09:33 AM
I had the Netduino 2 beta firmware,
Now with the Netduino PLUS 2 beta firmware I am connected.
I had no idea of ??the existence of another netduino (plus or without plus) version. Now I start testing everything again.
Chris, a little note.
Please put the announcement of Attached Files more on the top of the posts. It is written in Blue and at the end of the post and we can read easely over it without notice it. For you it is Obvious, but you work every day with the files.
#6 francoism
francoism
Posted 07 February 2013 - 06:29 AM
Hi all,
I am new to NETMF and Netduino.
I started of with a RGB LED and a Ultrasonic Rabge Sensor, to show the different colors at different distances.
All went well and I got it working, but the RGB LED was not bright at all, very faded.
I started playing around with the parameters of the PWM object for each of the RGB colors.
Now the problem, after a deploy I got an error in my code and the Netduino+ 2 froze up, if I reconnect to USB something happens.
I cannot deploy to Netduino+ 2 from Visual Studion no connection, I cannot ping from MFDeploy.
I read you can re-Flash the firmware, I downloaded STDFU Tester v3.0.1, restarted the Netduino+ 2 into BootLoader mode, it wanted to install a driver which failed, and the STDFU software is not detecting the Netduino+ 2 device in the device list.
The version is NET MF 4.2, Netduino+ 2 SDK 4.2.0 and the Firmware is also 4.2.X
I have downloaded all the version for 4.3 and want to flash the device to use Version 4.3 for MF, SDK and FW.
How can I get this to work, I know I have said a lot here, but help will greatly be appretiated.
#7 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 07 February 2013 - 02:05 PM
Hi, the [color=rgb(40,40,40);][font="helvetica, arial, sans-serif;"] [/color][/font]STDFU Tester v3.0.1 is not included in the download. When I unzip the file all that's there is DfuSe_Demo_V3.0.2_Setup and DfuSe_Demo_V3.0.2_Setup_amd64. Am I missing something? Thanks.
UPDATE: I found it. Nevermind.
Edited by AndrejsM, 07 February 2013 - 02:10 PM.
#8 Chris Walker
Posted 07 February 2013 - 04:36 PM
Hi francoism,
When you start the Netduino Plus 2 in bootloader mode (by holding down the pushbutton while plugging it into MicroUSB), what device appears in Device Manager?
#9 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 07 February 2013 - 10:19 PM
Hi. I'm having a problem with STDFU Tester as well. When I plug my Netduino Plus 2 in, holding the button, the device manager has a 'STM32 Bootloader'. When I Start STDFU, The Netduino doesn't show up as a device in the combo box at the top in the 'Protocol Tab'. Can you help please?
#10 Chris Walker
Posted 08 February 2013 - 12:05 AM
Hi AndrejsM, What version of STDFU are you running? Chris
#11 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 08 February 2013 - 12:30 AM
Hi. It's 3.0.1 it's the one from he download link up above in this thread.
UPDATE: Figured out my problem. Needed to install a driver for the Bootloader. Now I'll try to flash the darn thing.
#12 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 08 February 2013 - 04:24 AM
Hi. It's me again :) So I was able to erase my ND+2 using the above instructions. But now I can't flash the new firmware. In my device manager it says 'STM Device in DFU Mode'. I can see the device in STDFU tester when I erase. However a device does not appear at the top of the ST DfuSe Demonstrator v3.0.2. I can choose the DFU file per instructions, however the 'Upgrade' button never becomes active, so I can't press it. Any suggestions? BTW, I messed up the ND+2 by setting the frequency too low when I was messing with PWM. Thanks for your help!
#13 Chris Walker
Posted 08 February 2013 - 05:37 AM
Hi AndrejsM, STDFU and DFUSE should both recognize the device the same way. Can you please check to make sure it appears in STDFU...and then try DFUSE again? Perhaps reboot your PC really quickly? If it doesn't work there, diagnostics is going to be a bit tough. We're happy to contact ST and try to explore this, but it might be easiest to borrow another computer for a moment... Chris
#14 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 08 February 2013 - 11:15 AM
Hi. Is my driver out of date? In device manager the properties for the ST driver are;
Provider: STMicroelectronics
Driver Date: 11/9/2009
Driver Version: 3.0.1.0
Does this look right?
Thanks.
#15 Chris Walker
Posted 08 February 2013 - 04:58 PM
Hi AndrejsM,
The driver installed on my PC (from the standard DFUSE installer, linked in the firmware update posts and also below) is:
Driver Date: 7/5/2012
Driver Version: 3.0.4.0
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
I would recommend uninstalling your current version of DFUSE and installing the latest one instead:
http://www.st.com/in...DEMO/um0412.zip
#16 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 08 February 2013 - 06:15 PM
Thanks. I'll try the new link you have provided.
#17 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 08 February 2013 - 11:54 PM
Hi. I know I'm becoming a total pain with all of this, but I'm loosing my mind over here. I downloaded the file from...
The STtube.inf file that is in there is dated 2009 and has the following in it...
DriverVer=11/09/2009,3.0.1.0
CatalogFile=sttube.cat
And the sttube.cat file is also dated 2009. Where does the [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]3.0.4.0 version from 2012 come from. I have installed, uninstalled, rebooted. I even switched to another computer with the same results. Is there any other way to get new firmware on the N+2? Heck, I'll go back to 4.2 if I can just get it to work. Thanks.[/color]
#18 Chris Walker
Posted 09 February 2013 - 02:03 AM
Hi AndrejsM,
I suppose that it's possible that Windows Update pulled in the driver I'm using. If you uninstall your current driver and then just let Windows Update find it...do you get a newer version?
Also...it looks like ST has updated DfuSe to a new version (3.0.3). But the new version might have some compatibility issues with Windows 8 x64. So we've cached 3.0.2 in our downloads section at the following link.
http://www.netduino....edemo_3.0.2.zip
#19 AndrejsM
AndrejsM
  • 18 posts
  • LocationAtlanta
Posted 11 February 2013 - 06:23 PM
Hi Chris. Thanks for all of your help. FYI, I finally got a third laptop to behave correctly. I installed UM0412.zip from the link above on my third laptop. Checked the driver info and the driver was the 2009 version. I then uninstalled the driver, re-started the computer, plugged in the netduino with the button pressed, and in device manager, instead of showing up as unknown device or STM32 Bootloader (which it always did on the other two computers after I uninstalled the driver), it was in the USB section as if I hadn't uninstalled the driver. I checked the driver details and walla, it was the same version that you have, 3.0.4.0. I have no idea how that happened. The important part is that I was able to flash the netduino to 4.3.0 firmware and am back in business!!!
I have scoured the web and the ST Microelectronics site and cannot find the 3.0.4.0 driver for download. Does anyone know where it is as a standalone download? Thanks.
#20 col
col
  • 7 posts
Posted 17 February 2013 - 08:05 AM
hello i have a netduino plus, i can update my netduino plus with this firmware v4.3.0 (beta 1)
Thanks.
