Netduino Mini -using same COMPORT for deployment and debugging
1 reply to this topic
#1 Nissim
Nissim
  • 54 posts
  • LocationNew Zealand
Posted 12 September 2011 - 07:02 AM
Hi There
I have Netduino Mini
Is it possible to make use of the same comport of Netduino Mini to download firmware and for debugging?
I can deploy my example successfully on first attempt.
But the second time around the device is hung
As you can see below I close comport after sending test byte - I was hoping that after closing the port the comport will become available again.
using System.IO.Ports;
using SecretLabs.NETMF.Hardware.NetduinoMini;
namespace NetduinoMiniApplication1
            var serialPort = (SerialPort)null;
            Thread.Sleep(1000);
            var bytes = new byte[] { 0x31 };
            serialPort = new SerialPort("COM2", 9600, Parity.None, 8, StopBits.One);//" COM2"  RS232  Pin 1,2
            serialPort.Open();
            serialPort.Write(bytes, 0, 1);
           serialPort.Close();
                Thread.Sleep(5000);
Many thanks
Nissim
Edited by Nissim, 12 September 2011 - 07:22 AM.
Added [code] tags
#2 Dixon
Dixon
  • 32 posts
Posted 13 September 2011 - 08:58 AM
Hi Nissim, I'm afraid you can't. You will need to delete the application before you can deploy again. Check http://forums.netdui...-netduino-mini/ Regards, Carlos.
