Data logger
12 replies to this topic
#1 Zeus
Zeus
  • 8 posts
  • LocationIsrael
Posted 10 April 2012 - 08:58 AM
Hello,
I am trying to write some sensor data on SD card in a csv file.
But in the file I don't see all collected values, rather the last (just one set of three values).
Please correct.
using System.Net;
using System.Net.Sockets;
using System.IO;
using System.Text;
namespace Integration
        private const int MaximumValue = 1023;
        private const int AnalogReference = 5;
            AnalogInput no2Sensor = new AnalogInput(Pins.GPIO_PIN_A1);
            AnalogInput coSensor = new AnalogInput(Pins.GPIO_PIN_A2);
            AnalogInput o3Sensor = new AnalogInput(Pins.GPIO_PIN_A3);
                int digitalValue1 = no2Sensor.Read();
                float analogValue1 = (float)digitalValue1 / MaximumValue * AnalogReference;
                int digitalValue2 = coSensor.Read();
                float analogValue2 = (float)digitalValue2 / MaximumValue * AnalogReference;
                int digitalValue3 = o3Sensor.Read();
                float analogValue3 = (float)digitalValue3 / MaximumValue * AnalogReference;
                Debug.Print("NO2 value:\t" + analogValue1.ToString() + "\nCO Value:\t" + analogValue2.ToString() + "\nO3 Value:\t" + analogValue3.ToString());
                using (StreamWriter sw = new StreamWriter(@"SD\file.csv"))
                    sw.Write(analogValue1.ToString() + "," + analogValue2.ToString() + "," + analogValue3.ToString());
                    sw.Write("\n");
                    sw.Flush();
                    sw.Close();
                Thread.Sleep(1000);
Thanks.
Z
#2 Paul Csiki
Paul Csiki
  • 8 posts
  • LocationDublin, Ireland
Posted 10 April 2012 - 09:43 AM
Hello, What is the output of the Debug.Print? Do all three values show up? Also I don't recommend you to create / dispose StreamWriters like that, it's better to leave one active, write data to it, flush, then close it, on the next loop you open, write, flush, close (repeat). Normally everything should work if analogValue1,2,3 have correct values. Cheers.
#3 CW2
Posted 10 April 2012 - 10:25 AM
PaulCsiki is right, you should leave the stream open (and preferably flush it after each write). Because every time you create a new instance of StreamWriter class, the file is overwritten if it exists.
#4 Gorf
Gorf
  • 96 posts
Posted 10 April 2012 - 12:52 PM
My code from my solar inverter log routine:
if (!File.Exists(LogFileName))
    using (StreamWriter writer = new StreamWriter(LogFileName, true))
        writer.WriteLine("Time\tInverter\tTotal today (kWh)\tTotal this month (kWh)\tTotal since install (kWh)\tTotal this year (kWh)\tOutput now (W)");
strTemp = DateTime.Now.TimeOfDay.ToString();
strTemp = strTemp.Substring(0, strTemp.IndexOf("."));
    writer.WriteLine(strTemp + "\t" + InverterData);
I've not bothered logging the date - that's in the filename, and LogfFileName is changed every day.
#5 Paul Csiki
Paul Csiki
  • 8 posts
Posted 11 April 2012 - 10:13 AM
Hello,
Here is how I would do it.
using System.Net;
using System.IO;
using System.Text;
        private static StreamWriter sw;
            sw = new StreamWriter(@"SD\file.csv");
                try
                    sw.Write("\n");
                    sw.Flush();
                    Thread.Sleep(1000);
                catch (Exception)
                    sw.Close();
                    sw.Dispose();
                    break;
#6 Zeus
Zeus
  • 8 posts
  • LocationIsrael
Posted 11 April 2012 - 11:10 PM
First of all, sorry for late reply. Second, thanks all and especially Paul. Tomorrow I will check the code and update in here. Best, Z
#7 Zeus
Zeus
  • 8 posts
  • LocationIsrael
Posted 12 April 2012 - 02:55 PM
Yes! This code works for logging data unto SD card. I also have an RTC - DS1307, I need to log the time in the CSV file corresponding to analog pin values. I have set time of RTC already using Arduino. With Netduino I only want to read and log time. Please help. Thanks. Best, Z
#8 Paul Csiki
Paul Csiki
  • 8 posts
Posted 12 April 2012 - 03:16 PM
Hello, Glad it worked. To get time you will need to do a DateTime.Now.ToString() however this clock will start ticking from the moment you start your board. If you want to have current time and date either you buy a wifly wireless shield and module to give it wifi access to internet in order to get RTC from a NTP server, or you buy a netduino plus to connect it to internet via an ethernet cable and you connect manually to a ntp server via sockets. Also if you want to avoid doing all that you need a RTC (Real Time Clock) module attached to your netduino. Good Luck, Paul.
