Netduino Plus 2 Firmware v4.2.2 (update 2)
60 replies to this topic
#1 Chris Walker
  • 6076 posts
Posted 07 February 2013 - 06:07 PM
Version: 4.2.2 Update 2 (version 4.2.2.2)
This firmware requires use of the .NET Micro Framework v4.2 SDK (QFE2) or newer and .Netduino 4.2 SDK or newer.
384KB Flash
100KB+ RAM
1. .NET MF 4.2 QFE2 bugfixes
This firmware also includes the previous updates:
1. Bug fix: SPI clock 'idle high' setting now supported
2. Netduino Plus 1 projects can be upgraded without changing HardwareProvider
3. Now compatible with legacy SecretLabs AnalogInput and PWM classes
4. Bug fix: SPI chip select timing corrected
5. Bug fix: PWM frequency corrected
6. New: more reliable rebooting during deployment
7. Static IP now works (in addition to DHCP default)
8. MAC Addresses are now loaded by TinyCLR
9. Additional I2C bug fix--pins now forced into proper configuration
To flash this firmware:
1. Detach your Netduino
3. Erase the firmware on your Netduino using the STDFU Tester v3.0.1 application
> d. Press the "Go" button
4. Flash the attached .DFU file using the ST DfuSe Demonstrator v3.0.2 application (included with STDFU Tester)
After flashing, to set your network settings using MFDeploy:
1. Select the Target > Configuration > Networking menu. Re-enter your IP address settings and MAC address.
#2 Dave VanderWekke
Dave VanderWekke
  • 851 posts
  • LocationHighland Lakes, New Jersey, USA
Posted 07 February 2013 - 07:02 PM
Hey Chris...can you publish the BIN and HEX files?  I'd like to try a black box upgrade without having to open the unit and disassemble the shield to get to the button and see if it works.
Software Architect, Electronic Engineer, Car Enthusiast, Chef, Blogger, Paranormal Investigator (and Skeptic). I'm like MacGyver, Alton Brown, Doc Brown and Peter Venkman all in one.
My Blog Site: JerseyTechGuy's Blog
Facebook:JerseyTechGuy on Facebook
Twitter: @JerseyTechGuy
My Netduino 2 Tutorials
My Netduino Based Paranormal Investigation Tools
#3 Chris Walker
  • 6076 posts
Posted 07 February 2013 - 07:09 PM
Sure, here you go!
#4 Dave VanderWekke
Dave VanderWekke
  • 851 posts
Posted 07 February 2013 - 07:26 PM
Chris... You da Man!... I'll let you know how it goes. :D
#5 Dave VanderWekke
Dave VanderWekke
  • 851 posts
Posted 07 February 2013 - 07:56 PM
Ok, using the HEX and BIN worked like a champ.  My program basically used the "Erase Firmware" from MFDeploy, then Uploaded the new HEX and BIN files, then verified the firmware version was different than the previous version.  Finally it sets the MAC address (as this gets erased) and reboots.  Everything comes up fine and it's showing version 4.2.2.2 and the Pandora's Box version 2.95 software was still on there and didn't need to be erased as it doesn't affect those sectors.
All in all, the process too about 2 minutes.  This is a great way to allow end users of my product to get firmware and software upgrades alike.
#6 ajcg1973
ajcg1973
  • 70 posts
Posted 08 February 2013 - 10:59 PM
I'm not sure what changed in this firmware related to Analog Input but for reading a LM34DZ temp sensor off of AN0, I used to see swings in my readings as large as 8 units but with this release that variance has dropped to 4.  Not bad for a simple firmware upgrade.
#7 Dave M.
Dave M.
  • 47 posts
Posted 10 February 2013 - 02:38 PM
I could be wrong, but this update seems to have broken I2C.  When my SDA/SCL lines were inactive under 4.1.1 while my program was running (verified with my logic analyzer), I found the I2C firmware fix update and loaded it.  Once I did that, my I2C bus started to work.  But in the process of debugging a STDFU app crash, I found out from another member about firmware 4.2.2, so I loaded it.  And now my I2C bus doesn't work again.  Has anyone else out there noticed this?  I'm going to downgrade the firmware again and will let you know what happens.
#8 Dave M.
Dave M.
  • 47 posts
Posted 10 February 2013 - 03:01 PM
I've confirmed by going back and forth between 4.2.1.1 and 4.2.2.2 that the latter update causes I2C to not work again.
