Can't get digital out to work
5 replies to this topic
#1 skarphedinnos
skarphedinnos
  • 26 posts
  • LocationIceland
Posted 30 October 2012 - 04:02 PM
Hi.
static OutputPort D0 = new OutputPort(Cpu.Pin.GPIO_Pin0,false);
while(true)
                                    D0.Write(true);
                                    D8.Write(true);
                                    D1.Write(false);
                                    Thread.Sleep(5000);
                                    SensorValue0 = SensorValue0 + A0.Read();
                                    SensorValue1 = SensorValue1 + A1.Read();
                                    //Thread.Sleep(100);
                                    D8.Write(false);
                                    D0.Write(false);
                                    D1.Write(true);
                                    Thread.Sleep(2000);
The output seems to stay high no matter what.
I have the newest firmware.
I'm probabl missing something super simple.
#2 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 30 October 2012 - 04:18 PM
Hi there,
Its not that obvious:
I think you are using the wrong enumeration for the GPIO pins.
Try Pins.GPIO_PIN_D0 instead of Cpu.Pin.GPIO_Pin0
Hope this helps - Paul
Can't take credit for this, I can never remember what to use.
CW2 posted an example here: forum post
#3 skarphedinnos
skarphedinnos
  • 26 posts
  • LocationIceland
Posted 30 October 2012 - 04:43 PM
Hi there,
That does not work in version 4.2 :/
#4 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 30 October 2012 - 05:01 PM
make sure you have the SecretLabs.NETMF.Hardware.yournetduinotype reference included. also do using SecretLabs.NETMF.Hardware.yournetduinotype; than you can use Pins.blabla
#5 skarphedinnos
skarphedinnos
  • 26 posts
  • LocationIceland
Posted 30 October 2012 - 05:17 PM
I have tried all kind of combinations of using SecretLabs.... and Microsoft.... I finally got it to work, but the method was rather strange. I changed the project to F 4.1 and used "pins." (I got two ND 4.1 and 4.2) That didn't work so I changed back to F 4.2 and switched ND again, and :D. There must be some kind of bug that got fixed during this framwork change. Anyways, thanks guys :)
#6 zemuss
zemuss
  • 69 posts
Posted 30 October 2012 - 08:42 PM
Skar... I am new to the .Net Micro Framework and just new to netduino development all together. What I had to do when upgrading from 4.1 to 4.2 is remove the references then re-add them. It makes sense because the assemblies are in different folders, so if you are using the 4.1 DLLS then the folder path will be C:\Program Files (x86)\Microsoft .NET Micro Framework\4.1. However, if your using 4.2 it will point to the C:\Program Files (x86)\Microsoft .NET Micro Framework\4.2 path. I edited the post because having a DLL folder does not work as expected. I hope this made some sense. "Z"
