News about Visual Studio 2012 .NETMF Support ?
Posted 05 September 2012 - 05:27 PM
Posted 05 September 2012 - 05:40 PM
Posted 05 September 2012 - 06:33 PM
Posted 06 September 2012 - 05:53 PM
Posted 06 September 2012 - 07:21 PM
Absolutely. I'm running both on my computer.Can VS 2012 and VS 2010 co exist ?
For a long time I was running VS.NET, VS2005, VS2008 and/or VS2010 on my computer. They seem to live well side-by-side.
Posted 27 October 2012 - 12:10 PM
Posted 27 October 2012 - 04:39 PM
We're testing it now. If you don't mind pulling in your own references, you can grab the .NET MF 4.3 beta SDK and be off and running today.Is there any news on netmf and vs2012?
I've been using the .NET MF 4.3 beta SDK (targeting .NET MF 4.2 apps) with VS2012 for a few weeks. Deployment takes longer (and displays more thorough step-by-step details) than before, but it seems to work well.
- pierpox likes this
Posted 28 October 2012 - 10:06 AM
Posted 09 November 2012 - 10:41 AM
Hi Chris what do it mean "targeting .NET MF 4.2 apps"? I installed .NET MF 4.3 beta SDK and Netduino SDK v4.2.1.0 (64-bit) but when I create a new c# project with vs2012 under microframework the only choices are :
1)Class Library
2)Console Application
3)Device Emulator
4)Windows Application
So please can you explain more accurately the procedure to create correctly a netduino plus project with vs 2012 thanks?
Posted 13 November 2012 - 10:40 AM
1)Class Library
3)Device Emulator
I'm having the same issue, no Project Templates available for Netduino (Plus). Do we need to install an updated SDK and if so, where can it be downloaded? Thanks in advance...
Posted 13 November 2012 - 04:59 PM
Posted 23 November 2012 - 08:13 AM
NeonMika.Webserver
> Browse the SD on your N+ directly in the browser and down - and upload files
Posted 25 December 2012 - 02:27 PM
pierpox--the .net framework version targeting options are in project properties.
2Elemental--we're working on a new 4.3 beta SDK which will ship before the end of the year. It will include Netduino templates. For the moment you'll need to create a ".net micro framework console application", switch it to use .net mf 4.2, and then add in the secret labs assemblies manually. Or load a project saved by vs2010.
Hi Chris!
Any News about the new 4.3 beta SDK? I'm asking because I'm waiting my Netduino Plus 2 to arrive and I only have Win8 with VS2012.
I'm anxious to get started with netduino!!!!
Posted 25 December 2012 - 08:38 PM
We're working on VS2012 support. If you'd like to get started with VS2012 now, you can do the following:
1. Install the .NET MF 4.3 SDK (from netmf.codeplex.com)
2. Install the latest Netduino 4.2 SDK (from our Downloads page)
3. Create a .NET Micro Framework "Console Application"
4. Add "SecretLabs.NETMF.Hardware.dll" and "SecretLabs.NETMF.Hardware.Netduino.dll" from the Netduino SDK directory (in \Program Files (x86).
That will effectively do the same thing as the Netduino SDK templates.
You can also be able to install Visual C# 2010 Express side-by-side with VS2012, although I always install VS2010 first.
Posted 03 January 2013 - 04:13 PM
Hi Carlos,
4. Add "SecretLabs.NETMF.Hardware.dll" and "SecretLabs.NETMF.Hardware.Netduino.dll" from the Netduino SDK directory (in Program Files (x86).
Posted 03 January 2013 - 04:27 PM
Change your project to 4.1;
Open your solution in Visual Studio and double click the "Properties"-page underneath your project in the Solution Explorer window. Go to the "Application"-tab. You can both see and change the target framework here.
Posted 03 January 2013 - 04:46 PM
Thanks for reply,I took your advice,but now there is a link error:"Rebooting...
Posted 03 January 2013 - 05:20 PM
Ok now installing netduino sdk 4.1 x64 (I have netduino plus) it works...so I can conclude that with win8(x64)+vs2012 I have to use 4.1 micorframework target+ 4.1 netduino sdk!
