Bitwise operations in VB
VB bitwise operations
1 reply to this topic
#1 sHINE
sHINE
  • 13 posts
  • LocationHamburg, Germany
Posted 01 January 2013 - 10:02 PM
Hi there!
As an old vb.net programmer I just reloaded my old netduino classic with the latest Firmware and start writing some test-programs to control my led-matrix mentioned in another thread.
However, I'm stuck at the following code:
Public Sub SetBit(ByRef byteToAlter As Byte, bitPosition As Integer, bitValue As Integer)        Select Case bitValue            Case 1                Dim mask As Byte = 1 << bitPosition 'if bitPosition is 3, mask results in 00001000                 byteToAlter = byteToAlter Or mask            Case 0                Dim mask As Byte = 255 - (1 << bitPosition) ' if bitPosition is 3, mask results in 11110111                 byteToAlter = byteToAlter And mask        End Select    End Sub
This one works fine in VB.net (full Framework) but not in MF. 1 << bitposition is not supported.
If I try to write this part in c# (1 <<= bitPosition) it works as expected.
But I don't want to write the entire stuff in c# (hmm, might be better :)) so it must be possible to do this sort of bitshifting in vb.
Thanks and regards
Jan
#2 baxter
baxter
  • 415 posts
Posted 04 January 2013 - 02:59 AM
Hi Jan,
It works ok for me using firmware 4.2.0.1
	Dim byteToAlter As Byte = 0        Debug.Print("byteToAlter = " & byteToAlter.ToString)        SetBit(byteToAlter, 3, 1)        Debug.Print("byteToAlter = " & byteToAlter.ToString)  '--> 8        SetBit(byteToAlter, 3, 0)        Debug.Print("byteToAlter = " & byteToAlter.ToString)  '--> 0        Debug.Print((247 And 8).ToString)               byteToAlter = 247        SetBit(byteToAlter, 3, 1)        Debug.Print("byteToAlter = " & byteToAlter.ToString) '--> 255        Debug.Print((247 Or 8).ToString)
Baxter
