On start up, only pin 3 and pin 7 fire high,
and pin 3 looks like its only 50 percent, but only happens for like 5
seconds. Then the program starts. It looks like a hardware quirk.
Here's the program
namespace Example
public const int SecondMs = 1000;
public const int MinuteMs = 60 * SecondMs;
public const int HourMs = 60 * MinuteMs;
public const int DayMs = 24 * HourMs;
public const int WeekMs = 7 * DayMs;
static OutputPort ph = new OutputPort(Pins.GPIO_PIN_D2, true);
static OutputPort b = new OutputPort(Pins.GPIO_PIN_D3, true);
static OutputPort a = new OutputPort(Pins.GPIO_PIN_D4, true);
static OutputPort drain = new OutputPort(Pins.GPIO_PIN_D5, true);
static OutputPort solenoid = new OutputPort(Pins.GPIO_PIN_D6, true);
static OutputPort heater = new OutputPort(Pins.GPIO_PIN_D7, true);
static OutputPort controller = new OutputPort(Pins.GPIO_PIN_D8, true);
public delegate void VoidAction();
try
Method_1();
AwaitCompletionOf(new VoidAction[] { Method_2,
Method_3, Method_4, Method_5 });
AwaitCompletionOf(new VoidAction[] { Method_6, Method_7 });
Method_8();
Thread.Sleep(10000);
catch
//Something has gone wrong; reset to a safe condition
void RunTheStuff()
public static void Method_1()
drain.Write(false);
Thread.Sleep(16 * MinuteMs);
drain.Write(true);
public static void Method_2()
solenoid.Write(false);
solenoid.Write(true);
public static void Method_3()
a.Write(false);
Thread.Sleep(11 * MinuteMs + 7 * SecondMs);
a.Write(true);
public static void Method_4()
b.Write(false);
Thread.Sleep(6 * MinuteMs + 3 * SecondMs);
b.Write(true);
public static void Method_5()
ph.Write(false);
Thread.Sleep(3 * SecondMs);
ph.Write(true);
public static void Method_6()
controller.Write(false);
Thread.Sleep(1 * SecondMs);
controller.Write(true);
Thread.Sleep(10 * MinuteMs);
public static void Method_7()
heater.Write(false);
for (int i = 0; i < 14; i++)
Thread.Sleep(20 * SecondMs);
Thread.Sleep(1 * DayMs);
heater.Write(true); // added this
public static void Method_8()
drain.Write(false);
Thread.Sleep(30 * MinuteMs);
public static void AwaitCompletionOf(VoidAction[] actions, int
millsecondsTimeout = -1)
ManualResetEvent mre = new ManualResetEvent(false);
Thread t = null;
int total = 0;
int target = actions.Length;
for (int i = 0; i < target; i++)
if (null != t)
t.Start();
int captured = i;
t = new Thread(() =>
try
actions[captured]();
finally
if (Interlocked.Increment(ref total) == target)
mre.Set();
if (null != t)
t.Start();
mre.WaitOne(millsecondsTimeout, false);
hardware quirk and bugs
Started by perkunas, Apr 12 2012 12:31 PM
6 replies to this topic
Posted 12 April 2012 - 12:31 PM
Posted 12 April 2012 - 01:13 PM
How do you determine this?
IIRC, on startup the microcontroller uses all pins as input with pullup enabled, then, after the startup-routine (bootloader and so on) is finished, the program starts ... so what's in your code will not take effect immediately after boot.
Posted 12 April 2012 - 02:19 PM
"IIRC, on startup the microcontroller uses all pins as input with pullup enabled, then, after the startup-routine (bootloader and so on)"
Not sure what that means, but I'm using optical relays, and I need them to all fire up on on startup
off is On and On is off with them.
As I understand it they all fire on on startup which is fine by me, but that's not happening.On start up Only pin 3 and pin 7 fire high,and pin 3 looks like its only 50 percent. So it's not correct its got to be some sort of glitch in the bootloader.
I used a row of Leds to test it
Posted 12 April 2012 - 03:41 PM
What "input with pullup" means is that there effectively is a resistor between 3v3 & the pin. This resistor limits the current, so using leds to check is not adequate (the current might simply be so low that you don't see the led lighting up), you need a scope or a fast multimeter to check.
There is also no way to turn a digital ouput on 50%.
Posted 12 April 2012 - 03:56 PM
ok but the real question is whats the price of soup in China.
Maybe this wont make me any problems, or should I even care; as I'm using optical relays and essentially they are all just leds.Guess I have to hook it all up and try it 1st but that's not going to happen soon. The rest of the programs fine I haven't tested it all yet but looks ok.
Posted 12 April 2012 - 04:03 PM
Hi Perkunas,
Quite often other hardware (shields, breakout boards, etc.) attached to the Netduino causes strange behaviour. I would re-test with nothing connected to the Netduino apart from a voltmeter to read the level on the pins in question.
Pins 2, 3 and 7 are the high(er) current pins, this probably explains why the behaviour on these is different. See CW2's Wiki page How much current can I draw from Netduino? for a list of pins and what they can drive.
At start-up, the voltage on the pins will go high, but they are only driven high by a weak pullup resistor. This limits the amount of current that will be sourced from the pins. It is (sometimes annoyingly
) enough to drive logic gates and transistors ON, but is unlikely to be enough to drive a bigger load such as an LED.
I think you may be better off using a buffer chip (e.g. Octal buffer/line driver 74HCT541) or (npn) transistors to drive the LEDs.
Hope this helps - Paul
EDIT: I was typing this while Stefan W. was replying - I'm too slow!
- Dan Morphis and Stefan W. like this
Posted 12 April 2012 - 06:26 PM
You weren't too slow, your post has more helpful information than mine
and your suggestion about not driving optocouplers/LEDs directly is certainly right.
