using System; using System.Collections; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.Netduino; using Servo_API; namespace Accelerometer_Example { public class Program { // Define our accelerometer inputs static AnalogInput accX; static AnalogInput accY; static AnalogInput accZ; static Servo servoX; static Servo servoY; static ArrayList stackX; static ArrayList stackY; static int capacity = 5; public static void Main() { // Create the Inputs accX = new AnalogInput(Pins.GPIO_PIN_A0); accY = new AnalogInput(Pins.GPIO_PIN_A1); accZ = new AnalogInput(Pins.GPIO_PIN_A2); servoX = new Servo(Pins.GPIO_PIN_D5); servoY = new Servo(Pins.GPIO_PIN_D6); stackX = new ArrayList(); stackY = new ArrayList(); servoY.inverted = true; while (true) { Debug.Print("X:" + accX.Read().ToString() + " Y:" + accY.Read().ToString() + " Z:" + accZ.Read().ToString()); MoveAvgX(accX.Read()); MoveAvgY(accY.Read()); Thread.Sleep(10); } } public static void MoveAvgX(int x) { stackX.Add(x); if (stackX.Count > capacity) stackX.RemoveAt(0); int avg = 0; for (int i = 0; i < stackX.Count; i++) { avg += int.Parse(stackX[i].ToString()); } avg = avg / stackX.Count; servoX.Degree = servoX.map(avg, 400, 600, 0, 180); } public static void MoveAvgY(int y) { stackY.Add(y); if (stackY.Count > capacity) stackY.RemoveAt(0); int avg = 0; for (int i = 0; i < stackY.Count; i++) { avg += int.Parse(stackY[i].ToString()); } avg = avg / stackY.Count; servoY.Degree = servoY.map(avg, 400, 600, 0, 180); } } }
Servo Jitters
Posted 04 March 2012 - 07:38 AM
Posted 04 March 2012 - 02:23 PM
Posted 04 March 2012 - 06:15 PM
Posted 04 March 2012 - 06:36 PM
Posted 04 March 2012 - 06:43 PM
Posted 04 March 2012 - 06:44 PM
I have not measured it, but IMHO you can speed up the code a little bit by replacing Parse() with cast:Still shaky but now extremely slow.
avg += (int)stackX[i];Also, you might consider changing avg type to long to avoid overflow and Queue instead of Stack.
What accelerometer do you use?
Posted 05 March 2012 - 05:10 AM
Posted 05 March 2012 - 06:38 AM
Posted 05 March 2012 - 06:41 AM
Posted 05 March 2012 - 04:12 PM
Here is the sensor link...
http://www.adafruit.com/products/163
It takes me to a data sheet with the following image...
I'm not very intuitive in reading electronic symbol diagrams, but those resistors look built in to me. Looks like 4 capacitors needed? will ceramic 0.1uf do the trick?
Posted 05 March 2012 - 07:39 PM
Yes you are correct - the resistors are actually part of the chip.
Are you using the breakout board shown at the link?
I am guessing that you are as that device would be a bugger to solder on its own!
If not then congratulations on the soldering skills, and yes you will have to add the four capacitors. The diagram does not show polarised capacitors (no + symbol) - so ceramic should be OK. They should be fitted near the device.
The breakout board has all the capacitors fitted already, so assuming that is what you are using, you don't need to add anything else. It also has a voltage regulator.
3Vo is the output from the on-board regulator, you could use it to drive the Aref input on the Netduino. Once the jitters are fixed, using the 3Vo to drive Aref would give a better range on the ADCs. (To use the Aref signal for the ADCs instead of the on board 3.3V, there is a setting to make in the Netduino - I can't remember what it is off hand.)
EDIT: sorry the regulator is actually 3.3V so it will not give an improvement in range. I read 3Vo as three volts not 3.3 Volts
A few questions that might help spot a problem with your setup:
What have you done with the test pin? The data sheet says to either leave it unconnected or to tie it to ground.
What voltage have you connected to Vin (3.3V or 5V)? I think 5V would be better, I am not sure that 3.3V will give enough voltage for the regulator to work correctly.
How long are the wires from the board back to the Netduino? If they are long, they will be susceptible to noise, and the chip may not be able to drive enough current into them.
Remember to enjoy yourself - it is a hobby after all
Regards - Paul
Posted 05 March 2012 - 07:47 PM
Posted 05 March 2012 - 08:38 PM
Posted 05 March 2012 - 08:46 PM
There's other ways to make it faster (don't push/pop from a list, instead use a plain array and cycle the index that you are using). However, your main problem is that you only have an accelerometer to measure the orientation of your setup, and accelerometers are jittery in itself - also, for an accelerometer gravity is indistinguishable from you accelerating your hand, so it's expected that your readings are off when you move your hand. What you'd need to do would be to couple the accelerometer with a gyro, and then combine the measurements e.g. complementary filtering - see this Presentation for example.
Stefan,
I'm sorry I did not see this post. I just ordered a sensor with Nine axis modules (three-axis gyro + three axis acceleration + tri-axial magnetic field)
I'll give it a go with that one. Thank you.
And Paul, thanks again for your insight as well.
