Issues with Serial Communication
Serial
#1 Cyclone_ZA
Cyclone_ZA
  • 6 posts
  • LocationJohannesburg, South Africa
Posted 22 July 2015 - 05:34 PM
using System.Net;
using System.Net.Sockets;
using System.Text;
using System.IO.Ports;
namespace RF
        public static SerialPort oCom1 = new SerialPort(SerialPorts.COM1, 11520, Parity.None ,8, StopBits.One);
        public static SerialPort oCom2 = new SerialPort(SerialPorts.COM2, 11520, Parity.None, 8, StopBits.One);
        public static Timer timer_SendSignal = new Timer(new TimerCallback(Transmit), null, 3000, 10000);
            oCom2.Open();
            oCom2.DataReceived += oCom2_DataReceived;
                Thread.Sleep(250);
        static void oCom2_DataReceived(object sender, SerialDataReceivedEventArgs e)
            try
                int iBytes = oCom2.BytesToRead;
                Debug.Print("Data Received : " + iBytes + " bytes");
                int iRead_count = 0;
                byte[] rx_byte = new byte[7];
                string counter_string = string.Empty;
                iRead_count = oCom2.Read(rx_byte, 0, 7);
                //Debug.Print("Read Count : " + iRead_count);
                if (iRead_count > 0)// Any Data?
                    for (int i = 0; i < rx_byte.Length; i++)
                        if (rx_byte[i].ToString().Substring(0,1) != "0")
                            counter_string += Encoding.UTF8.GetChars(rx_byte).GetValue(i).ToString();
                    Debug.Print(" > " + counter_string);
                oCom2.Flush();
                Thread.Sleep(250);
            catch (Exception ex)
                //   Debug.Print("Error : " + ex.Message);
        private static void Transmit(object state)
            oCom1.Open();
            oCom1.Write(UTF8Encoding.UTF8.GetBytes("abcdefg"), 0, 7);
            oCom1.Close();
            oCom1.Flush();
            Debug.Print("Transmitted!");
Hi All,
Looking for some help here.
I'm having a frustrating time trying to get basic Serial communication to work.
My ultimate intention is to use a 315mhz RF Kit to send instructions between two Netduino 2 Plus'
I was having trouble getting that to work, so decided to just test basic serial communication to work by simply linking the first Netduino TX (Pin D1 ... Com1) to the RX on the same Netduino (Pin D2).
I keep getting garbage data coming through when the DataReceived event is fired - very seldom am I actually getting the data I'm sending "abcdefg".
It's also sending parts of the message - for example it will send some of the characters like "acdef", etc.
I've tried different baud rates, to no avail.
Above is the basic code I wrote ... Spot anything wrong?
Edited by Cyclone_ZA, 23 July 2015 - 06:29 AM.
Posted 23 July 2015 - 06:22 AM
Hi Cyclone,
I was having trouble getting that to work, so decided to just test basic serial communication to work by simply linking the first Netduino TX (Pin D1 ... Com1) to the RX on the same Netduino (Pin D3).
First things first... Pin D1 and pin D3 are both TX pins. You'll want to connect pin D1 (COM1 TX) to D2 (COM2 RX).
Does that get you started down the right path?
#3 Cyclone_ZA
Cyclone_ZA
  • 6 posts
Posted 23 July 2015 - 06:29 AM
Apologies - typo - I meant to type D1 and D2.
I've also tried using COM3 (D7) - and get the same results.
(I've correct my original post)
#4 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 31 July 2015 - 05:10 AM
This probably has no bearing, but you might want to flush before you close.
Also, if you close the port immediately after sending data, then you may be shutting it down before it has transmitted all the characters in the Tx buffer. I think SerialPort.Write() is non-blocking, I'm not sure how it is implemented in Netduino.
--Tim Long
Also tagged with one or more of these keywords: Serial
