So I bought three netduino mini's and I changed the pins to program them on using putty and pressing escape. I was then able to program each of them the first time no problem, but then they wont program again. I've found if I reset the board randomly throughout the programming process I can sometimes get them to program. Any ideas on what i'm doing wrong?
Can't reprogram Netduino Mini
Started by i182willsw, May 27 2011 05:11 PM
1 reply to this topic
Posted 27 May 2011 - 05:11 PM
Posted 27 May 2011 - 05:31 PM
Hi i182willsw,
Do the Netduino Minis run your app when they first boot?
It's possible that the program you're running is locking out the debugger. Are you opening up the debug serial port in your app by any chance?
Regardless, you can fix this problem by applying power to the DTR pin (pin 3) while powering up the Netduino Mini...and then pressing ERASE in MFDeploy. This will clear the current app off your Netduino Mini.
