Bosch BMP085 Digital Pressure and Temperature Sensor
#21
Posted 06 December 2010 - 01:32 AM
#22
Posted 15 December 2010 - 04:32 PM
... my sensor is reading too low -about 5.4 hPa.
I have received information from a Bosch engineer, who points out that:
- a pressure vessel would be needed to determine the accuracy of the sensor ... local weather stations may be too far away, or their reports to old, to use as a reference
- the calibration of the altimeter I was using is unknown
- the sensor is very accurate but not an "ideal" sensor
- the specification document mentions a possible offset ("up to 1 hPa") as a result of soldering techniques, which would not be included in the on-chip calibration data stored in EEPROM
#23
Posted 15 December 2010 - 10:29 PM
You mentioned on the BMP085 SparkFun product page that this sensor is light sensitive. Can you confirm that this is also true in addition to the other information the engineer provided you?
#24
Posted 20 December 2010 - 09:34 PM
#25
Posted 21 December 2010 - 03:34 AM
I connected the wires as mentioned (I am using the sparkfun board, which has pull-up resistors included). I downloaded all of the necessary files, but it was unable to read from the barometer.
Does anyone have any suggestions as to what I could do?
Zip up your visual studio project and send it to me or post it here. Also take a picture or fritzing schematic of how your hooked up the wires.
#26
Posted 21 December 2010 - 07:19 PM
In case it is not clear in the pictures.
Blue is connected between SDA and Analog 4
Green is connected between SCL and Analog 5
Red is connected between VCC and 3V3
Black is connected between GND and GND
Thank you
John
#27
Posted 22 December 2010 - 06:11 AM
#28
Posted 18 February 2011 - 02:46 PM
I tried using this library and I come up with an error in Class2.cs. Maybe not an error but the exception is thrown on line 83, Could not read from device. I have the code in some existing code that loops once a second in order to get real time results as a vessel is moving. What happens is that it will do the loop 2 or 3 times then throw this exception. Any ideas on why after a couple runs it stops responding?
Here is the code
using System; using System.Text; using System.Net; using System.Net.Sockets; using System.Threading; using System.IO; using System.IO.Ports; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoPlus; namespace BMP085 { public class Program { public static void Main() { OutputPort led = new OutputPort(Pins.ONBOARD_LED, false); SerialPort serialPort1 = new SerialPort("COM1", 57600, Parity.None, 8, StopBits.One); serialPort1.Open(); SerialPort serialPort2 = new SerialPort("COM2", 115200, Parity.None, 8, StopBits.One); serialPort2.Open(); FileStream fs = new FileStream("\\SD\\CTAP.txt", FileMode.OpenOrCreate, FileAccess.Write, FileShare.None, 512); StreamWriter sw = new StreamWriter(fs); while (true) { BMP085 pressureSensor = new BMP085(0x77, BMP085.DeviceMode.UltraLowPower); Debug.Print("BMP085 Pascal: " + pressureSensor.Pascal); Debug.Print("BMP085 InchesMercury: " + pressureSensor.InchesMercury.ToString("F2")); Debug.Print("BMP085 Temp*C: " + pressureSensor.Celsius.ToString("F2")); int GPStoRead = serialPort1.BytesToRead; int CHRtoRead = serialPort2.BytesToRead; if (GPStoRead > 0) { //blink the LED to show we got data led.Write(true); //Thread.Sleep(100); led.Write(false); // get the waiting data byte[] GPSbuffer = new byte[GPStoRead]; serialPort1.Flush(); serialPort1.Read(GPSbuffer, 0, GPSbuffer.Length); serialPort1.Write(GPSbuffer, 0, GPSbuffer.Length); if (GPSbuffer[0] != 36) continue; String GPSMessage = new String(System.Text.Encoding.UTF8.GetChars(GPSbuffer)); Debug.Print(GPSMessage); sw.Write(GPSMessage); } if (CHRtoRead > 12) { int i = 0; //blink the LED to show we got data led.Write(true); //Thread.Sleep(100); led.Write(false); // get the waiting data byte[] CHRbuffer = new byte[CHRtoRead]; serialPort2.Flush(); serialPort2.Read(CHRbuffer, 0, CHRbuffer.Length); serialPort1.Write(CHRbuffer, 0, CHRbuffer.Length); if (CHRbuffer[i] == 's') { //Print final result i = i + 7; int YawVal = (int)((((CHRbuffer[i++] << 8) | CHRbuffer[i++]) << 16) >> 16); String ShowYaw = YawVal.ToString(); double YawCalc = YawVal * 0.0109863; String ShowCalc = YawCalc.ToString("F"); //Debug.Print("Yaw"); //Debug.Print(ShowCalc); int PitchVal = (int)((((CHRbuffer[i++] << 8) | CHRbuffer[i++]) << 16) >> 16); String ShowPitch = PitchVal.ToString(); double PitchCalc = PitchVal * 0.0109863; String ShowPCalc = PitchCalc.ToString("F"); //Debug.Print("Pitch"); //Debug.Print(ShowPCalc); int RollVal = (int)((((CHRbuffer[i++] << 8) | CHRbuffer[i++]) << 16) >> 16); String ShowRoll = RollVal.ToString(); double RollCalc = RollVal * 0.0109863; String ShowRCalc = RollCalc.ToString("F"); //Debug.Print("Roll"); //Debug.Print(ShowRCalc); string CTAP = "$CTAP,Y," + ShowCalc + ",P," + ShowPCalc + ",R," + ShowRCalc + "\r\n"; Debug.Print(CTAP); sw.Write(CTAP); } else { i++; } } Thread.Sleep(1000); } sw.Close(); fs.Close(); } }
#29
Posted 21 February 2011 - 02:42 AM
#30
Posted 21 February 2011 - 06:02 PM
#31
Posted 19 January 2013 - 09:39 PM
Thank you for nice implementation! For anyone using Netduino Plus 2 - there are special pins SD/SC, so A4/A5 is not used anymore. Took me few hours to find out :-)
#32
Posted 21 January 2013 - 06:09 PM
#33
Posted 21 January 2013 - 07:26 PM
Yes, this is documented in the original posts about the release of the ND+2.
I found i2C only worked properly on the Plus 2 with the latest (4.2.2) firmware.
Yes, there are several discussions on the forums about the I2C issues with the initial firmware releases for ND+2. As of 4.2.1.0 these issues should be resolved.
#34
Posted 03 May 2013 - 12:12 AM
I am trying to run your code on a Netduino 2
When the Ic2Bus tries to write to the device it throws a "Could not write to device."
I pulled your code from this post and your code from your IC2 Bus post.
I have triple checked the wiring
I bought the sensor from Adafruit.
any help would be greatly appriciated.
#35
Posted 06 May 2013 - 06:16 PM
Can you post up all of your code if possible so I can take a look.
