What's feasible and what's not
Posted 25 September 2010 - 01:58 AM
Posted 25 September 2010 - 03:00 AM
Posted 25 September 2010 - 03:21 AM
Thank you, Mark. Your message is very helpful because it starts to give me a sense of what I am looking for in a chip. So, it seems that I could use the chip I mention if my microprocessor I had came with "1 Wire" support. Is that something that would be flagged as a feature of a microprocessor?Unfortunately, Netduino doesn't appear to support 1 Wire, so you'd want to look for an i2c, spi or analogue output temperature sensor.
Something like a LM60 from National or a TMP36 from Analog are examples of analogue output sensors.
Similarly, what clues might I look for when I review the datasheet for, say, the LM60 or the TMP36. I look at those and I don't see anything that leaps out at me as "Yes - Netduino supports that!!!". I guess I am trying to figure out what the relevant standards/features that are important as I search around for a solution. Is it maybe the fact that the chips you mention seem "passive" in nature, meaning they just emit their information on certain pins and, providing I can connect to and interpret the high/low values from the Netduino then I am OK (as opposed to the device I mentioned which seems to have a full-fledged "command interface").
Thanks again.
Posted 25 September 2010 - 03:37 AM
Thanks again.
Actually, there's firmware (by CW2) for the Netduino that supports onewire. And SL is rolling his code into the main codebase I believe.
Posted 25 September 2010 - 04:14 AM
I guess I'm still not getting exactly what 1 Wire actually is. Is it a protocol that defines the physical characteristics of the protocol (I see references to pulse duration and amplitude, for example). Or is it more at the application layer (I see comments about commands that I can send).Actually, there's firmware (by CW2) for the Netduino that supports onewire. And SL is rolling his code into the main codebase I believe.
Anyway, that's more a curiosity. At this stage I'm interested in what is available to me with the default Netduino firmware (I'll think about upgrading at some later stage). Let's say I am looking for a temperature sensor. What exactly is it in a datasheet that will leave me able to state whether I can get this working on the Netduino? I'm not so much interested in a specific recommendation for a sensor here (although the pointers were appreciated). I'm just trying to get my head around the characteristics I'd need to look for when hunting down a chip/solution I might use in my project. For example, with the two suggested already other than being told that they work I don't know how to check that for myself.
BTW, it could be that my understanding will be clearer if I understand what I2C or UARTs are and how they are used. I asked about this last week but didn't really get any pointers to stuff I can read as to actually use these ports.
Thanks again.
Posted 25 September 2010 - 08:10 AM
Mark, have you tried Wikipedia or Google?BTW, it could be that my understanding will be clearer if I understand what I2C or UARTs are and how they are used. I asked about this last week but didn't really get any pointers to stuff I can read as to actually use these ports.
Posted 25 September 2010 - 09:22 AM
Posted 25 September 2010 - 01:33 PM
Yes, I uses these resources :-) I've been looking at a number of places but, again, it's the Netduino context I am looking for. By way of example, the DS18S20 is, I am told, not considered suitable for the Netduino. The fact that it uses 1 Wire (and the Netduino - without firmware updates - doesn't support this) seems to be the data point that I should be looking for. OK, I'll buy that :-)Wikipedia can be a really great resource for understanding what different protocols mean, usually the articles are high level enough that most people with basic electronics knowledge can understand them and if you need more information you'd be able to go to google to look for specifics.
1 wire is just a protocol for systems to communicate, like i2c, CAN, SPI, TTL and RS232 among others are.
But what about the two that have been suggested (the LM50 and the TMP36)? As far as I can tell, the data sheets don't have any references to I2C or CAN or SPI or TTL, etc, etc. So, it doesn't seem to be as structured as looking for a protocol that Netduino uses and seeing if I can find it in the datasheet. If I look at the TMP36 datasheet, for example, what is it about that which tells you this could work on a Netduino. Also, does the fact that a chip (like the DS18S20) supports 1 Wire and the Netduino doesn't simply mean that there's no way to get it to work? Or is 1 Wire just one option, but not a requirement?
And finally, let's take the TMP36 example again. If it's deemed feasible for the Netduino I'm still not sure how I'd actually use it. The 1 Wire approach seems to require more of a formalized "command protocol". I don't see such an approach with the TMP36. Does this just mean that I merely respond to pin changes (high/low) with this and don't use commands?
Thanks.
Posted 25 September 2010 - 01:49 PM
"The TMP35/TMP36/TMP37 are low voltage, precision centi-grade temperature sensors. They provide a voltage output that is linearly proportional to the Celsius (centigrade) temperature." This means the microcontroller has to have an analog input that can measure voltage - this feature is known as Analog to Digital Converter (ADC) and Netduino has its 10-bit ADC accessible via 8 pins labeled "Analog In 0 .. 7", you can use AnalogInput class and its Read() method to get the digital value of measured voltage on a certain pin (the value in range [0, 1023] represents voltage [0, Aref]). Hope this helps.If I look at the TMP36 datasheet, for example, what is it about that which tells you this could work on a Netduino.
Posted 25 September 2010 - 01:59 PM
That's EXACTLY what I was looking for - gives me that specific context that ties the features of the chip to the functionality of the Netduino. I really appreciate this."The TMP35/TMP36/TMP37 are low voltage, precision centi-grade temperature sensors. They provide a voltage output that is linearly proportional to the Celsius (centigrade) temperature." This means the microcontroller has to have an analog input that can measure voltage - this feature is known as Analog to Digital Converter (ADC) and Netduino has its 10-bit ADC accessible via 8 pins labeled "Analog In 0 .. 7", you can use AnalogInput class and its Read() method to get the digital value of measured voltage on a certain pin (the value in range [0, 1023] represents voltage [0, Aref]). Hope this helps.
BTW, having looked at I2C a little more, I'd be interested in any Netduino-specific details on how I might use it (samples, etc).
Thanks.
Posted 27 September 2010 - 07:15 AM
Please use forum's search box to look for "I2CDevice", there are several code samples already published. Also note the current Netduino firmware does not support "Repeated Start Bit" condition, which is required by certain I2C devices to read data from them - for more details, have a look at I2C Driver Improvement post.BTW, having looked at I2C a little more, I'd be interested in any Netduino-specific details on how I might use it (samples, etc).
