Best Answer Chris Walker, 01 February 2013 - 04:27 PM
Hi martin2250,
It sounds like your Netduino Plus 2 may be locking out the debugger. This can be fixed by erasing and reflashing your Netduino using the instructions in the latest "Netduino Plus 2" firmware sticky at the top of this forum.
Please note that the reflashing procedure is new and simplified for the gen2 boards. The ERASE pad process of gen1 is now discontinued and you simply use software to erase and reflash the board now. Full instructions are in the latest firmware thread (be sure to look for the "2" in "Netduino Plus 2" in the thread title).
Also...1Hz is too long of a signal for the 16-bit PWMs. You'll max out at around 16Hz. You can go as fast as 1,000,000Hz--but no slower than 16Hz. The exception to that is the single 32-bin PWM.
Does that get you back up and running?
