Automatic Recovery
18 replies to this topic
#1 Charles
Charles
  • 192 posts
Posted 21 November 2010 - 06:48 AM
Is there any way to program the Netduino, N+, etc. to automatically reboot if the code crashes rather than just sitting there waiting for a debugger to connect?
#2 VincentA
VincentA
  • 31 posts
  • LocationIndia
Posted 21 November 2010 - 09:58 AM
I havent got my hands on DNMF yet...but cant you use a global try-catch and on error clean up all resources and restart all the methods ?? (I know you might have thought about it...) So is there any hardware way to reset device? like raising reset(if any) pin to 1 ?
#3 Charles
Charles
  • 192 posts
Posted 21 November 2010 - 03:08 PM
What about this error? http://forums.netdui...-5-serious-bug/ I was hoping for something that could reboot on all errors, not just managed exceptions... Like a watchdog timer. The AT91SAM7X512 has a hardware watchdog timer... Anyone know how to enable it?
#4 VincentA
VincentA
  • 31 posts
  • LocationIndia
Posted 21 November 2010 - 05:17 PM
a stupid idea..... How about connecting reset pin to one of the general IO pin and upon error setting it high? will it work? :blink: :blink: :blink: ( now i am being impatient...cant wait to get my netduino plus :( :( :( )
#5 Chris Walker
Posted 21 November 2010 - 05:53 PM
Vincent, To reset the Netduino/Netduino Plus/Netduino Mini, drive the /RESET line to ground. If you hook up a GPIO to the reset line, create an OutputPort, and set it to false...that should work. Creating a global exception handler (or an exception handling thread) could work too. We could also add a Reset feature to a future firmware release. The function is already built into the firmware...we'd just have to create a wrapper for it. You could also create one and build it into your own custom firmware. The firmware could also be tweaked to activate the hardware reset function in case an exception occurred. Lots of options. Chris
#6 Charles
Charles
  • 192 posts
Posted 21 November 2010 - 10:42 PM
How exactly does one clean up resources in C#??? I can't fine any good way to destroy an object or deallocate memory.
#7 Chris Walker
Posted 21 November 2010 - 11:01 PM
It happens automatically. C# uses garbage collection to clean up resources when memory gets low.
If an object has a Dispose method, you can call it to mark it for cleanup. Also, Debug.GC(true) will clean up any free-able memory.
#8 cross6
cross6
  • 11 posts
Posted 13 November 2011 - 09:53 PM
Does the netduino actually run the .net runtime and do things like garbage collection? That seems like a lot to fit on the mcu, I assumed it just boiled down the .net CIL to the board's mcu?
#9 Chris Walker
Posted 13 November 2011 - 11:52 PM
Hi cross6,
The .NET is a full .NET IL interpreter. It includes a .NET runtime, garbage collection, threading, hardware abstraction, etc. It is a lot to fit on an MCU; it's pretty cool :)
The code that you're running on the Netduino is compact MSIL, interpreted at runtime by .NET MF.
#10 cross6
cross6
  • 11 posts
Posted 14 November 2011 - 12:35 AM
Hi cross6,
Very cool! Thanks.
#11 Dixon
Dixon
  • 32 posts
Posted 16 November 2011 - 07:34 AM
Did you manage to include the Reset function within the firmware? if not, how can we tweak it to activate the reset without need to use a GPIO?
Can the firmware be tweaked to just reset the TCP/IP stack?
#12 Chris Walker
Posted 16 November 2011 - 12:41 PM
Hi Dixon,
Have you tried PowerState.RebootDevice?
http://msdn.microsof...y/ee435764.aspx
The firmware could be tweaked to just reset the TCP/IP stack and the Ethernet PHY, but that might be quite a bit of work.
#13 Valkyrie-MT
Valkyrie-MT
  • 315 posts
  • LocationIndiana, USA
Posted 16 November 2011 - 03:17 PM
Hi Dixon,
Actually, resetting the TCP/IP stack could be quite useful. Along with a watchdog timer and an RTC, but I digress...
-Valkyrie-MT
#14 Chris Walker
Posted 16 November 2011 - 03:29 PM
A bit of info...we're working on an external RTC to plug into the Netduino. Still working out the details.
#15 Arbiter
Arbiter
  • 132 posts
  • LocationBrisbane, Australia
Posted 28 January 2012 - 02:36 PM
-Valkyrie-MT
I use a GPS shield to set the system clock. I've got an object wrapped around the serial port listening to NMEA sentences and updating properties. The first time it sets the DateTime, it also sets the system clock. I don't bother with anything but UTC on a logger; localisation to a timezone is a problem for UI code running on a full scale workstation.
I'm a bit surprised at the lack of a watchdog timer but it's not hard to do; you could knock up something with a MAX6814 to reset the Netduino and keep restarting it from a thread in your program. If the Netduino locks up it will fail to reset the watchdog, so the watchdog will reset the Netduino. I imagine Chris has something like this in mind for the RTC/watchdog he mentions.Of course if Chris does it, the heartbeat thread will probably be neatly hidden in the run-time so that we can all code away in blissful ignorance of occasional inexplicable lockups.
#16 CW2
Posted 28 January 2012 - 05:35 PM
The Netduino microcontroller has only one watchdog timer and that is used by the .NET MF runtime itself, so it is not available for user applications.
#17 Arbiter
Arbiter
  • 132 posts
Posted 31 January 2012 - 01:48 PM
Well there you go. No watchdog did seem unlikely. If it's used by the runtime then I take it framework lockups trigger reset. If so, that's perfect and I'll stop fretting about lockups in the field.
#18 Netd
Netd
  • 4 posts
Posted 10 April 2012 - 12:15 PM
Hello! Is it possible to reset the Netduino Plus with a watchdog? I would like to increase the reliability of a heating system, if the code crashes. Is it possible with the internal watchdog, or an external watchdog must be installed?
#19 Gorf
Gorf
  • 96 posts
Posted 10 April 2012 - 12:45 PM
I'm rebooting my ND+ whenever it fails to connect to its ethernet socket. This is something of a legacy, because it used to hang the whole unit if the connection failed more than a couple of times. Use
PowerState.RebootDevice(true);
