DS1307 Real Time Clock
41 replies to this topic
#1 stacyh3
stacyh3
  • 47 posts
Posted 26 August 2010 - 10:15 PM
Attached is some code for using the DS1307 Real Time Clock chip via the I2C bus. The code includes a simple test application. Nothing facny, but it works. It also shows the use of extension methods which are pretty handy. The code comments include instructions on connecting the DS1307. Also, I scavanged an old ribbon cable and soldered one end to the SparkFun breakout board for the clock chip. I added pins to the other end to make is easy to use for prototyping. I figured that when I mounted this into a project box, it would be handy as well since it will allow easy access to the backup battery. Enjoy! Stacy
#2 StefanoZ
StefanoZ
  • 16 posts
Posted 13 December 2010 - 09:44 PM
Hi stacyh3,
good project. I used it and it works fine. I had to add two pullup resistors (one 2.2K between SDA and +5, one 2.2K between SCL and +5) as indicated in the ds1307 datasheet.
I used this module
Thank you for your project.
Bye,
Stefano.
#3 mrxer
mrxer
  • 54 posts
  • LocationAustralia
Posted 22 December 2010 - 01:52 PM
Hi stacyh3,
I used this module
Bye,
Stefano.
How do i determine the address of the DS1307?
tony
#4 CW2
Posted 22 December 2010 - 01:57 PM
According to the datasheet (pdf), the address is 0x68 (b1101000).
#5 mrxer
mrxer
  • 54 posts
  • LocationAustralia
Posted 22 December 2010 - 02:39 PM
thanks CW2....another question....
private const int I2CAddress = 0x68;
        private const int I2CTimeout = 1000;
        private const int I2CClockRateKhz = 100;
        public const int UserDataAddress = 8;
        public const int UserDataLength = 56;
        private I2CDevice clock = new I2CDevice(new I2CDevice.Configuration(I2CAddress, I2CClockRateKhz));
I have seen that i need to connect the DS1307 to Analog Pin 4 and 5. Is this hardcoded? The configuration does not specify which pins to use or are these the only ones that support i2c?
thanks in advance
tony
#6 CW2
Posted 22 December 2010 - 02:56 PM
Yes, it is hardcoded. You can see in the schematic that the I2C signal lines are multiplexed with analog inputs and accessible via Analog Input pins 4 and 5. The microcontroller has only one I2C hardware module - it would be possible to implement "software" I2C on any two pins, but it would require native driver; another option could be to use an expander or bus converter IC...
#7 mrxer
mrxer
  • 54 posts
  • LocationAustralia
Posted 22 December 2010 - 03:08 PM
Sorry for all the questions as i am using the code above but its not working. Do i need to connect a battery if it connect to 5V? When it gets to this code
public DateTime Now()
            var data = new byte[7];
            int result = Read(0, data);//*******Returns 1 and data has all zeros in it
            //TODO: Add exception handling if result == 0
tony
#8 GDSever
GDSever
  • 81 posts
  • LocationNewark, DE
Posted 23 December 2010 - 01:39 AM
The battery is backup in case the 5V is disconnected. If the battery is not present, this pin must be grounded or the DS1307 won't work... I found that out the hard way a few years ago...
#9 mrxer
mrxer
  • 54 posts
  • LocationAustralia
Posted 23 December 2010 - 04:11 AM
thanks for your advice..got it working...mmm...and also make sure your track don't touch each other. I am using a vero board and using screw driver to break tracks...drill might be better
tony
#10 Doctor Bit
Doctor Bit
  • 14 posts
Posted 12 October 2011 - 03:55 PM
Me too... anybody find the solution? Thank You.
Alberto.
#11 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 12 October 2011 - 05:15 PM
Alberto.
how did you connect it? Did you include a 5V battery?
#12 Doctor Bit
Doctor Bit
  • 14 posts
Posted 14 October 2011 - 08:01 AM
I connect the module:
SDA -> Netduino Analog Pin 4
SCL -> Netduino Analog Pin 5
GND -> Netduino GND
Vcc -> Netduino 5V
And also I connect 2 resistors (2.2 Khm):
SDA --> 2.2 Khm resistor --> Vcc
SCL --> 2.2 Khm resistor --> Vcc
And also include the CR2032 battery on the slot
But doesn't work... :(
P.S. I translate the C# code in VB...
Alberto.
#13 Mario Vernari
Posted 14 October 2011 - 08:45 AM
Alberto, have a peek at this thread.
#14 zelphia
zelphia
  • 6 posts
Posted 30 December 2011 - 08:13 PM
I have successfully run this demo software on a Netduino Plus. I used 1k pullup resistors to 3.3 volts for the I2C / Sq Wave pins. Powered the DS1307 with 5v. Changed '...Netduino' to ...'NetduinoPlus' at the top, and voila! The DS1307 came from SparkFun.
#15 boez52
boez52
  • 15 posts
Posted 09 October 2012 - 08:38 PM
I am trying to set the time of the RTC using a NTP server once a month. Any Ideas?
#16 Chris Walker
Posted 03 November 2012 - 10:26 PM
Hi boez52,
Are you struggling with getting the time from an NTP server...or setting the time of the RTC?
#17 boez52
boez52
  • 15 posts
Posted 04 November 2012 - 02:00 AM
Hi boez52,
Neither, I got it working a few weeks ago
#18 Chris Walker
Posted 04 November 2012 - 02:16 AM
Okay cool. Sorry that I didn't see this post until today. Thank you for the update.
#19 upstream
upstream
  • 8 posts
  • LocationBrasil
Posted 31 December 2012 - 07:24 PM
Hi.
Just to say this code worked fine to me after I set up clock. I was getting exceptions on mscorlib due weird values on DS1307. I think...
I used this code on Netduino plus, latest firmware and an Arduino module Tiny RTC with an extra AT24C32 memory on I2C bus, 3.3K ohms pull ups.
Many thanks!
"- Somewhere there's a bug to fix..."
#20 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 31 December 2012 - 07:43 PM
i also have written some ds1307 code.
it can be found here: http://forums.netdui...ground/?p=41558
it also shows how to access the ds1307 sram.
greetings