#9 Dave VanderWekke
Dave VanderWekke
  • 851 posts
Posted 10 February 2013 - 04:19 PM
I've upgraded 3 boards to 4.2.2.2 which each have five I2C devices attached.  They all work fine.
#10 Dave M.
Dave M.
  • 47 posts
Posted 10 February 2013 - 07:30 PM
Thanks, Dave.  Can you suggest other ways for me to determine what's going on?  What I am seeing is that, running the same project, firmware 4.2.1.1 works, but when I run 4.2.2.2, the SDA and SCL lines stay high.  Each time I reprogram, I follow the instructions and disconnect / reconnect the hardware.  The only thing odd in the entire process is that firmware upload verification crashes the ST application.
#11 Dave VanderWekke
Dave VanderWekke
  • 851 posts
Posted 12 February 2013 - 07:54 PM
I'm noticing an issue only after upgrading to this new firmware version.  My MAC Address is resetting everytime the netduino is rebooted.  When I try to set it using MFDeploy I get an error saying "Memory: OUTOFMEMORY!! 8216".  Up until now I haven't encountered this issue.  Has anyone else encountered such an issue?
#12 ryan_sorensen
ryan_sorensen
  • 4 posts
Posted 14 February 2013 - 11:22 PM
Thanks for this update. It seems to have resolved a few issues for me. I am using I2C to talk to PCA9622DR Led drivers, and my Netduino Plus 2 with stock firmware could not establish any I2C communications at all. After updating to 4.2.2.2, these LED drivers are working properly.
Has any progress been made on remapping the new I2C pins over to the old analog 4&5 pins? I have a number of shields made already and it would be great if I could get them to work on NDP1 and NDP2.
Thanks!
#13 Chris Walker
  • 6076 posts
Posted 15 February 2013 - 01:37 AM
The 4.2.2.2 firmware is the 4.2.2.1 firmware...with the bug fixes from 4.2 QFE2 checked in.
If you are experiencing specific issues with 4.2.2.2, please post a quick repro which exhibits the issue. We'll be happy to run the repro here and, upon seeing the issue, debug into QFE2 and figure out what's going on.
#14 Chris Walker
  • 6076 posts
ryan_sorensen--we're working on a fast software I2C and special I2C Configuration class for A4/A5. Nothing official quite yet. In the meantime connecting wires between SDA/SCA and A4/A5 should make I2C work for you.
#15 bsilvereagle
bsilvereagle
  • 11 posts
Posted 19 February 2013 - 07:34 PM
ST updated their website - all the links fro STDFU Test links are broken and I couldn't find good ones.
#16 yogotie
yogotie
  • 11 posts
Posted 19 February 2013 - 09:39 PM
http://www.st.com/we...SS1533/PF257916
STSW-STM32080
#17 bsilvereagle
bsilvereagle
  • 11 posts
Posted 20 February 2013 - 03:09 AM
Thank you yogotie.
#18 jleitheiser@gmail.com
Posted 20 February 2013 - 07:01 PM
HI,
I have installed a few programs onto a netduino plus and now I have moved to a netduino plus 2 for more memory.
I have loaded my original code and debugged it a couple times, but now I can't get a response. it does not appear that the PC usb is recognizing the Netduino plus 2 is connected, so I do not get the option to select a device in the
STDFU Tester application. When I connect the netduino to the PC with the reset button pushed, It is ON (pwr LED) and the blue LED stays on....when I connect it without the reset button pushed, The blue LED start in the on state and changes to the óff'state. I assume this means that I am successfully entering the bootloader and that the unit is not entirely dead. How Do I get it to accept a download and/or accept an update of the firmware?
Thank you,
Jeff
#19 Martijn
Martijn
  • 13 posts
Posted 20 February 2013 - 08:38 PM
Cool update! Any ETA on working UDP multicast? I've got multiple device lying around gathering dust and a working UPnP implementation on GHI G120HDR...
#20 Chris Walker
  • 6076 posts
Posted 20 February 2013 - 09:14 PM
Hi Jeff,
Welcome to gen2! The extra memory enables so many new projects. Let's get you up and running.
It sounds like something might be locking out the debugger. There are a few ways to fix this but the easiest is to erase and reflash the firmware on your board. Check out the instructions in the first post on this thread. They should get you back into a factory-reset state.
