NeonMika.Webserver - Page 11 - Project Showcase - Netduino Forums
NeonMika.Webserver
webserver web server neonmika internet web server http sd xml json
213 replies to this topic
#201 Peter Forstmeier
Peter Forstmeier
  • 53 posts
Posted 17 May 2014 - 05:33 PM
i try to convert NeonMika.Webserver to Framework 4.3 with no success. Is  somebody out how can Point me in the right direction.
Problem: I changed all the Projects to 4.3, compiling is ok, but it seems that the deployment 'blocks' my N2P.
Even with MFDeploy there is no answer from N2P ping... is freezing.
Peter
#202 EnergySmithe
EnergySmithe
  • 10 posts
Posted 07 June 2014 - 05:04 AM
Markus, I just wanted to chime in and thank you again for all your hard work on this.  I am going to give this a try tomorrow of my N+2's.  Really awesome project, great work man!
Jim
#203 NeonMika / Markus VV.
  • 209 posts
  • LocationUpper Austria
Posted 11 June 2014 - 10:14 AM
Peter
Sorry that I haven't answered for so long. I cannot help you with that problem because I just have a NP1. Have you ever figured out how to get it working?
Jim
Thanks Jim! It's always great to hear so kind words.
Please let me know how NeonMika.Webserver works for you. If you have questions don't hesitaste to aks :)
Greets, Markus
NeonMika.Webserver
> Browse the SD on your N+ directly in the browser and d
own - and upload files
If you need help with NeonMika.Webserver, please just leave a note in the thread and/or contact me via Skype :)
#204 Peter Forstmeier
Peter Forstmeier
  • 53 posts
Posted 11 June 2014 - 05:52 PM
i didn't try it any more. but if i find some time i will give them a second chance
Gruß nach A aus D
Peter
#205 EnergySmithe
EnergySmithe
  • 10 posts
Posted 12 June 2014 - 06:43 AM
Markus, this is really awesome!  One of my n+2 is used as a controller for a chicken coop door, temperature sensor, daylight sensor, etc.  I was never happy with how it was working.  In less than 20 minutes using your webserver I have a project that is working MUCH better/cleaner and is easily upgradeable!  The one thing I would mention so it would get updated in the documentation is that the RequestReceivedEventArgs is just Request now, but that was easy enough to figure out.
Thank you and all who contributed to this project - this just lets you concentrate on doing the fun stuff!
Best regards,
Jim
#206 NeonMika / Markus VV.
  • 209 posts
Posted 26 June 2014 - 10:06 AM
Best regards,
Jim
I'm always happy when my webserver code can help people cutting down their development to the important part without caring about the whole networking stuff :)
Good that it worked out without problems for you :)
Thanks for the tip with the documentation, i will fix this :)
Greets,
Markus
NeonMika.Webserver
#207 daverathbone
daverathbone
  • 3 posts
Posted 17 August 2014 - 06:26 PM
Great crashed the Netduino Plus 2 after loading a webpage will not boot now!
needs to be re-flashed.
I think secret labs needs to remain a secret and develop the 1980 watch!
As old NETMF with missing dot.net functions and SL's stack hacked stack is pants!
If You like flashing a blue light then your CLR will just do it!
That's why Microsoft dropped it. it so Sloooow!
Learn C or Buy a PI!
#208 beastyboy
beastyboy
  • 194 posts
  • LocationNetherlands
Posted 18 August 2014 - 10:35 AM
Good luck Dave,
I run multiple projects without any problems.
So what are you doing wrong...
Just ranting in these forums does not help you, And does not correctly show how awesome these devices are.
And I am one of the most critical people running around in these forums.
Best regards and have fun with your PI that runs Mono with C# ....
Olaf
Van SchOten Ict Diensten en Services
http://www.voids.nl
#209 NeonMika / Markus VV.
  • 209 posts
Posted 25 August 2014 - 10:04 AM
Hello Dave!
I'm sorry that the Netduino doesn't work out for you as expected.
I'm also sorry that NeonMika.Webserver doesn't work on you device, but I can tell you that I got many feedbacks from different people that it works on their devices without problems.
