Serial port problem - Netduino 2 (and Netduino 1) - Netduino Forums
Serial port problem
serial serial port serialport rs-232
#1 Duefectu
Duefectu
  • 34 posts
Posted 22 January 2013 - 12:47 PM
Hello:
I found some post about serial port problems, but I have a strange case.
I have a new Netduino Plus 2, and a RFID reader that sends data via RS-232 in 9600,n,8,1. This reader only sends data, and no need to receive any information or config.
I connected the RFID TX to D0, and GND to GND (I tried with COM1 and COM2).
I use simple code to read the data, and I tested several methods (read byte to byte, all bytes indicated by BytesToRead property…)
When I approach a card to the reader it sends the serial number of the card, but the data is different to the read with Hyperterminal on the PC.
[font="'courier new', courier, monospace;"]Hyperterminal  : 02 30 31 30 36 44 30 45 42 32 36 0D 0A 03[/font]
[font="'courier new', courier, monospace;"]Netduino Plus 2: 3F A6 E6 66 E6 F9 EA F6 36 26 CA D6 F2 00[/font]
The number of bytes is correct but the other data is totally wrong.
Any idea?
Thanks for your time!
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 22 January 2013 - 01:43 PM
Do you have a data sheet for the reader and can you post more information about the hardware set up?
For instance, you mentioned that the reader is generating data over RS-232 - the Netduino cannot handle RS-232 data directly as it uses TTL serial logic levels.  So, you have any form of converter in place or is this needed?
#3 Duefectu
Duefectu
  • 34 posts
Posted 22 January 2013 - 03:50 PM
Thanks for your fast response Mark:
Unfortunately, the technical sheet is very poor, only one page without any tech details. But as you say, if Netduino is unable to handle RS-232 data, I thing I need a shield like this http://www.futurlec....32_TTL_3V.shtml to ensure compatibility. Is this correct?
Regards!
#4 Nevyn
Nevyn
  • 1072 posts
Posted 22 January 2013 - 04:29 PM
You would need to confirm the voltage levels on the RFID reader and verify that it is generating RS-232 voltage levels.  If it is then you will need a converter which can output 3.3V levels.  The one you mentioned looks like it operates at 3V rather than 3.3V and there is no link to a datasheet to verify how it works.
Also tagged with one or more of these keywords: serial, serial port, serialport, rs-232
