I2C Driver Improvement
5 replies to this topic
#1 CW2
Posted 16 September 2010 - 09:30 PM
This is a follow-up to missing start bit in I2C communication post. I have been able to successfully get the temperature reading from Melexis MLX90614 IR Thermometer by hardcoding the internal address in the firmware, namely MasterXAction_Start function method:
// DeviceCode\Targets\Native\AT91\DeviceCode\AT91_I2C\AT91__I2C.cpp, line 123
if (g_AT91_I2C_Driver.m_currentXActionUnit->IsReadXActionUnit())
  address |=  AT91_I2C::TWI_MMR_MREAD_R ;
  // Experimental: Master Read with hardcoded IADR -> repeated start bit
  address |= AT91_I2C::TWI_MMR_IADRSZ_1;  // Size = 1
  I2C.TWI_IADR = 0x7;                     // Melexis RAM Tobj1 Address
Although this fits my particular needs, it obviously cannot be used as a general solution. After a bit of further investigation, it seems to be possible to modify the I2CDevice::Execute() method (in spot_hardware_native_Microsoft_SPOT_Hardware_I2CDevice.cpp) to examine the list of transactions and replace Write+Read sequences with a Read transaction that takes the buffer from preceding Write transaction and sets it as internal address (up to three bytes supported). The internal address can be stored in new attributes of I2C_HAL_XACTION structure and the value can be set to TWI registers in AT91_I2C_Driver::MasterXAction_Start.
Note: I focused on the native layer, because most of the managed classes are sealed and modification would result in a need to rebuild and distribute the whole SDK (managed dlls) along with the firmware.
If anyone is interested in doing this (perhaps in a completely different/much better way), I will be glad to provide more detailed information and I can test the code - unfortunately, I cannot do it by myself right now, because I am busy finishing OneWire support.
#2 phantomtypist
phantomtypist
  • 142 posts
Posted 12 October 2010 - 05:35 AM
Any updates on the progress of implementing a fix for this problem?
#3 CW2
Posted 08 November 2010 - 08:36 PM
I have just published I2CDevice extension (firmware and managed dll) that supports Repeated Start condition.
#4 Chris Walker
Posted 28 December 2010 - 01:59 AM
Update: based on CW2's contribution, this feature has been incorporated into the v4.1.1 alpha 4 firmware, which will be posted by 12/31/2010.
#5 madartsoft
madartsoft
  • 19 posts
Posted 08 January 2011 - 10:54 AM
Hi, When the new firmware with mentioned I2CDevice support will be available?
#6 Fred
Fred
  • 302 posts
  • LocationUK
Posted 08 January 2011 - 01:36 PM
Already available (and updated to alpha 5) here.
