Compatible Shields and Accessories - Page 4 - Netduino 2 (and Netduino 1) - Netduino Forums
70 replies to this topic
#61 lancewmccarthy
lancewmccarthy
  • 9 posts
  • LocationBoston, MA USA
Posted 06 February 2013 - 12:04 AM
Seeed Studio Bluetooth Shield and Netduino
I am attempting to apply the code seen in this awesome project http://blog.roguecod...luetoothwithWP8 but I am using a SeeedStudio Bluetooth shield.
All I can find for sample code for this shield is written for Arduino http://www.seeedstud...luetooth_Shield, it is some great documentation, but nothing in c#.
Has anyone used this Bluetooth shield with the netduino and know of a good starting point (simply getting it to the point of pairing it) maybe even you've successfully streamed through it?
Thanks!
Lance McCarthy
Microsoft MVP (Windows Platform Development)
#62 gopsi
gopsi
Posted 07 February 2013 - 07:16 AM
There are lots of Arduino-compatible shields. Many/most of them work with the Netduino. Some of them require C# drivers, some do not.
A few community members have asked for a list of tested/compatible shields, components, etc. Let's make that list here.
There are literally thousands of components out there, so this will serve as a very brief introductory list--but let's not worry about making it a really long introductory list Posted Image
A few notes:
1. Please link to the manufacturer's website where possible--for details on the accessory
2. If you've built a project, please link to it (or its post) showcasing your use of the accessory
3. If the accessory requires C# drivers, please link to them here...
Will the Ethernet Arduino Shield works with Netduino 1 board. And if yes, any driver is required for it. And is there any project to show how to connect both of them.
#63 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 07 February 2013 - 11:15 AM
Hi and welcome to the Netduino community!
You are probably looking for this:
http://forums.netdui...hernet-shields/
#64 Kalix
Kalix
Posted 10 February 2013 - 10:05 PM
Just got the  http://learn.adafrui...shield/overview shield working on a Netduino plus 2 with 4 DC motors (Have not tested servos or steppers yet).
Did have to modify some of the codesamples I found because of difference in PWM classes. (Code now only supports 4 DC motors all PWM controlled).
using System;using System.Threading;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.Hardware.Netduino;namespace Robot.Drivers.Adafruit{    public class MotorShield : IDisposable    {        public enum Drivers : byte        {            None = 0,            Driver1,            Driver2,            Both        }        public enum Motors : byte        {            M1 = 0,            M2,            M3,            M4        }                private Drivers UsedDriver;        private PWM Motor1;        private PWM Motor2;        private PWM Motor3;        private PWM Motor4;        private OutputPort MotorLatch, MotorEnable, MotorClk, MotorData; // 74HCT595 commands        byte latch_state; // Actual 74HCT595 output state        double MaxSpeed;        /// <summary>        /// Constructor        /// </summary>        /// <param name="driver"> Which driver to initialize : 1=driver 1, 2=driver 2, 3=both</param>        public MotorShield(Drivers driver = Drivers.Both, double pwmfrequency = 20000, double maxspeed = 255D)        {            UsedDriver = driver;            if (driver == Drivers.Driver1 || driver == Drivers.Both)            {                Motor1 = new PWM(PWMChannels.PWM_PIN_D11, pwmfrequency, 0, false);                Motor1.Start();                Motor2 = new PWM(PWMChannels.PWM_PIN_D3, pwmfrequency, 0, false);                Motor2.Start();            }            if (driver == Drivers.Driver2 || driver == Drivers.Both)            {                Motor3 = new PWM(PWMChannels.PWM_PIN_D6, pwmfrequency, 0, false);                Motor3.Start();                Motor4 = new PWM(PWMChannels.PWM_PIN_D5, pwmfrequency, 0, false);                Motor4.Start();            }            MotorLatch = new OutputPort(Pins.GPIO_PIN_D12, true);            MotorEnable = new OutputPort(Pins.GPIO_PIN_D7, false);            MotorClk = new OutputPort(Pins.GPIO_PIN_D4, true);            MotorData = new OutputPort(Pins.GPIO_PIN_D8, true);            MaxSpeed = maxspeed;            latch_state = 0;            latch_tx();        }        #region IDisposable Members        public void Dispose()        {            latch_state = 0;            latch_tx();            if (UsedDriver == Drivers.Driver1 || UsedDriver == Drivers.Both)            {                Motor1.Dispose();                Motor2.Dispose();            }            if (UsedDriver == Drivers.Driver2 || UsedDriver == Drivers.Both)            {                Motor3.Dispose();                Motor4.Dispose();            }            MotorLatch.Dispose();            MotorEnable.Dispose();            MotorClk.Dispose();            MotorData.Dispose();        }        #endregion IDisposable Members                // Send byte to the 74HCT595 demux        private void latch_tx()        {            MotorLatch.Write(false);            MotorData.Write(false);            for (int i = 0; i < 8; i++)            {                MotorClk.Write(false);                bool bitdata = (latch_state & (1 << (7 - i))) > 0;                MotorData.Write(bitdata);                MotorClk.Write(true);            }            MotorLatch.Write(true);        }                /// <summary>        /// Control a motor; Non-blocking call. Set speed to 0 to stop.        /// Frequency might need to be adjusted deppending on motor, or to match other PWMs        /// </summary>        /// <param name="which">Which motor to drive</param>        /// <param name="speed">Speed, between 0 and MaxSpeed supplied in Constructor (0 to stop)</param>        /// <param name="direction">True = foward, False = backward</param>        public void MotorControl(Motors which, int speed, bool direction)        {            switch (which)            {                case Motors.M1: // This motor can have its speed controlled through PWM                    if (speed == 0)                    {                        Motor1.DutyCycle = 0;                    }                    else                    {                        latch_state = (byte)((latch_state & 0xF3) | (direction ? 4 : 8));                        latch_tx();                        uint duration = (uint)(Motor1.Period * (double)speed / MaxSpeed);                        Motor1.Duration = duration;                    }                    break;                case Motors.M2: // This motor can have its speed controlled through PWM                    if (speed == 0)                    {                        Motor2.DutyCycle = 0;                    }                    else                    {                        latch_state = (byte)((latch_state & 0xED) | (direction ? 2 : 16));                        latch_tx();                        uint duration = (uint)(Motor2.Period * (double)speed / MaxSpeed);                        Motor2.Duration = duration;                    }                    break;                case Motors.M3: // This motor can have its speed controlled through PWM                                      if (speed == 0)                    {                        Motor3.DutyCycle = 0;                    }                    else                    {                        latch_state = (byte)((latch_state & 0xBE) | (direction ? 1 : 64));                        latch_tx();                        uint duration = (uint)(Motor3.Period * (double)speed / MaxSpeed);                        Motor3.Duration = duration;                    }                    break;                case Motors.M4: // This motor can have its speed controlled through PWM                                      if (speed == 0)                    {                        Motor4.DutyCycle = 0;                    }                    else                    {                        latch_state = (byte)((latch_state & 0x5F) | (direction ? 32 : 128));                        latch_tx();                        uint duration = (uint)(Motor4.Period * (double)speed / MaxSpeed);                        Motor4.Duration = duration;                    }                    break;            }        }    }}
#65 Vol_Del
Vol_Del
Posted 18 February 2013 - 10:25 PM
Hi all!
I´m an absolutely newbie to .NETMF programming and love to spent some time as a hobbyist on this platform. To be honest my personal programming experience lasts back to my university time when I was programming in Turbo Pascal and a little assembler... (which is more than 25 years ago)
I have some understanding of the C, C++ and even C#, read some books, did some small practice (and forgot many things, as I didn´t find the time to consecutively follow my trail aside of my job).
I bought a Netduino 2+ and for some trials a Nootropic design 4 digit shield, a Adafruit Motorshield and a luminosity sensor. Thanks to you guys I already found some porting for the motor control, but I´m struggling with the digit shield. It uses 4 pins and uses a timer interrupt controlled multiplexing. What I´ve understood so far from the Arduino library provided by Nootropic, is that the concept is based on using a shift register for the data (taking 1 pin), a clock pin, a latch pin and a control pin for decimal point on/off. Many of the inherited methods appear quite simple, but especially this timer issue is giving me headache. I have tried to figure out, whether and how this ISR concept could be ported ....but to be honest: I HAVE GOT NO CLUE
Has anyone played around with this shield yet?