#19
Posted 03 January 2013 - 09:45 PM
Just received my Netduino Plus 2 today and it's my first dabble with electronics. Started learning a bit of C# + Web Pages 2 this summer for developing websites and starting to get the hang of that.
This evening been trying to get my first - and what I thought would be an easy - start project running, the BlinkingLed.
What do I have installed:
- Windows 7
- Visual Studio Express 2012 for Windows Desktop
- MS .NET Microframework 4.3
- Netduino SDK v4.2.1.0 (32-bit)
To start the project I did as above, started a c# console application and then manually added the Microsoft.SPOT.Hardware and
Found debugger!Create TS. Loading start at 806a238, end 8085f74Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)Assembly: Microsoft.SPOT.Net (4.2.0.0)Assembly: System (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.IO (4.2.0.0)Assembly: System.IO (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0)Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)Assembly: Microsoft.SPOT.Time (4.2.0.0)Loading Deployment Assemblies.Attaching deployed file.Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Attaching deployed file.Assembly: BlinkingLed (1.0.0.0)Attaching deployed file.Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.2.0.1)Resolving.The debugging target runtime is loading the application assemblies and starting execution.Ready.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2Assemblieslemscorlib.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Native.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Net.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleSystem.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.IO.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleSystem.IO.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.PWM.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.Usb.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesSecret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Diagnostics.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesSecret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.Netduino.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.OneWire.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Time.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Graphics.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:UsersQDocumentsVisual Studio 2012ProjectsNetduinoBlinkingLedBlinkingLedbinDebugleBlinkingLed.exe', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program FilesSecret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.NetduinoPlus.dll', Symbols loaded.The thread '<No Name>' (0x2) has exited with code 0 (0x0).The program '[6] Micro Framework application: Managed' has exited with code 0 (0x0).
And the Output console for Micro Framework Device Deployment was:
Looking for a device on transport 'USB'Starting device deployment...Iteration 0Opening port ?USB#VID_22B1&PID_1000#000000000000#{09343630-a794-10ef-334f-82ea332c49f3}OperationsAttaching debugger engine...... debugger engine attached!Querying device assemblies...Found Assembly mscorlib 4.2.0.0Found Assembly Microsoft.SPOT.Native 4.2.0.0Found Assembly Microsoft.SPOT.Hardware 4.2.0.0Found Assembly Microsoft.SPOT.Net 4.2.0.0Found Assembly System 4.2.0.0Found Assembly Microsoft.SPOT.Hardware.SerialPort 4.2.0.0Found Assembly Microsoft.SPOT.IO 4.2.0.0Found Assembly System.IO 4.2.0.0Found Assembly Microsoft.SPOT.Hardware.PWM 4.2.0.1Found Assembly Microsoft.SPOT.Hardware.Usb 4.2.0.0Found Assembly SecretLabs.NETMF.Diagnostics 4.2.0.0Found Assembly SecretLabs.NETMF.Hardware.Netduino 4.2.1.0Found Assembly Microsoft.SPOT.Hardware.OneWire 4.2.0.0Found Assembly Microsoft.SPOT.Time 4.2.0.0Found Assembly Microsoft.SPOT.Graphics 4.2.0.0Found Assembly BlinkingLed 1.0.0.0Found Assembly SecretLabs.NETMF.Hardware.NetduinoPlus 4.2.0.1Adding pe file C:Program FilesMicrosoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Graphics.pe to deployment bundleAdding pe file C:UsersQDocumentsVisual Studio 2012ProjectsNetduinoBlinkingLedBlinkingLedbinDebugleBlinkingLed.pe to deployment bundleAdding pe file C:Program FilesSecret LabsNetduino SDKAssembliesv4.2lesecretlabs.netmf.hardware.netduinoplus.pe to deployment bundleAttempting deployment...Incrementally deploying assemblies to deviceAll assemblies on the device are up to date. No assembly deployment was necessary.Assemblies successfully deployed to device.Restarting interpreter...Attaching to device...Waiting for device to initialize...
Anyone have any ideas about what is going wrong with my non blinking arduino?
#20
Posted 04 January 2013 - 07:21 PM
