Bosch BMP085 Digital Pressure and Temperature Sensor
34 replies to this topic
#1 phantomtypist
phantomtypist
  • 142 posts
Posted 27 October 2010 - 04:39 AM
This managed driver is for the Bosch BMP085 Digital Pressure and Temperature Sensor. This sensor allows you to retrieve the temperature and barometric pressure in both Pascals and Inches of Mercury (InHg). While not coded, you could hypothetically use the data from this sensor alone to calculate your altitude.
This code uses my I2CBus managed driver. You will need the I2CBus.cs file attached in that posting.
I completed this a few weeks ago and I've been testing it to make sure it works.
FYI there is a timer in this driver that takes the readings / measurements every 30 seconds. You can change that as you please. Furthermore, you can remove the timer and make the TakeMeasurements method public so that you can take readings / measurements only when you want or need to. Last, but not least, if you intend to use this sensor and code please read the datasheet. It will definitely help you understand what is going on in the code.
Here is an example of using the code:
    BMP085 pressureSensor = new BMP085(0x77, BMP085.DeviceMode.UltraLowPower);
    Debug.Print("BMP085 Pascal: " + pressureSensor.Pascal);
    Debug.Print("BMP085 InchesMercury: " + pressureSensor.InchesMercury.ToString("F2"));
    Debug.Print("BMP085 Temp*C: " + pressureSensor.Celsius.ToString("F2"));
Here is the code for the driver:
    /// <summary>
    /// Bosch BMP085 digital pressure and temperature sensor.
    /// </summary>
    public class BMP085
        private I2CDevice.Configuration _slaveConfig; // BMP085 I2CDevice configuration
        private const byte ClockRateKHz = 40; // BMP085 clock rate
        // Oversampling for measurements.  Please see the datasheet for this sensor for more information.
        private byte _oversamplingSetting;
        // These wait times correspond to the oversampling settings.
        // Please see the datasheet for this sensor for more information.
        private readonly byte[] _pressureWaitTime = new byte[] {5, 8, 14, 26};
        private const int TransactionTimeout = 1000; //ms
        private Timer _sensorTimer;
        public enum DeviceMode
            UltraLowPower = 0,
            Standard = 1,
            HighResolution = 2,
            UltraHighResolution = 3
        // Calibration data backing stores
        private short _ac1;
        private short _ac2;
        private short _ac3;
        private ushort _ac4;
        private ushort _ac5;
        private ushort _ac6;
        private short _b1;
        private short _b2;
        private short _mb;
        private short _mc;
        private short _md;
        public BMP085(byte address, DeviceMode deviceMode)
            Address = address;
            _slaveConfig = new I2CDevice.Configuration(address, ClockRateKHz);
            _oversamplingSetting = (byte) deviceMode;
            // Get calibration data that will be used for future measurement taking.
            GetCalibrationData();
            // Take initial measurements.
            TakeMeasurements();
            // Take new measurements every 30 seconds.
            _sensorTimer = new Timer(TakeMeasurements, null, 200, 30000);
        /// <summary>
        /// Calculates the compensated pressure and temperature.
        /// </summary>
        private void TakeMeasurements()
            TakeMeasurements(null);
        /// <summary>
        /// </summary>
        /// <param name="state"></param>
        private void TakeMeasurements(object state)
            long x1, x2, x3, b3, b4, b5, b6, b7, p;
            long ut = ReadUncompensatedTemperature();
            long up = ReadUncompensatedPressure();
            // calculate the compensated temperature
            x1 = (ut - _ac6) * _ac5 >> 15;
            x2 = (_mc << 11) / (x1 + _md);
            b5 = x1 + x2;
            _celsius = (float)((b5 + 8) >> 4) / 10;
            // calculate the compensated pressure
            b6 = b5 - 4000;
            x1 = (_b2 * (b6 * b6 >> 12)) >> 11;
            x2 = _ac2 * b6 >> 11;
            x3 = x1 + x2;
            switch (_oversamplingSetting)
                case 0:
                    b3 = ((_ac1 * 4 + x3) + 2) >> 2;
                    break;
                case 1:
                    b3 = ((_ac1 * 4 + x3) + 2) >> 1;
                    break;
                case 2:
                    b3 = ((_ac1 * 4 + x3) + 2);
                    break;
                case 3:
                    b3 = ((_ac1 * 4 + x3) + 2) << 1;
                    break;
                default:
                    throw new Exception("Oversampling setting must be 0-3");
            x1 = _ac3 * b6 >> 13;
            x2 = (_b1 * (b6 * b6 >> 12)) >> 16;
            x3 = ((x1 + x2) + 2) >> 2;
            b4 = (_ac4 * (x3 + 32768)) >> 15;
            b7 = (up - b3) * (50000 >> _oversamplingSetting);
            p = (b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2);
            x1 = (p >> 8) * (p >> 8);
            x1 = (x1 * 3038) >> 16;
            x2 = (-7357 * p) >> 16;
            _pascal = (int) (p + ((x1 + x2 + 3791) >> 4));
        private long ReadUncompensatedTemperature()
            // write register address
            I2CBus.GetInstance().Write(_slaveConfig, new byte[2] { 0xF4, 0x2E }, TransactionTimeout);
            // Required as per datasheet.