Thx in advance from a desperate bloodie newbie.......
#66 Kalix
Kalix
Posted 19 February 2013 - 07:26 AM
Hi all!
Hi Vol_Del,
First of all, I do not have the [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Nootropic design 4 digit shield you are talking about, however the technique used to write to the 4 digit shield is the same used in the Motor driver above your post. Both shields use a 74HC595 serial to parallel latch. Take a look at the: [/color]latch_tx(); method and the assignment: latch_state [color=rgb(102,102,0);]=[/color] [color=rgb(102,102,0);]([/color][color=rgb(0,0,136);]byte[/color][color=rgb(102,102,0);])(([/color]latch_state [color=rgb(102,102,0);]&[/color] [color=rgb(0,102,102);]0xBE[/color][color=rgb(102,102,0);])[/color] [color=rgb(102,102,0);]|[/color] [color=rgb(102,102,0);]([/color]direction [color=rgb(102,102,0);]?[/color] [color=rgb(0,102,102);]1[/color] [color=rgb(102,102,0);]:[/color] [color=rgb(0,102,102);]64[/color][color=rgb(102,102,0);]));[/color]
If you use a windows calculator (set to programmer mode) you will find that 0xBE translates into the bit pattern 10111110 in the code above either the first bit or the seventh bit is set. The latch_tx method is all you need to write the 8 bits to the 74HC595. For more information about the 74HC595 I recommend reading this article: http://arduino.cc/en/Tutorial/ShiftOut .
The other IC on the Nooptric shield will translate the binary pattern of the 74HC595 to the 7-segment display so you do not have to do that yourself.
Hope this helps you a bit.
One more thing to keep in mind is the use of pins when stacking shields on top of each other.
The Adafruit Motor shield uses quite a lot of pins. The information below might help you:
What pins can be used for external components on the Arduino with Ladyada's Motor Shield?
Answer:
What pins are not used on the motor shield?
All 6 analog input pins are available. They can also be used as digital pins (pins #14 thru 19)
Digital pin 2, and 13 are not used.
Digital pin 11: DC Motor #1 / Stepper #1 (activation/speed control)
Digital pin 3: DC Motor #2 / Stepper #1 (activation/speed control)
Digital pin 5: DC Motor #3 / Stepper #2 (activation/speed control)
Digital pin 6: DC Motor #4 / Stepper #2 (activation/speed control)
These pins are in use only if the DC/Stepper noted is in use
Digital pin 4, 7, 8 and 12 are used to drive DC motors and Stepper motors via the 74HC595
serial-to-parallel latch
All these pins are in use if any DC motors or steppers are used
Digitals pin 9: Servo #1 control
Digital pin 10: Servo #2 control
These pins are used only if that particular servo is in use
#67 Nerdenator
Nerdenator
Posted 28 August 2013 - 06:20 PM
All,   I am curious if the SparkFunCAN-bus shield is compatible with the Netduino 2. Furthermore, I'm interested to know if any libraries exist to make the shield run.
#68 sfugarino
sfugarino
  • 29 posts
  • LocationSuwanee, GA
Posted 19 March 2014 - 01:15 PM
Does the Adafruit Ultimate GPS Logger Shield work with netduino? Not the older one, this one:
http://www.adafruit.com/products/1272
#69 nhale
nhale
  • 64 posts
  • LocationHeidelberg, Germany
Posted 31 March 2014 - 03:38 PM
I would also be interested in that
#70 c2rosa
c2rosa
  • 15 posts
Posted 29 May 2014 - 12:35 PM
Do these shields work with the Netduino 2 as well?
If so, where do I go to download libraries (*.dll files or the C# source code) to drive these shields?
Finally, do I need a particular firmware in my Netduino 2 or a particular version of the SDK for these to work?
I'm particularly interested in a motor shield, if possible, but some of the others look cool too.
#71 tridy
tridy
  • 68 posts
  • LocationStockholm, Sweden
Posted 11 May 2015 - 02:31 PM
Would it be possible to create a compatability checklist, so everyone could at least eliminate the most obvious incompatible shields/components?