#9 Zeus
Zeus
  • 8 posts
  • LocationIsrael
Posted 12 April 2012 - 03:35 PM
Hi, I have RTC already. I bought DS1307 from Sparkfun. SDA and SCL are meant for analog pins 4 and 5. That I have figured out already but I am looking for a way to read time from this RTC module. Thanks. Z
#10 Cabadam
Cabadam
  • 90 posts
Posted 12 April 2012 - 07:05 PM
Thanks.
Z
There's a post about using that device here: http://forums.netdui...eal-time-clock/
#11 Cabadam
Cabadam
  • 90 posts
Posted 12 April 2012 - 07:16 PM
And Stefan wrote up an article on the wiki if you run into questions regarding the hardware connections: http://wiki.netduino...k-Breakout.ashx
#12 Zeus
Zeus
  • 8 posts
  • LocationIsrael
Posted 23 April 2012 - 07:24 PM
I added here some more lines to add more sensors on analog pins. Unfortunately, when Netduino is plugged with wall wart, no data is written to SD card.
It only creates the file.
But when I debug the code and run, it logs data on SD card.
Kindly correct.
Thanks.
Z
using System.Net;
using System.IO;
using System.Text;
            AnalogInput no2Sensor = new AnalogInput(Pins.GPIO_PIN_A0);
            AnalogInput coSensor = new AnalogInput(Pins.GPIO_PIN_A1);
            AnalogInput o3Sensor = new AnalogInput(Pins.GPIO_PIN_A2);
            AnalogInput e_no2Sensor = new AnalogInput(Pins.GPIO_PIN_A3);
            AnalogInput e_noSensor = new AnalogInput(Pins.GPIO_PIN_A4);
            AnalogInput e_coSensor = new AnalogInput(Pins.GPIO_PIN_A5);
            OutputPort led = new OutputPort(Pins.GPIO_PIN_D8, false);
                try
                    int digitalValue4 = e_no2Sensor.Read();
                    float analogValue4 = (float)digitalValue4 / MaximumValue * AnalogReference;
                    int digitalValue5 = e_noSensor.Read();
                    float analogValue5 = (float)digitalValue5 / MaximumValue * AnalogReference;
                    int digitalValue6 = e_coSensor.Read();
                    float analogValue6 = (float)digitalValue6 / MaximumValue * AnalogReference;
                    Debug.Print("NO2 value:\t" + analogValue1.ToString() + "\nCO Value:\t" + analogValue2.ToString() + "\nO3 Value:\t" + analogValue3.ToString() + "\ne_NO2 value:\t" + analogValue4.ToString() + "\ne_NO Value:\t" + analogValue5.ToString() + "\ne_CO Value:\t" + analogValue6.ToString());
                    sw.Write(analogValue1.ToString() + "," + analogValue2.ToString() + "," + analogValue3.ToString() + "," + analogValue4.ToString() + "," + analogValue5.ToString() + "," + analogValue6.ToString());
                    sw.Write("\n");
                    sw.Flush();
                    led.Write(true);
                    Thread.Sleep(295);
                    led.Write(false);
                    Thread.Sleep(500);
                catch (Exception)
                    sw.Close();
                    sw.Dispose();
                    break;
#13 Zeus
Zeus
  • 8 posts
  • LocationIsrael
Posted 23 April 2012 - 09:09 PM
Well, I figured out the problem.
Here is the updated code.
using System.Net;
using System.IO;
using System.Text;
                using (StreamWriter sw = new StreamWriter(@"SD\file.csv", true))
                    sw.Write("\n");
                    sw.Flush();
                    sw.Close();
                    led.Write(true);
                    Thread.Sleep(295);
                    led.Write(false);
                    Thread.Sleep(50);