I would try to help you out, but according to the "sound" of your text you are not really interested on working together on a solution.
And thanks for the advice, but I already know C (I'm currently writing my bachelor thesis with it) and a also own a Raspberry Pi ;)
Good luck Dave,
Olaf
Thanks for your reply Olaf.
It's great to hear that you run different projects without problems :)
And always keep critical, supporting feedback is always welcome!
The more informative feedback, the better a software can get :)
Greets, Markus
NeonMika.Webserver
#210 gangolfus
gangolfus
  • 9 posts
Posted 03 September 2014 - 04:50 PM
I just wanted to report that I was able to get NeonMika.Webserver working on my N+2 with framework 4.3.1 with ease.  There are 2 things that need to be done.
1) For each project, right-click>Properties>Application and update the Target framework to ".NET Micro Framework 4.3"
2) For each project, expand the References folder, remove any reference to Microsoft.SPOT.* and SecretLabs.NETMF.* and re-add the 4.3.1 versions of each
Took me all of 5 minutes and fired right up!
#211 NeonMika / Markus VV.
  • 209 posts
Posted 05 September 2014 - 01:28 PM
Hi gangolfus!
Thanks for the info, that are great news.
I don't have a N+2 at my place, so it's always appreciated when people give feedback on how they get things done :)
If people have questions in the future regarding N+2 or .net framework 4.3 I can refer them to your post, thank you :)
Greet, Markus
NeonMika.Webserver
#212 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 25 May 2015 - 11:20 AM
Managed to get this working on the Netduino 3 with a little bit of fiddling:
  1. Upgraded all the project to NETMF 4.3
  2. Changed the reference to the NetduinoPlus assemby to Netduino
  3. Some of the SecretLabs assemblies in the WebServer project had to be manually removed and replaced with 4.3 versions
  4. Had to remove the call to interf.EnableDhcp() in Server.cs as this is not implemented.  Also commented out the line below it.  Will investigate later.
But it's up and running...
#213 NeonMika / Markus VV.
  • 209 posts
Posted 29 September 2015 - 11:35 AM
After some months I just had the idea to visit the netduino forum again :)
Great to also see it running on netduino 3 and thanks for your input. Hope it can help others to run it on N3.
Greets,
Markus
NeonMika.Webserver
#214 Bayzter
Bayzter
  • 4 posts
Posted 02 February 2016 - 09:53 PM
Hi guys,
I'm trying to convert my NeonMika.Webserver soloution for my Netduino +2 from framework 4.2 to 4.3, but i am stuck with an error i do not know what to do about.
I followed the guide written in the post above.
1. Changed target framework for all projects included in the soloution from 4.2 to 4.3
2. Deleted 4.2 references and re added 4.3 references instead.
The error i am getting in VS2015 :
Severity Code Description Project File Line Suppression State
Error CS1579 foreach statement cannot operate on variables of type 'string' because 'string' does not contain a public definition for 'GetEnumerator' JSONLib C:\Users\bayzt\Desktop\Ny mappe\Framework\FastloadMedia.NETMF.Http\JSONLib\Json.cs 43 Active
Error 0x80131700 JSONLib C:\Users\bayzt\Desktop\Ny mappe\Framework\FastloadMedia.NETMF.Http\JSONLib\MMP
Error 0x80131700 NeonMika.Util C:\Users\bayzt\Desktop\Ny mappe\Framework\NeonMika.Util\MMP
Error 0x80131700 NeonMika.XML C:\Users\bayzt\Desktop\Ny mappe\Framework\NeonMika.XML\MMP
Error 0x80131700 NeonMika.Webserver C:\Users\bayzt\Desktop\Ny mappe\Framework\NeonMika.Webserver\NeonMika.Webserver\MMP
Error 0x80131700 NeonMikaWebserverExecuteable C:\Users\bayzt\Desktop\Ny mappe\Executeable\NeonMikaWebserver\NeonMikaWebserver\MMP
Any help would be appreciated!  :rolleyes:
/Kim
Also tagged with one or more of these keywords: webserver, web server, neonmika, internet, web, server, http, sd, xml, json
