USB To Serial Question
10 replies to this topic
#1 BrianMarkR
BrianMarkR
Posted 21 January 2013 - 08:56 PM
This is the usb converter I have.
http://arduino.cc/en/Main/USBSerial
Can anyone suggest the pin configurations to connect to the mini so I can double-check them?  Can I power the mini from this converter as well?
I've been having all sorts of connection issues, and I would like to verify that I am not having simple driver issues since i'm on Win8.
Thanks in advance
#2 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 22 January 2013 - 06:50 AM
Welcome to the forum!
Arduino stuff uses 5V whereas the Netduino uses 3.3V but I it is 5V tolerant so it should work. Connect your wire list this:
Shield   Netduino mini
5V   Pin 21
GND Pin 23 (or 4)
Rx Pin 11
Tx   Pin12
Applying 5V to Pin 21 will power the board. Also have a look at this:
http://www.netduino....omini/specs.htm
Good luck!
#3 BrianMarkR
BrianMarkR
Posted 22 January 2013 - 04:26 PM
That is how I have it configured.  My issue was software related.  Everything is working now.
Thank You!
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 22 January 2013 - 08:13 PM
Sorry, thought you meant wiring when you said pin config.What turned out to be the problem and how did you solve it?
#5 Sigma7
Sigma7
  • 15 posts
Posted 24 April 2013 - 12:58 PM
Update...
Adafruit makes a "USB Console Cable #954" (a.k.a. "USB-to-TTL Serial Debug Cable") (Newark part 44W3509) that goes for $9.95.  In addition to being low-cost, it also brings out the USB's +5V which you can use to power the Netduino Mini.  It makes the "pay-to-play" price for the Mini about $40 ($30 for the Mini and $10 for the cable).
I used to use a Parallax "Board of Education" (serial or USB versions), but they're pretty pricey ($70 for the board alone, and $100 if you want to get it with a BASIC Stamp 2 module).
The only issue with the #954 cable is that your firmware needs to use USART0 (instead of the DBGU).  I hook it up as follows:
[font="'courier new', courier, monospace;"]AT91SAM7X512 Netduino Mini  Adafruit 954[/font]
[font="'courier new', courier, monospace;"]TXD0 PA1(A)   TX0  DIP 11   white[/font]
[font="'courier new', courier, monospace;"]RXD0 PA0(A)   RX0  DIP 12   green[/font]
[font="'courier new', courier, monospace;"] 5V DIP 21   red[/font]
[font="'courier new', courier, monospace;"] GND  DIP 23   black[/font]
[font="arial, helvetica, sans-serif;"]Regards,[/font]
[font="arial, helvetica, sans-serif;"]Tom[/font]
#6 Dr Who
Dr Who
  • 261 posts
  • LocationNYC
Posted 19 July 2013 - 12:57 AM
Hello!
Oddly enough for connecting to my Mini, I use either a Sparkfun FT232 breakout board, which is still shown as https://www.sparkfun.com/products/718 or the one that was aimed for an Arduino design https://www.sparkfun.com/products/8165 I switched to that breakout board because its easier to combine the whole business onto one breadboard, instead of three. I might switch to their FTDI basic part as soon as I find one. That branded one you showed earlier, is good, but it's aimed towards the brand. Adafruit certainly does. The FTDI parts are the (big) cat's pajamas.
Doctor Who
#7 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 19 July 2013 - 03:16 AM
FYI you can get RS232->TTL converters a lot cheaper, I bought 10 for $14 on ebay...
http://www.ebay.com....984.m1439.l2649
#8 Dr Who
Dr Who
  • 261 posts
  • LocationNYC
Posted 19 July 2013 - 04:26 AM
Hello!
The brand of chipset thus described has a poor reputation amongst a certain community. But okay, I'll allow it.
Doctor Who
#9 baxter
baxter
  • 415 posts
Posted 19 July 2013 - 05:02 AM
You can use one USB-to-TTL cable for either deployment on COM2 or applications on COM1 with a Schmitt trigger inverter circuit on COM2,
http://forums.netdui...x232-interface/
If you want to get fancy, just add a switch to select one function or the other. No need for a USB to RS232 cable and no DB9 connector.
#10 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 19 July 2013 - 05:34 PM
i also wouldnt buy the pl2303.
the cp2102 are very good ones, i use them myself a lot.
the cheap ebay modules are missing the pins for flow control and such, but since i dont use it, i dont care :D
http://www.ebay.com/...=item3a731c735c
500000 bitrate works very well on them, 1million i couldnt get to work (iam not sure if it was the adapter or my uC that made the problem)
(thats nearly 5 times faster than 115200!)
i have 5 or so of them, all are working fine.
btw: my ftdi breakout also works fine, but for the price, idk, i wouldnt buy one again.
edit: they are able to supply 5v and 3.3v at the same time.
#11 Dr Who
Dr Who
  • 261 posts
  • LocationNYC
Posted 11 June 2015 - 05:33 AM
I normally don't like replying to a topic that's older then Methuselah thanks to how the chap who started this off,then, I was able to confirm that I wasn't loosing my touch, and did get my setup to work. And yes it was an FTDI breakout board that did it.
I strongly suspect that there is logic on the board to translate the serial communications properly, such that it knows that we did wire things properly as used on both places.
Besides if there are problems its not the fault of the board, or the fault of the IDE.....
Doctor Who