            Thread.Sleep(5);
            I2CBus.GetInstance().Write(_slaveConfig, new byte[] { 0xF6 }, TransactionTimeout);
            // get MSB and LSB result
            byte[] inputData = new byte[2];
            I2CBus.GetInstance().Read(_slaveConfig, inputData, TransactionTimeout);
            return ((inputData[0] << 8) | inputData[1]);
        private long ReadUncompensatedPressure()
            I2CBus.GetInstance().Write(_slaveConfig, new byte[2] { 0xF4, (byte) (0x34+(_oversamplingSetting<<6)) }, TransactionTimeout);
            // insert pressure waittime using oversampling setting as index.
            Thread.Sleep(_pressureWaitTime[_oversamplingSetting]);
            byte[] inputData = new byte[3];
            I2CBus.GetInstance().ReadRegister(_slaveConfig, 0xF6, inputData, TransactionTimeout);
            return ((inputData[0] << 16) | (inputData[1] << 8) | (inputData[2])) >> (8 - _oversamplingSetting);
        /// <summary>
        /// Retrieves the factory calibration data stored in the sensor.
        /// </summary>
        private void GetCalibrationData()
            _ac1 = ReadShort(0xAA);
            _ac2 = ReadShort(0xAC);
            _ac3 = ReadShort(0xAE);
            _ac4 = (ushort)ReadShort(0xB0);
            _ac5 = (ushort)ReadShort(0xB2);
            _ac6 = (ushort)ReadShort(0xB4);
            _b1 = ReadShort(0xB6);
            _b2 = ReadShort(0xB8);
            _mb = ReadShort(0xBA);
            _mc = ReadShort(0xBC);
            _md = ReadShort(0xBE);
        private short ReadShort(byte registerAddress)
            I2CBus.GetInstance().Write(_slaveConfig, new byte[] { registerAddress }, TransactionTimeout);
            return (short)((inputData[0] << 8) | inputData[1]);
        private byte _address;
        public byte Address
            get { return _address; }
            private set { _address = value; }
        private int _pascal;
        public int Pascal
            get { return _pascal; }
        public float InchesMercury
            get
                return (float) (_pascal / 3386.389);
        private float _celsius;
        public float Celsius
            get { return _celsius; }
        public void Dispose()
            _sensorTimer.Dispose();
Posted 27 October 2010 - 04:58 AM
It would be cool to submit this data to a web service from the Netduino Plus--and then pull it down from a phone app. Great job.
#3 speedbird
speedbird
  • LocationGermany
Posted 16 November 2010 - 07:54 AM
Hi, I use the Sparkfun BMP085 Breakout. This sensor supports a voltage supply between 1.8 and 3.6VDC. Can i connect the I2C Bus direct to te NETDUNO Ports A4, A5 ? Greetings from germany Thomas
#4 phantomtypist
phantomtypist
  • 142 posts
Posted 16 November 2010 - 02:58 PM
Thomas, for the BMP085 sensor, please connect as follows:
  • The BMP085 ground to any ground pin on the Netduino
  • The BMP085 VCC to the 3.3V pin on the Netduino or any other 3.3V source
  • The BMP085 SDA pin to analog pin 4 on the Netduino
  • The BMP085 SCL pin to analog pin 5 on the Netduino
#5 CW2
Posted 16 November 2010 - 03:12 PM
Also, don't forget pull-up resistors for I2C signal lines: connect both data and clock to 3.3V via ~2 kΩ resistors. The value is not critical, typically 10 kΩ is used for 100 kHz clock, 2 kΩ for higher clock rates, 4.7 kΩ as a reasonable compromise.
#6 phantomtypist
phantomtypist
  • 142 posts
Posted 16 November 2010 - 03:59 PM
If you are using the BMP085 breakout board from SparkFun (and Thomas is) there is no need for pull-up resistors as they are already on the breakout board. Just connect the four pins like I described.
#7 CW2
Posted 18 November 2010 - 07:32 AM
Yes, you are right, SparkFun breakout board already has the pull-up resistors. Sorry for the confusion.
#8 Shaw
Shaw
  • 14 posts
Posted 20 November 2010 - 05:51 AM
Hi there, Great Driver. I have made a few little changes to your code and added some events to send updates back to my main app. Is there any reason why you have the initial TakeMeasurements() call when you also have the timer doing the same thing approx 200ms later? I found in my edited version of the class if let that first one run my events weren't wired up yet - but if I comment it out it works fine - and you only have to wait 200ms for the result anyway. My guess would be that because you're using it in a non-event driven manner that you need to force it to initialise the values?
#9 phantomtypist
phantomtypist
  • 142 posts
Posted 20 November 2010 - 06:00 PM
Hi there,
If you want your driver to talk to your application you can implement an event in the driver and have your application subscribe to it.
