SOMO-14D Embedded Audio-Sound Module - Project Showcase - Netduino Forums
5 replies to this topic
#1 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 12 February 2012 - 02:11 PM
Last weekend I made a small class to drive the SOMO-14D module.
It's perhaps not the cheapest audio solution, but it works, easy to connect, and it can hold 512 tracks on a µSD-card (no SDHC-support though!)
I made a small sample video:
http://www.youtube.com/watch?v=KDN4hDNWv3A
How to use it?
 * This sample uses 5 files on the SD-card. They can be found in netmftoolbox\Samples\Visual C#\Sound Module\samples
public static ushort EXTERMINATE = 0;
public static ushort WAAAAAAAAAAAA = 1;
public static ushort YOUMAYNOTLEAVE = 2;
public static ushort TARDIS = 3;
public static ushort SONIC = 4;
    // The module is connected to these pins
    Somo SoundModule = new Somo(Pins.GPIO_PIN_D0, Pins.GPIO_PIN_D1, Pins.GPIO_PIN_D2);
    // Sets the volume fully open
    SoundModule.SetVolume(7);
    // Plays "Exterminate!"
    Debug.Print("EXTERMINATE");
    SoundModule.PlayTrack(EXTERMINATE, true);
    // Plays the Tardis-sound
    Debug.Print("TARDIS");
    SoundModule.PlayTrack(TARDIS, true);
    // Plays "You may not leave my precence!"
    Debug.Print("YOUMAYNOTLEAVE");
    SoundModule.PlayTrack(YOUMAYNOTLEAVE, true);
    // Plays the sonic screwdriver sound
    Debug.Print("SONIC");
    SoundModule.PlayTrack(SONIC, true);
    // Repeatedly play "Waaaaaaaaa!"
    Debug.Print("WAAAAAAAAAAAA (repeated)");
    SoundModule.PlayRepeat(WAAAAAAAAAAAA);
    // Let this go on infinitely
You can download the source code here
Now let your Netduino talk!
#2 Mario Vernari
Posted 12 February 2012 - 04:07 PM
*** SIMPLY AMAZING !!! *** I want it! ...BTW, congrats for the video+sources, though! Cheers
#3 NeonMika / Markus VV.
  • 209 posts
  • LocationUpper Austria
Posted 27 March 2012 - 03:11 PM
Yeah, your video is really cool =)
Greets
NeonMika.Webserver
> Browse the SD on your N+ directly in the browser and d
own - and upload files
If you need help with NeonMika.Webserver, please just leave a note in the thread and/or contact me via Skype :)
#4 atabou
atabou
Posted 24 October 2012 - 07:23 AM
Hi I don't know if you can help me because I don't use arduino. I am currently trying to command the somo in serial mode using an AVR ATmega48 in the beginning and then I'm planing on migrating to a Xmega128. In any case I'm programming using C code with the CodeVision compiler. So far I've written the following code taking some lines out of the forums in the web, but I still can't get to communicate with the somo. I checked the waveforms in Proteus and seems that I can not adjust the timing in a proper way.
Here is the code:
#include <mega48.h>
#include <stdio.h>
#include <delay.h>
//PORTC.2 ia the resest pin
//PORTC.1 is the clock pin
//PORTC.0 is the data pin
void reset(void)                            //subroutine to reset somo
    PORTC.2=0; //pin de reset en bajo
    delay_ms(6);
    PORTC.2=1; //vuelve a estar en alto el pinde reset para permitir el funcionamiento nomral del robot
void envia_comando (unsigned int ThisSong)  //subroutine to send the command
    unsigned int TheSong = ThisSong;
    unsigned int ClockCounter = 0;
    reset();        //se resetea el módulo para enviar una nueva instrucción
    PORTC.0=0;      //data
    PORTC.1=1;      //clock
    delay_ms(300);
    PORTC.1=0;      //clock
    delay_ms(2);
    PORTC.1=1;
    while(ClockCounter<= 15 )
        //PORTC.0=0;             //pone el pin de datos en bajo
        if (TheSong & 0x8000)
                PORTC.0=1;     //pone el pin de datos en alto
        else
        PORTC.1=1;             //pone el pin de reloj en alto
        delay_us(50);
        TheSong = TheSong << 1;
        PORTC.1=0;             //pone el pin de reloj en bajo
        delay_us(50);
        ClockCounter++ ;
    delay_ms(20);
void main(void)
DDRC = 0b00001011;
PORTC = 0x00;
DDRD = 0x00;
PORTD = 0x00;
PORTC.2 = 1;
while (1)
      // Place your code here
       if( PORTD.2)
          delay_ms(500);
           if(!PORTD.2)
               envia_comando(0x000A);            //for example I want to play track number 10
Thanks a lot if someone can give me a hand. or some ideas to make it better.
Edited by Chris Walker, 05 November 2012 - 04:18 AM.
added [code][/code] tags
#5 Chris Walker
Posted 05 November 2012 - 04:19 AM
Hi atabou,
I'd recommend raising this question in the Arduino forum. We typically only deal with ARM-based microcontrollers here, not AVR-based ones like Arduino.
#6 Giuliano
Giuliano
  • 361 posts
  • LocationSimi Valley, CA
Posted 22 October 2014 - 02:26 AM
Hi Stefan,
Do you happen to know if the Sparkfun WTV020SD would work with your library out of the box?