I called the TakeMeasurements so that the data is there right after the class is initialized and your application will be able to get data right away.
I would normally only post the basic stuff in a driver (to keep the driver as small as possible) and let people customize it to fit their needs.
#10 phantomtypist
phantomtypist
  • 142 posts
Posted 20 November 2010 - 08:21 PM
Sorry, I totally overlooked that part of your question.
You are actually right! I am not using the driver in a manner that it causes an event to fire and have the application subscribe to that event.
I have a smart home project and the server is polling different sensors at different times. The server will make a request to the sensors and they will in return answer back with the data requested.
There is a lot of complicated logic happening on the server and it only gets data when it's needed. This is why I opted for a pull versus push approach.
But like I said in the previous reply, if it makes sense for you to push the data from the sensor to your application there is no problem in doing so.
PS - If you find any bugs let me know and I'll update the posting.
#11 mluckham
mluckham
  • 6 posts
Posted 01 December 2010 - 10:04 PM
I also have the BPM085 from Sparkfun. I'm finding that the pressure readings do not correspond very closely to local weather reports, even if I apply an altitude compensation to adjust the pressure relative to sea level. BPM085 pressure: 98400 BPM085 temperature: 212 Sea level equivalent for 206 metres altitude: 98873 Weather Underground report: 100500
#12 Shaw
Shaw
  • 14 posts
Posted 02 December 2010 - 12:04 AM
Hmmm that's a bit odd. I've noticed minor variations in my readings but not that much. Could it be a faulty chip?
#13 phantomtypist
phantomtypist
  • 142 posts
Posted 02 December 2010 - 12:30 AM
If everything is hooked up correctly and you compensated for altitude, then the sensor might not have been calibrated correctly at the factory. As Shaw suggested, the sensor could be defective. Contact SparkFun tech support.
P.S. I personally received a defective BMP085 from them. They were more than happy to replace it for me.
#14 Tecchie
Tecchie
  • 23 posts
  • LocationGermany
Posted 02 December 2010 - 06:17 PM
It seems that your compensation is not correct. As a rough estimation one may assume that the pressure decreases by 1hPa per 8 meters.
206 / 8 = 25
984 + 25 = 1009hPa
#15 mluckham
mluckham
  • 6 posts
Posted 03 December 2010 - 02:06 AM
206 / 8 = 25
984 + 25 = 1009hPa
Thanks Tecchie, I am using these calculations:
altimeter_setting = (float)101325*pow(((288-0.0065*known_altitude)/288),5.256);
long pressureASL = (101325 + pressure) - altimeter_setting;
Serial.print(" PressureASLcorrected (Pa): ");
#16 mluckham
mluckham
  • 6 posts
Posted 03 December 2010 - 02:07 AM
Are you located near sea level?
#17 Shaw
Shaw
  • 14 posts
Posted 03 December 2010 - 03:38 AM
Yeah pretty close to sea level - maybe 35m ASL I think. I'll rerun the code and check how much variation there is between my pressure and the nearest weather station. I guess I could drive my netduino out to the airport :)
#18 Tecchie
Tecchie
  • 23 posts
  • LocationGermany
Posted 03 December 2010 - 11:20 AM
The formula is correct:
altimeter_setting = 101325 * pow( 0.99535, 5.256 ) = 98873
pressureASL = (101325 + 98400) - 98873 = 100852
My guess is that your pow function does not calculate a correct value. Check if
pow(0.99535,5.256) = 0.9758
#19 mluckham
mluckham
  • 6 posts
Posted 03 December 2010 - 10:33 PM
Thank you.
Yes, it is correct
Serial.print(" Pow: ");
Serial.print( pow(0.99535,5.256) * 10000, DEC);
produces
9758.0019531250
Today's readings are closer:
Temperature ©: 220
Sensor Pressure (Pa): 99363
Altimeter Setting (Pa): 98873
PressureASLcorrected (Pa): 101815
Wunderground reports 1021 hPa for my location ... so it's much closer today, out only by 3 hPa
Perhaps the higher pressure is a factor.
#20 mluckham
mluckham
  • 6 posts
Posted 05 December 2010 - 10:04 PM
Today I obtained values from an aircraft altimeter ... set to 0 feet it reads 29.34 (993.566 hPa); set to 700 feet it reads 30.05 (1017.61 hPa). The latter agrees with Weather Underground (1017 hPa and rising). The BMP-085 sensor output (after the equations in the datasheet) is 988.10, and corrected to sea level 1012.75. So it seems like the sensor output is 5.466 hPa too low, and as a result the sea level correction is 4.86 too low also. Re-checking my program, I manually substitute the pressure reading from the 0 feet altimeter 993.56 and the sea level corrected output is 1018.08 - which is much closer to the 700 feet altimeter reading, the error is only 0.45 hPa. Re-checking the program calculations from the datasheet, using the datasheet calibration values and input pressure, the output pressure is calculated correctly. So I am forced to conclude my sensor is reading too low -about 5.4 hPa.
